TRD Brake Pads.
Discussion in '2.5 Gen Tundras (2014-2021)' started by toyoboyo, Sep 27, 2019.
  1. Sep 27, 2019 at 8:31 PM
    toyoboyo
    toyoboyo [OP] New Member
    So these are available to option from the factory. Pretty cheap too. Anybody run these vs stock? What are your feelings on them?
  2. Sep 27, 2019 at 8:33 PM
    Baja1000
    Baja1000 New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    Hi hope to hear some input. My 2018 with 5k are super spongy! Im looking for any help to stop this beast a little better without breaking the bank???
  3. Sep 27, 2019 at 9:19 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I did the upgrade recently with new OEM rotors. They run in the mid 80$ each set for front and rear. There is a significant improvement. I love them. Much better stopping power IMO. The key is to follow instructions on the initial break in after installation. You run the truck at 60+ MPH and do a hard stop (no locking) just before the ABS kicks in, release completely at 5+ MpH and repeat about 9-10 times (as I recall) to break them in. More or less heat treat them, otherwise the material will stick to the rotors and need to be cleaned and repeated. My installer worked on race cars, so I had him do it. They have worked flawlessly since. Instructions come with the pads.
  4. Sep 27, 2019 at 9:21 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I didn’t like the feel of what I had either and this corrected it.
    Badger Co-Op, cjmay13 and HulkSmurf14 like this.
  5. Sep 28, 2019 at 1:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do they last longer? Or at least last the same as OEM?
  6. Sep 28, 2019 at 3:59 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I heard the same or better. IF you break them in properly.
    I read a post last week about someone who had installed these pads and quickly thought his rotors were warped. what I think happened is the pads were not broken in and left material on the rotors. When you don’t, the pad is initially sticky when heated. and if you come to a complete stop and hold the brake, some material sticks to the rotors. You have to clean the rotors and do the proper procedure. I think the pedal movement could have been from pad residue and not a warped rotor.
    HulkSmurf14[QUOTED] likes this.
  7. Sep 28, 2019 at 4:00 PM
    toyoboyo
    So are these properly bedded if you spec it from the factory?
  8. Sep 28, 2019 at 4:06 PM
    HulkSmurf14
    2014 Tundra Limited
    Just like the engine, probably not...baby it until you stretch it out.
  9. Sep 28, 2019 at 9:38 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    They don’t come seasoned. They come with detailed instructions. And a bit of a warning about Choosing your spot to break them in. You basically have to get the rotors And pads HOT without coming to a complete stop and releasing the pedal while it’s still rolling so they don’t stick. It’s race car style breaking in the pads. Hard breaking from 60-65 mph down to 5-10 and repeat immediately 10 times. My driver went 11 for good measure. The rotors were blue and you could hear the crackling when he got back. Then you let it sit until they cool down and then good to go. They are hardened. I live in the city. He did it on an extended two lane off ramp with a turnaround. He said he got a few looks.
    Black Wolf and HulkSmurf14 like this.
  10. Sep 29, 2019 at 9:19 AM
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Does anyone know the part number on these? Are all years the same?
  11. Sep 29, 2019 at 9:59 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    TRD performance pads on stock rotors wear faster with proper break-in compared to my my stock pads. Used 2 sets in my 2008 Tundra and installed them on my 2014 a few months ago. Well worth the performance though
    https://www.sparksparts.com/accesso...e-pads-front-oem-size-ptr09-0c111?parent=2115
    https://www.sparksparts.com/accesso...ke-pads-rear-oem-size-ptr09-0c110?parent=2115
  12. Sep 29, 2019 at 10:16 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I was thinking of getting the Z36 kit but I think I'm going to end up with Toyota rotors and the TRD pads.
    JP14 likes this.
  13. Sep 29, 2019 at 10:22 AM
    WFD473
    Northeast Illinois
    2014 MGM SR5 CM 4x4
  14. Sep 30, 2019 at 9:14 AM
    MJB_Tundra
    MJB_Tundra New Member
    Upgraded Sound System, bed cover, LED lighting, BA Muffler, Blisteins front/rear
    I added these, TRD pads and Frozen Slotted Rotors.
