Transmission Temperatures
Discussion in '2.5 Gen Tundras (2014-2021)' started by Greg Marmalard, Mar 28, 2019.
  1. Oct 23, 2019 at 1:40 PM
    #61
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I think it's more likely that the bean counters were able to determine that the transmission won't fail even when towing 10k lbs until after the warranty is up and thus it won't cost them anything (other than customer goodwill, maybe). But by then they'll have a new Tundra and will be able to say all the issues of the 2019 have been resolved so don't buy from someone else.
  2. Oct 23, 2019 at 3:09 PM
    #62
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I like knowing what's going on but I'll admit to being a data hog.
    georgie[QUOTED] likes this.
  3. Oct 23, 2019 at 6:05 PM
    #63
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    my trans was touching 217 driving around town. And its 53 degrees outside.
    k0diak8o8 likes this.
  4. Oct 24, 2019 at 5:08 AM
    #64
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    I found the codes and reprogrammed the Ultra Gauge
    Also. I dont want to rely on my phone when driving long distance
    So I will stick with the ultra gauge
    To ea h there own. Everyone should use whT they like. And are comfortable with
    Saltyhero13 likes this.
  5. Oct 24, 2019 at 8:00 AM
    #65
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    I have been monitoring my 2010 around tow, long trips, highway, ...etc.
    monitoring with my Bully Dog platinum....so wherever that pulls from...not sure...but I have NEVER gone above 199 on that gauge.
    most of the time I am around 190 ish...185-195...with sometimes 199...197...etc.
    k0diak8o8 and Cpl_Punishment like this.
  6. Oct 24, 2019 at 8:10 AM
    #66
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Marmalard! I did exactly as you suggested. I have an ‘18 and my brother in law has a ‘19. When I started reading over these trans/temp threads I got very curious about what kinds of temps I am running, as my 18 DOES have the external cooler. I now have the OBD app and and device to randomly check my temps (Thank you for the recommendation!) I can report that my temp sits around 185 once everything is warmed up. Heavy acceleration results in temps increasing to about 196, and then I believe the thermostat opens up and cools it back down to 185. Haven’t towed anything yet and probably won’t through the winter.
  7. Oct 24, 2019 at 8:17 AM
    #67
    timsp8
    NY
    I am the same in my 18. 180s to 190s using BD tuner. Sometimes up to 200-205 if I’m driving fast. My upper ATF hose is hot at 194 so my thermostat opens somewhere around there.
    k0diak8o8 and panicman like this.
  8. Oct 24, 2019 at 8:35 AM
    #68
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Has anyone installed a cooler on there 19 or 20 tundra yet?
    Badger Co-Op and Gaspssr like this.
  9. Oct 27, 2019 at 10:28 AM
    #69
    Blue Thunder
    Washington
    So this is an older thread...has anyone reported any issues?
    Also, I read this entire thread and didn’t see any temperature ranges and max temps for the Tundra as reported by Toyota. Does anyone have those? Maybe they’re buried in another thread...but I’d like to understand the real numbers.
    I saw the graph that someone posted earlier in this thread. It looks suspiciously like one that floats around the internet from a company selling aftermarket coolers and doesn’t have any references. That chart (if it’s the same) was posted multiple times in the Ford forums I used to frequent as gospel. However, the forum had Ford engineers answering questions for a while and they confirmed their transmission temps and fluid limits are completely different. Today’s synthetics are completely different than whatever fluid was used to formulate that chart years ago.
  10. Oct 27, 2019 at 11:48 AM
    #70
    That may be so, ATF can probably handle better heat tolerances, however, there have been reports of folks getting high transmission temp warning towing half the trucks rated towing capacity in their 2019 Tundra.
  11. Oct 27, 2019 at 2:05 PM
    #71
    panicman
    Eric
    That’s my experience too- at 195 or so, there is a sudden temp drop.it cycles between 185-195 unless I accelerate hard. Still playing with it to see how it acts. I am using OBD fusion and OBD 2 scanner, which works great. Great suggestion by @Greg Marmalard.
  12. Oct 28, 2019 at 6:17 PM
    #72
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Not trying to stir the pot on this issue further. Anyone have bigger tires on their 19-20 yet and run the temps? I wonder if the new ones will see more of a cooking effect from big tires
  13. Oct 29, 2019 at 12:01 AM
    #73
    1engineer
    1engineer New Member
    Appalachians
    2019 Tundra Limited TRD Off Road.
    Really? I absolutely don't worry about it. I have no monitoring. I have towed 9K several hundred miles. It still shifts fine. I trust the engineers because in this application, they know more than me.
    tttrdpro likes this.
  14. Oct 29, 2019 at 5:46 AM
    #74
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    But you've had your truck for less than ~15 months. How can you say it will last 15 or 20 years and 500,000 or a million miles?
  15. Oct 29, 2019 at 6:12 AM
    #75
    clownkillerloaf
    clownkillerloaf New Member
    Logan
    '21 SR 5.7
    ahh, but isnt that the gamble we all take w/ a complex, long-term piece of machinery?
    Trans temps for my '14 (4.6 w/ no tow/haul mode, no extra coolers, etc.) are virtually unaffected towing vs not towing. Keeping truck in S4, temps are staying constant 190-200°F (in Louisiana heat) towing my boat, which is probly 2750-3000 loaded. Yes, this trans runs a little warmer than I'm used to, but the truck keeps temps pretty consistent. I'll service everything per the manual and see how long this thing can last! Definitely my favorite truck I've had so far, and I'm curious to see the kind of miles we'll get before anything major happens.
    Badger Co-Op likes this.
