Transmission Temperatures
Discussion in 'General Tundra Discussion' started by HTGreen, Dec 9, 2015.
  1. Dec 9, 2015 at 10:45 AM
    HTGreen
    HTGreen [OP] New Member
    Halsey
    Central Virginia
    2018 SR5 TRD Tundra Quicksand
    I added a Scanguage II to my 2016 Tundra V8, but the readings are about 50 degrees warmer than my 2015 Tacoma TDR Offroad V6 with towing package. I used the same codes as the Tacoma
    Transmission Temperature 1 - pan
    TXD: 07E02182
    RXF: 046105820000
    RXD: 2808
    MTH: 00090005FFD8
    NAM: TF1
    Transmission Temperature 2 - Torque Converter output
    TXD: 07E02182
    RXF: 046105820000
    RXD: 3808
    MTH: 00090005FFD8
    NAM: TF2
    Tacoma reading level road 55 mph = 130 Degrees, Tundra same level road 55 mph = 180 degrees. Anyone have any ideas why the differences, I wouldn't think heavier truck would be the answer as most sites say that Transmission temps over 175 cause shorter fluid life, and Tundra should have a larger cooler.
    Army_of_One likes this.
  2. Jan 7, 2016 at 1:02 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Good question that i missed but i do not know the answer. @LOTSOFTOYS ?
  3. Jan 7, 2016 at 3:09 PM
    HTGreen
    Halsey
    Central Virginia
    Another question, what is the temperature range that fluid levels are checked at, the Tacoma is at a range of 115 to 130 degrees.
  4. Jan 7, 2016 at 8:07 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I'd have to look it up. And ur tacoma temp depends on year... most are actually 97 to 115 when u check. My 4.7 runs about 140 normally
  5. Apr 27, 2016 at 6:10 PM
    Ancient1
    Ancient1 New Member
    Tallahassee
    2012 rclb tundra 4x4
    20160427_140116.jpg Curious about tranny temps also. Mine goes in the low 200's often....and thats with ambient temps in mid to upper 80'. Truck is empty, except for me and not towing. Definitely warmer than Tacoma.
    Does the Ultra guage read from torque converter or pan?
    Thanks for any info
  6. Apr 27, 2016 at 6:52 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Good question. Ur second gen has 2 sensors. One in each location u mentioned.
    My first gen only has one sensor so it's easier...
    Does it get hot and cold quickly? If so it may be near the tc because it heats up fast there.... pan should take a while for temp changes I would think.
    My first gen has been to 215 while towing...
  7. Apr 27, 2016 at 6:59 PM
    Ancient1
    Ancient1 New Member
    Tallahassee
    Heats up rapidly during upshifts but more so when applying brakes and downshifting. Also jumps close to 20 degrees climbing a slight grade.
    It has the tow package and looks like the lines run through the a/c condenser
  8. Apr 27, 2016 at 7:09 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Probably lookin at tc Temps then.... how high do they get?
  9. Apr 27, 2016 at 7:14 PM
    Ancient1
    Ancient1 New Member
    Tallahassee
    Got to 210 once today....thinking I may need an auxiliary cooler for the 90 degree + summer temps, especially when towing
  10. Apr 27, 2016 at 10:47 PM
    AaronK
    AaronK New Member
    Aaron
    2002 White Tundra AC SR5 4x4
    Side note: where is the first gen's sensor? Just curious where my 02 is reading from.
  11. Apr 28, 2016 at 6:44 AM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    What are you using to read the temps? I like the layout and display.
  12. Apr 28, 2016 at 7:24 AM
    Ancient1
    Ancient1 New Member
    Tallahassee
    Ultra guage....came from a group buy a year or so ago on tacoma world. You can display up to 8 parameters/page with 7 pages. The new models are available with blue leds.
    tibadoe and LOTSOFTOYS like this.