  15. Sep 30, 2019 at 10:04 AM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I Don’t know if it still applies, when I work for Toyota I was told that no Toyotas come with semi metallic pads. The reason is they don’t want noise or excessive dust. I haven't worked for Toyota in many years but when I did the brakes on my 2014 Tundra I could tell that the OE were not semi metallic pads.
    Aftermarket companies use semi metallic compounds in their pads to achieve the same stopping power as Toyota’s original equipment.
    WFD473 likes this.
  16. Oct 1, 2019 at 7:18 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Has anyone tried the Frozen Rotors? Wondering if they're worth the xtra cost
  17. Oct 1, 2019 at 8:33 AM
    sundance
    sundance New Member
    Just did a brake job on mine. Stock pads and Centric rotors. Couldn't be happier. Got 75,000 on my front set of factory pads. IMO, TRD pads are overkill and wear out faster. Always felt safe on the factory pads. Even towing.
    HulkSmurf14 likes this.
  18. Oct 1, 2019 at 9:00 AM
    sundance
    sundance New Member
    The pads I used looked like they had metal in them. I used the old part #. I think they have a new part #. The old one's were cheaper and I liked them any ways....
    https://www.amazon.com/Genuine-Toyota-04465-AZ120-2008-2012-2007-2017/dp/B07CZN2Z1K
    You can see the metal (copper looking flakes) in these. At least, that is what I took it for.
  19. Oct 1, 2019 at 9:14 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Bought these earlier in the year when they were doing a big sale on TRD parts/accessories. I just put them on 2 weeks ago and so far I happy with them. I followed the break in procedures based on the included instructions and have had no issues. Great stopping power, better than stock.
  20. Oct 1, 2019 at 11:57 AM
    toyoboyo
    Thanks for the input fellas!
  21. Oct 10, 2019 at 3:30 PM
    How are the Frozen rotors? I have Powerstops and they are warped.....steering wheel shakes like crazy when I apply the brakes.
  22. Oct 31, 2019 at 4:40 PM
    omgboost
    East Coast
    Have had the TRD pads front and rear for about 2 weeks now. Stopping power and bite feels good but so much dust! I feel like I'm driving a German right now
  23. Oct 31, 2019 at 6:25 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Did you “season” them with the hard braking passes? I had mine done and notice the opposite?
  24. Nov 1, 2019 at 3:50 AM
    omgboost
    East Coast
    Yes I did. Went to a place late night no traffic to do 60-10 stops and let cool for 15 minutes
  25. Nov 1, 2019 at 6:21 AM
    mambo143
    mambo143 New Member
    Phil
    Maine
    Mine is in the body shop to repair rear bumper and side panel, but I will have a look when I get it back. I replaced the rotors with pads and have been checking to see how much dust they produce and find very little. I was finding a lot esp inside the wheels before.
  26. Nov 1, 2019 at 6:44 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I tried them on my f150 10 years ago with hawk pads. They wore just as fast as the mid grade centric rotors and i always had noise issues with hawk pads. I may have been an outlier and they offered to replace pads with something else at the time. I ended up pulling the rotors after 30k miles and slapped on centric premium rotors with akebono ceramic pads, been good for 7 years. I may try slotted rotors on the tundra when due but wont spend money on cryo again.
  27. Nov 1, 2019 at 7:17 AM
    omgboost
    East Coast
    I also put in new OE rotors
  28. Mar 30, 2021 at 6:26 PM
    Jeff_1974
    Jeff_1974 Cookeville, TN
    Jeff
    Tennessee
    2010 supercharged rock warrior dc
    Supercharger Bama Exhaust Bully dog tune Bed extender Roll up Bed cover Bed carpet 18” Method wheels Falken wildpeak 285 75 18 P & P rock sliders Weather tech floor mats Sdhq pre runner bumper Warn 9.5 xp synthetic winch Icon 2.5” lift Iron cross rear bumper RCI al skids Trd brake pads Trd front sway bar Deaver u748 leaf springs Marathon seat covers
    Just got some , and did the break in.
    Pads clicking hot.
    Not sure how long I need to wait to continue driving?
    Method wheels hot also.
  29. Mar 30, 2021 at 6:30 PM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Wow, I've honestly never thought of breaking in my new pads like that. I do that all the time on my bikes! :frusty:
