Transmission
Discussion in '2.5 Gen Tundras (2014-2021)' started by Andrew19, Jul 5, 2019.
  1. Jul 5, 2019 at 3:43 AM
    Andrew19
    Andrew19 [OP] New Member
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    Has anybody experienced any issues with their transmission? Longer then usual to go into drive. Clanks or clunks going into drive. Hard downshifting, especially when coasting and then getting back into it. I would like to hear from you. What did you find out and did it ever lead to anything worse. Thanks in advance.
  2. Jul 5, 2019 at 4:37 PM
    Rider0120
    Rider0120 New Member
    Bucks County, Pa
    2018 White double cab SR 4x4 long bed
    Ranch Hand full replacement bumper
    My trans did a weird clunk after coasting and I would accelerate. Did it mainly between 35-45 when the trans was warmed up and in heavy traffic on i95. They did the PCS update and oddly enough the trans started shifting better in traffic.
  3. Jul 5, 2019 at 7:34 PM
    Andrew19
    Andrew
    Baytown TX
    2019 TRD PRO
    Stock
    That is odd thanks for the info thought they might have had that worked out for 2019
  4. Dec 31, 2020 at 10:11 AM
    2018Tundra
    2018Tundra New Member
    VA
    2021 Tundra Platinum
    Did you ever find out what was going on? Mine started doing exactly that. Very hard shift from R to D and clanks when coasting down around 30-40mph.
    okccj likes this.
  5. Dec 31, 2020 at 10:53 AM
    Rider0120
    Bucks County, Pa
    Mine still does the clunking in the right scenario is not broken so the dealership will not take care of it all you can do is make a report and documented that way in case and transmission does fail you can have proof that you brought it in prior to it failing and hopefully it would be taken care of, when it is out of warranty
    2018Tundra likes this.
  6. Dec 31, 2020 at 11:04 AM
    2018Tundra
    VA
    I took it in last week but all they did was reset the adaptive shift points. It still does the clunking but at least now I have it documented in the service history. I'm surprised that a Tundra at 23k miles would start doing this.
  7. Dec 31, 2020 at 11:22 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    The only clunking I've had is going from Park to Drive when cold. Doesn't matter if I let the truck warm up for 10 minutes or if I jump in start it up and go. Only does it cold starts though. No other issues with general shifting in gears either way. Mines a 2020
  8. Dec 31, 2020 at 11:36 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    My 2014 would shift a bit weird when cold. Very firm shifting through the gears. My 2020 shifts smooth all of the time.
  9. Dec 31, 2020 at 3:15 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    When leaving work, feels like my transmission slips some for the first couple times I get one the gas, then does not do it again. Weird thing is when I leave home it does not do that... only difference is that I back out of garage at home no pull straight out at work...
    Other than that, trans operates great.
  10. Jan 1, 2021 at 12:58 PM
    aaronoto
    aaronoto New Member
    I get the hard downshift when coasting around 30-40mph and then getting back on the gas. Doesn't happen every time and hard to replicate so I haven't bothered taking to dealer.
  11. Jan 1, 2021 at 1:26 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Mine does this everyday. I just learned to feather the peddle and listen/feel when to get back on it. Maybe I should at least bring it to their attention. Done it since I bought her
  12. Jan 1, 2021 at 1:38 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Have you tried greasing the U joints? It helped a lot to smooth out the shifting for me.
  13. Jan 1, 2021 at 1:40 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    I can’t find any on my driveshaft. Maybe cause I’m a 2wd??
  14. Jan 1, 2021 at 1:50 PM
    2018Tundra
    VA
    Very hard to replicate at the dealership! It never happens when you need it to.
    Melikeymy beer likes this.
  15. Jan 1, 2021 at 1:51 PM
    2018Tundra
    VA
    You can’t really make the techs do it at the dealership. They have to follow their own rule book.
  16. Jan 1, 2021 at 5:16 PM
    Tundyfundy
    Bay Area, CA
    I have them grease my truck every other service. My propeller shaft and UCAs. It calls for it in the maintanenece guide.
    2018Tundra[QUOTED] likes this.
  17. Jan 4, 2021 at 2:48 AM
    Tundrafan23
    Tundrafan23 New Member
    Is your garage heated at home? That is the difference, these trannies operate far smoother when at operating temp.
  18. Jan 4, 2021 at 5:09 PM
    RickPlatinum2020
    Rick
    Eastern PA
    Nice thought about garage, no, it is not heated... it has done this since buying it in July. Temperature outside hotter than garage and still does it... very consistent, does not slip at all after that first turn from parking lot.
  19. Mar 29, 2021 at 6:41 AM
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    I park outside and definitely notice my transmission delays shifts and the power is not there when I first start it from being cold. A little bit of a whine sound as well from the truck until it gets up to temp. Had this on other cars in the past so I consider it pretty normal. I just take it easy for a a couple miles until the temp gauge starts showing some life.
  20. Mar 29, 2021 at 8:31 AM
    2018Tundra
    VA
    Good to know!
