Travel Trailer Newbie Questions
Discussion in 'Towing & Hauling' started by CaptCraig, Jun 6, 2021.
  1. Jun 10, 2021 at 4:09 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    If your transmission temperature light comes on, you will spend more than that getting the fluid changed. Its one of the items that is needed when running such a large trailer with a Tundra.
    CaptCraig[QUOTED][OP] likes this.
  2. Jun 11, 2021 at 1:43 PM
    CaptCraig
    CaptCraig [OP] New Member
    Craig
    2021 Tundra CrewMax 4x4
    What should normal temps look like without a cooler?
  3. Jun 11, 2021 at 6:20 PM
    A-A-Ron
    Aaron
    Seattle
    My 2016 had the factory cooler, the trans temp would get to a little over 240F on the worst long hills. That was staying in S4 with tow/haul on, would’ve been worse if in D. Personally I would want to avoid getting to 250F+. The more shifting your transmission does the more heat it creates, S mode with a way to monitor the temps will be your friend. Keep in mind there are two sensors in the trans, want to watch both.
