Travel Trailer
Discussion in 'Towing & Hauling' started by scott.swanson, May 31, 2019.
  1. Jun 3, 2019 at 4:03 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    I don't think it will vary much, if you look at the size trailers everyone's been posting the small trailers are netting the same mpg as the bigger ones. I think the main issue is the aero of the camper and that's what determines the mpg.
  2. Jun 17, 2019 at 3:30 PM
    scott.swanson
    scott.swanson [OP] New Member
    Scott
    14 Tundra Crew Max SR5 4x4
    Update....borrowed a 4500 lbs travel trailer. 30ft with bunkhouse. Gas mileage was 9.2 mpg, so about 1mpg better than the last one we used, which was about 7000 lbs. MPG's weren't a huge difference, but it sure was a bunch smoother!
    TacoWuzzaTurd likes this.
  3. Jun 17, 2019 at 4:54 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    I got 14mpg when towing our camper but it was only a 15ft Aliner pop up A frame weighing about 1900 lbs. Didn’t even feel like anything was back there.
    Hbjeff and TacoWuzzaTurd like this.
  4. Jun 17, 2019 at 7:52 PM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    That's a super light 30'er. My 24' is 5.5k. Just towed about 5-6 hours to Indiana, close to Illinois and got 7.7ish (used refuel to check dash calculations and came out within 2 tenths). Wind was brutal. Glad it was a smooth tow for ya!
  5. Jun 17, 2019 at 9:14 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    they at least get to use that non-road use, pink-dyed diesel that’s waaay cheaper than normal diesel. Fire departments up there in noco use it too. Gotta ease the pain of the job
  6. Jun 17, 2019 at 9:48 PM
    It's definitely cheaper, but after delivery charges and buying a large fuel tank, .38 per gallon just doesn’t seem worth it.
    Jrharvey02[QUOTED] likes this.
  7. Jun 18, 2019 at 3:33 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I towed 5000 lb bay boat 300 miles of mostly IH with Tacoma and got 9 with regular and almost 10 with 93. I get the same with Tundra. I have not tried premium because I never get the tank low enough.
  8. Jun 18, 2019 at 9:45 AM
    offsetplayer2
    offsetplayer2 New Member
    Woods and Fields, NC
    2018 Inferno CM 4WD
    About 8-9 here towing a 25ft weighing in around 5k.
    Where I live we have farmers all around us. Not uncommon to see the tractor itself pulled up next to the off road tank. Also not uncommon to see it showing 200 gallons was just filled out of it either.
  9. Jun 18, 2019 at 8:07 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Not to mention the ticket if highway patrol decides to dip your tank!
  10. Jun 18, 2019 at 8:23 PM
    Cfincke
    San Antonio
    I average 8mpg towing a 26BH trailer. Normally going 65-70mph on the highway with it locked in 4th gear
    1794x4 and ColoradoTJ like this.
  11. Jun 18, 2019 at 10:05 PM
    We hardly ever get tested in CO...if ever.
    On the flip side, I do know “someone” that was borrowing diesel fuel from the oil rig sites in ND and bringing it back to CO. That “someone” was selling it for 2.00 per gallon when diesel was close to 4.50.
    Tempting, but he was caught running non taxed fuel in the Midwest. The fines were astronomical.
    Personally, not worth the risk.
    JH5370[QUOTED] likes this.
  12. Jun 19, 2019 at 7:46 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    Agreed. I have only known one guy that was tested. It was by Idaho State Patrol after the trooper noticed a slip tank in the bed of the truck. That being said I did know a few farmer's kids in high school that got away with running it exclusively for years... I am with you. Not worth the risk.
    2manytoys and ColoradoTJ[QUOTED] like this.
  13. Jun 19, 2019 at 9:01 AM
    Fastestcolor
    Fastestcolor New Member
    Blue Ribbon Limited CM
    The MPGs and tank issues seem to be a real issue for the tundra. I didn’t even look at domestic half tons as I’m very Japanese car loyal. What are the domestic trucks getting while towing similar loads. Stopping every 150miles is a pain in the rear enough to think about a different truck
  14. Jun 19, 2019 at 9:09 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    If you get the 38 gallon tank you'll be better off. If you're towing frequently (6000lbs+ more than once a month?) A diesel domestic would likely be the better option.
  15. Jun 19, 2019 at 9:37 AM
    Fastestcolor
    I have a 2015 so the 38 wasn’t an option and putting one in isn’t cheap. It’s also not even 38 usable just like the crappy 26 isn’t 26 usable.
    What kind of mpgs are the domestic gas trucks getting when towing and what size tanks. This gas tank and mpg issue makes the tundra good for nothing more than looking good as a grocery getter which is my primary use but even around town you’re at the gas station every few days, geez
    whiskeyjack and ColoradoTJ like this.
  16. Jun 19, 2019 at 9:45 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Cheapest way to make your tundra the 38gal model 5453C564-F8F8-46B0-B2F9-045EDED1FBAE.jpg
  17. Jun 19, 2019 at 9:49 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    You just gotta look for the positive ! After 2 hours of driving, I’m ready to take a piss !! Might as well get gas to !