  16. Oct 29, 2019 at 9:37 AM
    #76
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    The guys I've talked to who run their GMs for a long time like to target below 185F but 190-200 doesn't concern me too much as it sounds like that's where most 2007-2018 Tundras run. However, the 2019-2020s seem to run in the 215-230 or 240 range and it's the impact of that change on long term reliability that I think is unknown at this time (and will remain that way for several years).
    jetfishn, stuckinohio and ryanwgregg like this.
  17. Oct 29, 2019 at 8:48 PM
    #77
    1engineer
    Appalachians
    I cannot, and neither can the guy who monitors every temp including bearings, changes his oil every 500 miles, waxes it every day and cleans his injectors twice on Sunday.
    There is an expectation from consumers and it differs depending on vehicle. Most Toyota truck owners expect 250K+ with OEM listed maintenance. Most will get that, as evidenced by history. Truthfully the guy who takes his truck to the dealer for service and never cares about anything but adding gas will end up getting the same longevity out of his truck as the paranoid guy monitoring everything and halving the service intervals.
    I personally think that most enthusiasts here just enjoy tinkering and trying to figure stuff out and that's fine. Trying to justify that their diligence will add reliability is sketchy at best as the data just cares about the miles driven, not how it was maintained.
    Now, with that said, and knowing what I know from my profession, if I wanted to drive this truck for the rest of my life (newsflash... I don't. I enjoy changing it up every now and then) it would be fairly easy to go 750K+ and beyond.
    1. On day 1 change out oil filters to dual cannister remote mounted.
    2. Sample all fluids every 10K, including diffs and transmission. Change oil 10K, change diffs at 50K, change trans fluid 100K, rinse and repeat.
    3. Change major joints every 150-200K.
    4. Change coolant, ps fluid and brake fluid every few years.
    5. Belts and hoses changed every four years.
    That would do it if you truly wanted to have a forever truck. Not me but maybe somebody else. Life is too short.
  18. Aug 31, 2020 at 9:00 PM
    #78
    Coffee*8)
    Coffee*8) New Member
    Pennsylvania
    2020 Tundra Crew Max
    + Trans cooler
    This is an older thread but wish I had found it before just purchasing a new 2020 Tundra.
    Apparently Toyota has decided that temperatures below 257 degrees are fine in their transmission. And they are most likely correct. Just goes against everything I thought I knew about trans and how temperature affects them.
    The heater/cooler cools the transmission enough to keep it around 207 while the torque converter is locked. And easily go up to 220 to 230 in third gear on hills.
    When going over a mountain temps will spike to ~255 degrees and then plummet back down to ~207 when the torque converter locks. The torque converter will lock in second and third gears when the trans temp reaches 257 degrees. As long as you are not in first gear it the trans will not overheat (go above 260).
    TTund16 and WesternFlyer like this.
  19. Sep 1, 2020 at 8:41 PM
    #79
    Jtundra81
    Jtundra81 Just a member
    Joe
    2019 cement tundra crewmax
    Were you towing ?
  20. Sep 1, 2020 at 9:17 PM
    #80
    18" TRD Off Road Wheels
    https://www.tundras.com/threads/2019-transmission-cooler-kit.60550/unread There have been several threads on this "issue" but this one presents a solution and has good info.
  21. Sep 2, 2020 at 4:52 AM
    #81
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Jtundra. Yes while towing a 5500 pound trailer with family of 5 and gear.
    Azure. Thanks for that link. Excellent information there. Going to follow that.
  22. Sep 2, 2020 at 5:11 AM
    #82
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Just throw an auxiliary cooler in it and wash your hands of any more temperature concerns. You will see transmission temps drop a solid 50 degrees.
    jetfishn likes this.
  23. Sep 2, 2020 at 11:00 PM
    #83
    TTund16
    TTund16 New Member
    Good info!
    How do you know this?
    Cpl_Punishment likes this.
  24. Sep 3, 2020 at 7:20 AM
    #84
    betotundra
    betotundra Toyota for Life
    :popcorn:
  25. Oct 1, 2020 at 8:43 PM
    #85
    Coffee*8)
    Pennsylvania
    + Trans cooler
    Info was from a post, looked for it but could not find it again. OP was talking about going over a mountain and watching his temps rise in 3rd gear, then all of a sudden out of no where they dropped when they hit 260.
    One of the replies was what looked like a transmission testing document from Toyota showing the case where tq locks in second and third and temp is over 257.
    Anyone towing with a 2019/2020 w/o a cooler should be able to reproduce.
  26. Oct 1, 2020 at 8:58 PM
    #86
    Vizsla
    Vizsla 2 = 2.5
    It’s not that simple, many options for TC lock. If you want to see any specific let me know.
    TTund16 and 19crewmaxTRD like this.
  27. Oct 1, 2020 at 9:10 PM
    #87
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Will the $1000.00 out of pocket fix a problem that hasn't been fully proven yet? Lots of good info here, but i still haven't seen a definitive answer to all the great questions asked that would lead me to believe, or make a decision one way or the other.
  28. Oct 1, 2020 at 9:12 PM
    #88
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I’d like to see specifics, I geek out on this stuff so any and all info is welcome and appreciated.
  29. Oct 1, 2020 at 9:17 PM
    #89
    Vizsla
    Vizsla 2 = 2.5
    What would you like to see? There are tables for many things on 18+
  30. Oct 1, 2020 at 9:23 PM
    #90
    19crewmaxTRD
    Seth
    Mostly interested in torque converter lock up control, when and at what percentage. I’m assuming since we have a flexible lock up converter the computer can control lockup percentage in a certain range.
