Travel Trailer Mods
Discussion in 'Outdoors' started by Alloutdrs1, Jan 13, 2019.
  1. Jan 13, 2019 at 2:56 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I’m currently in the process of installing this wrap I designed.
    BDD005A9-BC95-44B1-A31F-FA5E14CD33EB.jpg 7BC40C7C-E66E-42D2-86B7-A5773DCA6115.jpg
  2. Jan 13, 2019 at 3:46 PM
    twistedcricket
    twistedcricket New Member
    Paul
    Omahell, NE
    2014 SR5
    TRD rear sway bar, power fold tow mirrors, Firestone airbags, LED OEM fogs
    The *only* issue I have with electric jacks is that you're screwed if your battery dies. So, just don't let your battery die :)
    Otherwise, yes, get one. They save time/effort.
    Notachickmagnet likes this.
  3. Jan 13, 2019 at 3:50 PM
    twistedcricket
    Paul
    Omahell, NE
    2014 SR5
    If you're plugged in to shore power;
    Broan heater
    If you're not, then yes have a spare propane tank. I carry a second in the bed of the truck and swap out.
  4. Jan 13, 2019 at 3:56 PM
    Azblue
    The Dirty T ( ^_^)_且
    Not really, they come with a manual handle. If the battery dies just pop a rubber cover off and crank away.
  5. Jan 13, 2019 at 3:57 PM
    Hell, I bring a couple of these even in dispersed camping. I learned a hard lesson in northern NM when my furnace wouldn't start one frosty night. Inside the camper was 36*F in the morning due to no heat. We had a generator, just no little heaters. The next town that had a Walmart, two were purchased. Of course, this hasn't happened again since.
  6. Jan 13, 2019 at 3:58 PM
    Alloutdrs1
    Alloutdrs1 [OP] New Member
    Andrew
    Virginia Beach, VA
    Its the Taillight/aux terminals...I actually just did this mod last night and what I did was buy a 7way vehice side connector and jumped it and I will mount to the tongue. Then I have a place to store the 7way when unplugged out of the weather and can turn on the lights at night if it want.
    Thanks!! We are really excited, I looked for awhile and just really liked the apex nano. The floorplan we found works great for us so we went for it.
    Never thought about this, but is a great idea.
    @TruckyTruck I like your campers wheels and the lights you added around to illuminate the ground around the camper.
    @Azblue those levelers look very nice, I will have to look into these!
    Good idea on the baby wipe dispenser, I have been looking into solar as some places we go don't have shore power.
    Lots of great ideas in this thread, thanks for all the input guys!
  7. Jan 13, 2019 at 4:00 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I like this better then the simple battery charge display mine has and its pretty inexpensive.
  8. Jan 13, 2019 at 4:03 PM
    Azblue
    We went camping during the great Arizona blizzard of 2019 https://tucson.com/news/local/inche...cle_ece26752-0e96-11e9-a812-dbf00b96977b.html
    We had plug in electric and brought a cheap $20 space heater. Surprisingly the furnace hardly kicked on even in mid 20's weather. Very handy.
  9. Jan 13, 2019 at 4:07 PM
    Exactly!!
    We do more remote camping (well, as remote as one can get with 33' behind them), and if its cold out, and changing the batteries, those heaters are on to save propane. We have two large tanks though.
  10. Jan 13, 2019 at 4:08 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Yeah I had a small utility space heater for the pop up since I didn't have a heater in it and I planned on transferring that to help supplement the propane camper heat so maybe it will use less propane. If that little heater could keep a pop up comfortable it should have no problem doing so in the travel trailer.
  11. Jan 13, 2019 at 4:12 PM
    Azblue
    Yep, I was surprised. Mid 20's is FUCKING FREEZING to those of us here in the desert southwest but that cheap, 15 year old space heater kept our 24' dual slide trailer warm, even in the bedroom with the doors closed.
