Travel Trailer Mods
Discussion in 'Outdoors' started by Alloutdrs1, Jan 13, 2019.
  1. Jul 8, 2023 at 5:44 AM
    #121
    KNABORES likes this.
  2. Jul 8, 2023 at 6:58 AM
    #122
    justcuz
    justcuz 2.5 Gen Member
    WFD473 likes this.
  3. Jul 9, 2023 at 9:02 PM
    #123
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    I suggest you get the longest hose you can. I have a blackstone grill and the propane connect for the trailer is near the front but we do most of our cooking near the back of the trailer. Think mine is like 20-25 feet. Gives us options. Can’t believe I have not seen this thread. I think I may have more mods to our trailer than the truck! Ha!
  4. Jul 11, 2023 at 1:08 PM
    #124
    justcuz
    What is everyone using to support their trailer steps?
  5. Jul 11, 2023 at 1:23 PM
    #125
    Azblue
    The Dirty T ( ^_^)_且
    I made this out of a couple of 2 x 6's. Just set it under the bottom step and it provides a big landing platform and supports the trailer step.
    bflooks and bgdv1 like this.
  6. Jul 11, 2023 at 1:38 PM
    #126
    NWPirate
    Zach
    WA
    Looks like we have almost the same steps, we don't use anything and they barely move. Our trailer is a '22 so maybe they weaken over time?
  7. Jul 11, 2023 at 1:56 PM
    #127
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
  8. Jul 11, 2023 at 2:04 PM
    #128
    bflooks likes this.
  9. Jul 11, 2023 at 2:09 PM
    #129
    bflooks
    bflooks New Member
    Metrowest MA
  10. Jul 11, 2023 at 2:47 PM
    #130
    SD Surfer
    Bruce
    So Cal
    Camco Save a Step Brace https://www.amazon.com/Camco-Stabilizes-Movement-Protects-43691/dp/B0024E6ZW2?th=1
    Screw them down short and very easy to stow.
    I've been using just the shorter one under my bottom step, but I think I'll get the longer one to put under the second step also.
    Definitely helps... with the X-Chocks tightened down real good about the only movement I feel is when somebody uses the steps, and this minimizes that.
    It can be a little tricky to get them to stay in place on uneven ground sometimes (we mostly boondock) but once you get it dialed it's good.
    justcuz[QUOTED] likes this.
  11. Aug 27, 2023 at 3:49 PM
    #131
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Stupid question…. What is this for?
    It’s on the tongue on the drivers side of many RV frames.
  12. Aug 27, 2023 at 4:09 PM
    #132
    NWPirate
    Zach
    WA
    Storage spot for your trailer plug. :thumbsup:
  13. Aug 27, 2023 at 4:10 PM
    #133
    The big red switch is a battery cutoff usually
  14. Aug 27, 2023 at 5:04 PM
    #134
    mountainpete
    Trailer plug! Yes. Makes sense.
    NWPirate[QUOTED] likes this.
  15. Aug 27, 2023 at 5:05 PM
    #135
    mountainpete
    Yes, familiar with that!
  16. Sep 23, 2023 at 3:49 PM
    #136
    NWPirate
    Zach
    WA
    Cut in and mounted a USB/volt meter. Tapped into constant power so we can charge electronics and keep an eye on the batteries while dry camping.
    Florida AF and j-utah like this.
  17. Jan 16, 2024 at 8:58 AM
    #137
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    What is the model number for that travel trailer? That is the perfect size
  18. Mar 2, 2024 at 8:58 AM
    #138
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Added some underglow lighting to the new trailer. Still need to secure the loom and do some wire management but the hard part is out of the way.
  19. Mar 5, 2024 at 7:04 PM
    #139
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Not the best pic, but...
  20. Jun 25, 2024 at 11:15 AM
    #140
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    I've lived these horror stories... had an in-law incorrectly wire up our 30amp shore power outlet. Fried the power convertor and the fridge circuit board.
    j-utah likes this.
  21. Jun 25, 2024 at 11:28 AM
    #141
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    ouch
  22. Oct 31, 2024 at 8:05 AM
    #142
    NWPirate
    Zach
    WA
    Solar noob here.. Is this solar prep on the roof typically wired into the batteries already?