  18. Jun 19, 2019 at 11:33 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Weighs around 3100 loaded up with gear. I'm getting around 10.5 to 12 just cruising at 60-65. Up and down the MT Mountains is what kills me, I'm usually down to about 50ish mph I don't ever push it to hard if I don't have to. Last year bringing home mine and my Buddies elk added another 700-900ish lbs and that made a difference. Dropped down to 7.5 to 9 with a good head win .
  19. Jun 19, 2019 at 11:52 AM
    #49
    Here are my experiences with other trucks:
    Ford EB 7-9 mpg, and that was on premium fuel. Pulls hard. 23 gallon tank. So less than your Tundra. But hey, got to have high capacity numbers right?
    GM- 5.3L is a good motor, but nonetheless a small motor. Good fuel economy empty, but towing is 8-10 mpg in the slow lane. 26 gallon tank, unless you want a regular cab, long box. Then it’s 34 gallons. All 3/4 and 1 ton GMs regardless of configuration have the 36 gallon tank.
    6.2L will not get you any better fuel economy, but you will be able to tow more and maintain speed on grades. Premium fuel.
    Ram- 26 gallon tank. Similar fuel economy with gasoline motors. The Hemi with the 8 speed and 3.91 gears does pretty good power wise. Towing was 8.5 mpg.
    Here’s my take on this:
    You’re towing with a 1/2 ton gasoline powered truck. Are these trucks designed to tow day in, day out? I would say the Tundra, F150 5.0/3.5 are capable of doing so.
    When towing with a 1/2 ton, and only getting 6-10 mpg while moving 6-8k lbs, I wouldn’t complain. Yes, a diesel will get you better numbers for that specific weight, but then why get a diesel?
    Now stepping up to 8-14k lbs, a diesel will get be a bit better on the fuel economy, but not huge leaps and bounds.
    This is probably the toughest towing I had with a TT and a diesel. High winds and a new (not broke in diesel) motor. Towing 8500 lbs at rated speed when safely able to (which wasn’t often)
    Normally, if I tow 9k lbs, 65-75 mph in mountain terrain, I do 11.5-13 mph. I can go 400+ miles with a 36 gallon tank depending on conditions. Empty, lol, I have done 680+ miles to a tank.
    Yota303, whiskeyjack, WFD473 and 3 others like this.
  20. Jun 19, 2019 at 12:36 PM
    #50
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    @ColoradoTJ What app are you using to track your MPGs?
  21. Jun 19, 2019 at 12:38 PM
    #51
    Fuelly.
  22. Jun 19, 2019 at 12:39 PM
    #52
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    :thumbsup:
  23. Jun 19, 2019 at 12:41 PM
    #53
    TacoWuzzaTurd
    Scottsdale AZ
    Excellent comprehensive reply. Edit: but what's up with that August 21 fill up?:eek2:
  24. Jun 19, 2019 at 12:50 PM
    #54
    I filled up twice that day and just added it up the fuel used.
    TacoWuzzaTurd[QUOTED] likes this.
  25. Jun 19, 2019 at 1:07 PM
    #55
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My dad always says his 1974 chevy One ton crew cab 454 got 8mpg “empty, towing, tailwind, headwind”. Didnt matter.
    So we should look at it as we get are getting extra mpg when not towing :p
    Yota303, WFD473 and ColoradoTJ like this.
  26. Jun 19, 2019 at 1:22 PM
    #56
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    With my Aliner Classic with dormers, dry at 2000 lbs, I get 14.5 to 15.5 on pavement with a few cities slowing tings down. Driving on gravel roads, 4 wheel drive doing max of 20 mph, I get about 9-10 mpg. 86B0DD7B-6F82-4C3A-AFFC-1843B548B74C.jpg
    JH5370 likes this.
  27. Jun 19, 2019 at 1:44 PM
    #57
    Fastestcolor
    Thanks for the great reply. These tanks should be all useable fuel
  28. Jun 19, 2019 at 2:06 PM
    #58
    Prison rooster
    Prison rooster New Member
    Bobby
    Tn
    2018 Tundra TRD SR5
    I average some were around 8.3. My trailer is only 17 foot at 3200 dry weight. And fully load with gear and water around 4100 I'm guessing. I have a Coachman Viking with bunks in back. Resized_Snapchat-482012705.jpg
    SuperSilverTundra and texasrho83 like this.
  29. Jul 18, 2019 at 3:04 PM
    #59
    Red Dragon
    Red Dragon New Member
    Pocatello, Idaho
    2015 Barcelona Red Limited TRD
    Just went on a 5,000 plus mile trip towing our 29 ft. Jayco. We averaged 8.98 mpg (calculated on Fuelly app). MPG varied from as low as 6.6 to as high as 11.5, traveling at 65 mph.
  30. Jul 18, 2019 at 8:31 PM
    #60
    TacoWuzzaTurd
    Scottsdale AZ
    Yeah I started looking at diesels this week. I think I'm a year out from an upgrade to an HD. I cant do the 8mpg engine screaming up hill much longer.
