TRD Center Caps on 2021 TSS OffRoad
Discussion in 'Wheels & Tires' started by PonyMan, Jan 31, 2021.
  1. Jan 31, 2021 at 5:15 PM
    PonyMan
    PonyMan [OP] Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
    Can anyone confirm if the TRD center caps interchange with the center caps on the 2021 TSS OffRoad 20” wheels? TIA
  2. Jan 31, 2021 at 5:48 PM
    They will not fit.
    Two different companies and different fittings.
    TSS wheels are made by Ultra Wheels.
    Motor71 and BravoDeltaRomeo like this.
  3. Jan 31, 2021 at 5:54 PM
    TSS caps
    TRD Off Road caps
    jonclark96 likes this.
  4. Jan 31, 2021 at 6:49 PM
    PonyMan
    Central, Louisiana
    Oh wow, yea totally different! Thanks for the info.
  5. Jan 31, 2021 at 7:13 PM
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    @Beau did something similar to his wheels. These look like and older version, but perhaps he can shed some light.
  6. Jan 31, 2021 at 7:27 PM
    :hattip:
  7. Jan 31, 2021 at 7:32 PM
    PonyMan
    Central, Louisiana
    This is what I’m looking for. Hopefully he’ll chime in on this!
  8. Jan 31, 2021 at 7:58 PM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    Mine are the 2019 TSS wheels but seem to be pretty similar to the OPs. Here is the thread that I created when I completed the caps. They are the standard TRD caps that were cut, dremeled, adorned with a vinyl circle, and glued in place. I rate the job a 5/10 in terms of difficulty though. Basically, you start with this and cut it down until it fits into the center cap hole and then run a bead of black glue on the outside perimeter. At first, I thought it wouldn’t work or look good because of the glue but I love the new look and the glue isn’t really noticeable. Hope this helps. I’ll see if I can find any pics that I took during the process.
  9. Jan 31, 2021 at 8:01 PM
    PonyMan
    Central, Louisiana
    perfect! Thanks for the quick response!
  10. Jan 31, 2021 at 8:13 PM
    Beau
    Beau
    These are all the pics I have. Hope they help.
    This is what it looks like once it's cut down:IMG_4450 3.jpgIMG_4449 3.jpgIMG_4451 3.jpg
    Prior to glueing it in (look closely at the gap between the cap and rim)
    And finally, after gluing it in. The vinyl could have been better, but I'm happy enough with the results.
    Jim LE 1301 likes this.
  11. Feb 1, 2021 at 3:37 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Did you custom make the TRD caps? I like those.
  12. Feb 1, 2021 at 4:39 PM
    jonclark96[QUOTED] likes this.
  13. Feb 1, 2021 at 4:49 PM
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    Thanks!
    Are the TDR caps smooth or is the lettering raised? Did you put anything over top the stickers?
  14. Feb 1, 2021 at 4:53 PM
    They are smooth. They have like a gel coating, very professional. The turn around time is about 8 weeks. It was under $15 for 4 shipped. They come from Ukraine.
  15. Feb 2, 2021 at 3:31 AM
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Do you happen to know if 83mm is the size for the limited Nightshade rims too?
  16. Feb 2, 2021 at 3:41 AM
    No, sorry.
  17. Feb 2, 2021 at 3:46 AM
    SpyderRC
    SpyderRC New Member
    All good, thanks. I'll measure when I get off work