  23. Oct 31, 2024 at 8:26 AM
    #143
    NWPirate
    Zach
    WA
    j-utah likes this.
  24. Oct 31, 2024 at 8:28 AM
    #144
    NWPirate
    Zach
    WA
    j-utah likes this.
  25. Apr 18, 2025 at 8:40 AM
    #145
    SD Surfer
    Bruce
    So Cal
    And campground power pedestals are notorious for being jacked up!
    People don't turn the breaker off when connecting/disconnecting so the arcs burn up the receptacles, making for loose connections which just makes it worse.
    30A gets used the most so it's usually in the worst shape, I carry a 50A to 30A dogbone and will sometimes use the 50 if the 30's hammered.
    They're also often poorly maintained by the campground handy guy rather than an actual electrician.
    Dirty power and undervoltage can be just as damaging as spikes, so I sprung for the full EMS unit rather than just a surge protector. Good peace of mind.
    Not cheap, but cheaper than a bunch of fried electronics. Plug the EMS into the pedestal and it analyzes everything, and won't let power through to my stuff until it confirms good power.
    Features:
    • Previous Error Code (PE)
    • A/C Frequency Protection
    • Time Delay (136 seconds)
    • Rugged Pull Handle
    • Built-in Scrolling Digital Display
    • Weather Resistant
    • Designed for Outdoor Use
    • Lifetime Warranty (excludes All Weather Shield Assembly).
    • Over/Under Voltage Protection
    • Open Ground, Open Neutral & Reverse Polarity Protection
    • Accidental 240V Protection
    • Surge Failure Indicator
    • Current Indication
    [​IMG] [​IMG]
    Florida AF, g6t9ed, Tunrod and 2 others like this.
  26. Apr 18, 2025 at 2:40 PM
    #146
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    That’s the one I have. It was expensive. But like you said, it gives peace of mind.
  27. Apr 19, 2025 at 10:01 AM
    #147
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    RV/Camper Roof Lap Sealant Non-Leveling, Non-Sag, by Dicor. I bought the wrong color and can't return. Prefer if you bought all 3 or 6.
    (3) black - SOLD.
    (3) gray - Available.
    Condition: New
    Price: $5.00 per tube + shipping.
  28. Apr 21, 2025 at 7:09 AM
    #148
    Florida AF
    Logan
    North Florida
    this x100!! I bought two 50 to 30's just in case and have done the same... as a matter of fact, I am doing it right now as the site I am on is so worn out the 30amp plug fell out in my hand... so I always use the surge protector and will step down more often than not.
    SD Surfer[QUOTED] likes this.
  29. Apr 21, 2025 at 7:15 AM
    #149
    Florida AF
    Logan
    North Florida
    As i sit at my dinette waiting for answers from work... here is what I can think of so far..
    - I have the typical blue hose charcoal filter, but want to and recommend the higher quality stand ones. Most importantly, the self service ones. Think whole home filter... I want to stop buying/packing water regardless of my on grid destination.
    - strongly recommend a surge protector. Mine has shown me two faulty sites so far on 30amp hookups, so I also recommend:
    - 50 to 30 step down/dog bone.
    - I bought and stickered a bucket to cover my jack controls...
    - I have the fold down ladder for entry and highly recommend kids shoes on the feet for those who do, it brings in less sand.
    - stick to wall towel hangers, paper towel rack, and TP holder. Eventually I will do something with the shower as well.
    - totes for storage in pass through gunnel. Also a tool bag for all the setup/tear down bits and level.
    - Multiple hoses and extension cords. I havent found a way to store them i love yet, but working on that.
    - I havent done it yet, but I will be doing a starlink pass through here before to long.
  30. May 8, 2025 at 5:38 PM
    #150
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I need @memario1214 to come up with a harness that let's me move the BD hitch light to the trailer receiver when I'm towing... maybe even throw a set of Squadrons up top :D:thumbsup:
    Running out room for stickers after some recent additions:
    g6t9ed, NWPirate and Cpl_Punishment like this.