  12. Jan 13, 2019 at 4:13 PM
    Both of these are great suggestions. I don't have the automatic transfer valve for the propane, but the factory pigtails for the hose connections are garbage, even on high end campers. I found both of mine in failure after a couple years, and they had never been in sunlight for more than a bottle swap.
    The electrical shutoff is a must. I thought most campers (if not all) came with them. I must have been assuming again....
  13. Jan 13, 2019 at 4:14 PM
    Mnorris1206
    08 tundra
    Here is a topic I will say I have had my camper for 3 yrs and just this last fall had an issue with our heater our funace is not easy to remove. Long story short I should have bought the screens to put on the exhaust and intake because mud dobbers got in amd messed it air intake up. Cleaned it all up it works fine now but not fun . so get you some screens. For the furnace.
  14. Jan 13, 2019 at 4:15 PM
    Another good one!!
  15. Jan 13, 2019 at 4:16 PM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Do they sell screens you install or something people fab up? I have these dobbers in my area, always building nest around the house so this is a great suggestion.
  16. Jan 13, 2019 at 4:18 PM
    Buy a small tool kit, hammer, nails/wood screws, small saw, some 1x1 wood for backing up doors when they come loose. put this all inside a compartment somewhere. You will need them eventually.
  17. Jan 13, 2019 at 4:19 PM
    Any RV place will have them for about 9.00.
  18. Jan 13, 2019 at 4:21 PM
    Mnorris1206
    08 tundra
    Here ya go.
  19. Jan 13, 2019 at 4:23 PM
    #49
    Mnorris1206
    08 tundra
    Here is another thing so simple but so nice to have. I love closing the door now when before it was a pain lol
  20. Jan 13, 2019 at 4:27 PM
    #50
    Azblue
  21. Jan 13, 2019 at 4:28 PM
    #51
  22. Jan 13, 2019 at 4:30 PM
    #52
    I get to take my RV in tomorrow for some maintenance/recall warranty work. That should be fun in the snow! Doubt I can get it out, but I will give it a hell of a shot.
    Then up for sale!
    Notachickmagnet and Azblue like this.
  23. Jan 13, 2019 at 4:31 PM
    #53
    Azblue
    Why you selling?
  24. Jan 13, 2019 at 4:35 PM
    #54
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Notachickmagnet and Mnorris1206 like this.
  25. Jan 13, 2019 at 4:36 PM
    #55
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Thanks! I agree its a little awkward shutting the screen.
    Bug screens, screen door handle in my cart!
    Good idea! I have a cordless impact so I will buy an extra socket of the correct size to keep in the camper for this task!
  26. Jan 13, 2019 at 4:47 PM
    #56
    We might go with a 32-36' gooseneck enclosed trailer. Then every toy is inside, locked, and the hotel is a nicer option. I can have hammocks inside when doing more remote camping, have a port-a-potty, and outside shower.
    With the rising costs of camping sites (most are 4-500.00 per week), the cost of RV's, insurance has started getting stupid in my area. Every carrier wanted 490-900.00 per year for an item used a few times. With the new tax code I will not be able to write off the camper as a second home anymore. So kinda pointless for me.
    Something like this:
    9-12,000.00 for this 34'
  27. Jan 13, 2019 at 4:48 PM
    #57
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Great thread! Just got back today from a little winter camping trip. Found out I need to come up with a tool to scrape snow/ice build up on top of the slide, was able to get it done with a broom but time consuming. Will be looking into a slide topper/awning not completely sure that'll help with wind driven snow tho.20190113_193325.jpg
  28. Jan 13, 2019 at 4:52 PM
    #58
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
  29. Jan 13, 2019 at 5:05 PM
    #59
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I can't take credit for the lights. The camper came that way. They are handy though!
  30. Jan 13, 2019 at 5:05 PM
    #60
    Mnorris1206
    08 tundra
    I dont know how I had forgot about the best investment for me so far .I like a good night sleep .
