TRD Cold Air Intake upgrade for my 5.7L... Yes/No?
Discussion in 'Performance and Tuning' started by InfernoB, Aug 13, 2016.
  1. Aug 14, 2016 at 7:02 PM
    Seems like I was correct that the TRD CAI is pretty much for looks which is OK. Not much more air flow to make it worth it. I will back track my statement that I would "maybe" spend up to $200. ..............Back to $0, not even $75. Use your money for for a great nite out with your kids/girl friend/wife. Better spent.
    CultusRider likes this.
  2. Aug 14, 2016 at 7:46 PM
    TheBeast The Beach
    there was a thread on the forum where pretty much if you get the TRD air filter + the oversized connector you make your own TRD CAI for like 75 bux top.
    Black Wolf and CultusRider like this.
  3. Aug 14, 2016 at 8:38 PM
    CultusRider
    CultusRider Know What Matters
    BC
    07' White SR5 DC 5.7L 4x4
    Bilstein 6112's & 5160's, Coachbuilder +1 Shackles, BA Stainless Exhaust, 17x8.5 Method Racing NV Wheels, 305/65R17 BFG KO2's, TRD Skid Plate, K&N CAI, Shift Handle, Roll N' Lock Tonneau Cover, Rubber Bed Liner, Toyota side steps...
    This reminds me - "Patience is a virtue", and repeat.... and repeat... thanks guys
  4. Aug 14, 2016 at 8:39 PM
    I remember that now. I think there was a part# for that TRD inlet piece too. I bet @Roman can get it too. Totally forgot about that. We need to bump that.
    TheBeast[QUOTED] and Roman like this.
  5. Aug 14, 2016 at 8:41 PM
    I just tried to find it. ??? Help!!!!
  6. Aug 15, 2016 at 7:04 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I might be able to get it. What exactly are we needing?
  7. Aug 15, 2016 at 7:45 AM
    I believe it's a new TRD style box air inlet to replace the OEM box air inlet for better air flow. I know I've seen it it somewhere. It may not even be a Toyota part.
  8. Aug 15, 2016 at 8:09 AM
    Roman
    Roman
    Franklin, TN
    There is a red, accordion like hose that connects directly to the TRD air box. Is that the one you're referring to?
  9. Aug 15, 2016 at 9:05 AM
    No not referring to that hose, The one I'm thinking about is the air inlet that is located between air box and the fender well. This new air inlet is supposedly designed for better air flow using the existing air box. I'll try to find a pic of what I'm talking about during my lunch break. I'm pretty sure it was a non Toyota sourced part.
  10. Aug 15, 2016 at 12:56 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Trd airflow accelerator
    Not sure that it actually did anything, but the sound of the air intake changed a little after I installed it.
    Texastundra2018 likes this.
  11. Aug 15, 2016 at 1:09 PM
    That's it. I knew I saw it here. Sorry about that Gary. Do you have the part# for that? If I recall it's supposed to improve air flow. More cold outside air can't hurt. Bottom line...Would you do this mod again?
    TruckyTruck[QUOTED] likes this.
  12. Aug 15, 2016 at 1:19 PM
    TruckyTruck
    Gary
    Absolutely. It brings the stock box one step closer to the trd setup. And I think it was relatively inexpensive. I don't have the part number anymore though. It looks like the s&b uses the same design on this part if that says anything to you. I'm sure it smooths out the air intake at the fender. I heard more of a gulp of air after it was installed.
  13. Aug 15, 2016 at 1:41 PM
    TheBeast The Beach
    I'll check my ebay list. I had the parts # there
  14. Aug 15, 2016 at 2:24 PM
    Roman
    Roman
    Franklin, TN
  15. Aug 15, 2016 at 3:10 PM
    Lee's rig
    Lee's rig Party naked
    Lee
    North nj
    2014 DC and 2014 single cab both 8' bed with 5.7
    To many
    I have one of the exhausts from him. Lost gpm due to the fact I am always on it. The sound is great and it is music toy ears
    CultusRider[QUOTED] likes this.
  16. Aug 15, 2016 at 3:22 PM
    TheBeast The Beach
  17. Aug 15, 2016 at 4:32 PM
    Thanks for that info Beast. The following is for the un-initiated: The TRD drop in is a wet filter. Just like the K&N. For those watching this thread..... Imagine a very good dry filter being a spider web, a spider web with nano inch spacing. Blocks a lot of dust particles. Add a little oil to that web. Restricts even more air particles. Obviously you don't want to use too much filter oil. Defeats the purpose. This is not rocket science by the way. If you read (RTFM) the f***king manual for a wet filter, you are good to go. "Oh, I may accidentally use too much and frack up my MAF". Only if you are a lame brain. Thin film......as in thin, sparse, a little. Give me a freaking break. This is not a hand holding lesson. Gary made a good point, this simple part that replaces the OEM inlet duct/pipe gives you some more COLD, (cooler), air flow from the "outside". Will it make you "King of the Hammers"?,No.............But a hell of a lot better than spending hard earned $ on an aftermarket "hot air intake" like the AFE for example. Aftermarket CAI's aren't the #1 scam. #1 scam is a throttle body spacer. Might as well torch your $. Better thrill than the total disappointment you will get from the throttle body spacer. I never rant here, never.
    tat2ude39 likes this.
  18. Jul 2, 2019 at 6:06 PM
    learnem
    learnem New Member
    Bakersfield, Ca
    16 Tundra crewmax
    3 in lift, 2in wheel spacers. Tinted all the way around Stock platinum wheels and tires
    Imo, you are better off going with a K&N and call it good.
  19. Jul 5, 2019 at 4:29 PM
    #49
    Texastundra2018
    Texastundra2018 New Member
    Aj
    2018 TRD 4x4 Crewmax Offroad
    Cold air intake, premium sound
    I swapped my stock out for a K&N cold air intake three months ago. Our environment is pretty hot in traffic and out on the beach area. It sounds more peppy and my mileage has improved by 1 mile per gallon. This will be my second swap. I found it very helpful on my 2nd gen Tundra 2wd. This 4x4 is a guzzler but I dig it. My last K&N made it 112k mi. 2 filter cleanings.
  20. Jul 5, 2019 at 4:51 PM
    #50
    bfd300
    bfd300 New Member
    Old thread but I would say no. Not worth the cash. K&N air filter with Toyota air accelerator does the same thing and a lot cheaper. My 2 cents.
    New_DoorDing likes this.
  21. Jul 6, 2019 at 5:41 AM
    #51
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Does anyone know if you can buy just the top box portion of the TRD cai? I dont want all the other parts, just the top.
  22. Jul 6, 2019 at 8:08 AM
    #52
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    Yes you can buy just the top part. As a matter of fact I have one on order that's supposed to be delivered today!
  23. Jul 6, 2019 at 8:10 AM
    #53
    Boxer310
    Boxer310 New Member
    2018 white tundra crewmax sr5
    For the looks yes if you just want the upgrade without the price then.buy the trd air filter and the mass air flow accelerator that what the trd cai comes with you just won't have the Nice red hosing and boxing
  24. Jul 6, 2019 at 8:58 AM
    #54
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Where did you order it from?
  25. Jul 6, 2019 at 9:00 AM
    #55
    Boxer310
    Boxer310 New Member
    Sparks toyota
  26. Jul 6, 2019 at 11:05 AM
    #56
    MR TRD PRO
    Queens, NYC
    HP Tuned
    Sparks Toyota and then used tundradude34's promo code for an extra 5% off my order
  27. Jul 6, 2019 at 11:07 AM
    #57
    MR TRD PRO
    Queens, NYC
    HP Tuned
    Well folks, my TRD air box came in and I managed to get it installed with 200 miles on the new truck!!!
    I made it work with the stock intake piping, and already have the TRD air accelerator in place along with the TRD drop in panel filter.
  28. Jul 7, 2019 at 3:25 AM
    #58
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    Did you have any issues with it fitting with the stock intake tube? Is the outlet on the TRD box in the same location as stock? I was hoping to find some pictures of the TRD and stock side by side to see differences. I heard the TRD is taller but wasn’t sure it the outlet is still the same spot.
  29. Jul 7, 2019 at 3:25 AM
    #59
    Rustyscrew
    Rockledge,Fl
    15 Tundra Platinum
    It looks really good btw
    MR TRD PRO[QUOTED] likes this.
  30. Jul 7, 2019 at 6:27 AM
    #60
    MR TRD PRO
    Queens, NYC
    HP Tuned
    The diameter on the TRD upper lid is slightly larger than the OEM one, and it was a bit tricky to slip on but with some patience you could get it on. The rubber coupling is flexible and can expand a bit to slip over the piping on the TRD lid. The outlet position is similar to the stock lid, fits fine and looks like it came that way from the factory, which was an important thing for me. I'm happy with it