  13. Apr 28, 2016 at 11:55 AM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Eh... maybe, I'll be honest I don't know what a typical temp on a second gen is.
    pan I believe
  14. Apr 28, 2016 at 5:39 PM
    tibadoe
    tibadoe New Member
    Joe
    Gladys
    2014 SR5 DC 4x4
    I like it - may have to pick one up. Thanks
  15. Apr 29, 2016 at 10:13 AM
    tacouser
    tacouser New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    I have the scan gauge II hooked up in my 2015 5.7. I use it mostly for when I tow my 27' travel trailer, weighs about 5500lbs.
    When not towing my trans temp stays around 195-200.
    When towing it will range between 195 on flat road to around 230 going up hill.
    I have been looking for a good fan to install in front of the trans cooler, or just put in a larger cooler.
  16. Apr 29, 2016 at 1:36 PM
    Ancient1
    Ancient1 New Member
    Tallahassee
    Installed a large stacked plate auxiliary cooler on my previous tacoma and the temps dropped 20+ degrees
  17. May 1, 2016 at 8:29 AM
    tacouser
    tacouser New Member
    Chicago
    I did the same on my 2012 Tacoma, but need to do it on my Tundra
  18. May 1, 2016 at 1:37 PM
    Ancient1
    Ancient1 New Member
    Tallahassee
    Lots of unknowns on the Tundra....topping off fluid after cooler install; existing lines appear to go in the a/c condensor, etc.
  19. Sep 28, 2016 at 5:01 AM
    Krohsis
    Krohsis New Member
    2016 Toyota Tundra SR5 CrewMax, 5.7L, Red
    The fix for high tranny temps in the gen 2 and gen 3 Tundras is to pin the trans fluid thermostat open. The same procedure used to check the fluid level. Temps dropped 30-35 degrees. All for the cost of a wire the size of a paper clip
    Ancient1 and NewImprovedRon like this.
  20. Sep 28, 2016 at 12:48 PM
    Kaerntner
    Kaerntner New Member
    2016 tundra sr5
    What ° does the thermostat open?Wonder if you pin it and it needs cooling if it'll act like taking thermostat out of radiator?
  21. Sep 28, 2016 at 6:32 PM
    Krohsis
    Krohsis New Member
    RowdyRon, yes I will try to do that in the few days. I will be under the truck putting stirrup steps on so I will take pics then.
    Kaerntner, yes pinning it open would be like pinning open the thermostat for your radiator. It takes the ability of the tranny thermostat to control temp out of the equation, so fluid flows through the cooler all the time. I'm still trying to find what temp the thermostat lifts, and haven't found that figure yet. It likely is in the service manual I have but with 12,457 pages and a crummy search feature, Im still looking. Based on what I have seen before pinning the thermostat, I believe it likely is hotter than 200*, but that is speculation on my part for now. Because the fluid will be always flowing to the cooler with the thermostat pinned is why I mentioned when outside temps get cooler, it will be important to watch your tranny temps. Having a tranny too cool can be a problem as well. With the tranny fluid heater still in place, it may not be a problem, but since most Tundra owners are oblivious how hot their transmissions are running, this is new territory we are working in, as no one has tried to fix this problem, they didn't know it exsisted. But if it does get too cool, it will take all of 30 seconds to remove the pin and the thermostat will be controlling the flow to the cooler again.
    NewImprovedRon likes this.
  22. Sep 29, 2016 at 5:48 AM
    Kaerntner
    2016 tundra sr5
    Thinking about using instant read thermometer and checking at the front and back?Just wondering
  23. Oct 6, 2016 at 6:33 AM
    Krohsis
    Krohsis New Member
    So, RowdyRon asked that I do a DIY post on pinning the transmission thermostat open, so here it is.
    This is a very simple procedure, and is the same procedure that is used to check the fluid level in the tranny. Here is two different diagrams from the Russian Service Manual I downloaded (see other post https://www.tundras.com/threads/2015-service-manual.7436/#post-111603 ) on how to pin the thermostat open to check fluid level. In one diagram the center plunger that you depress has not been depressed yet, and extends out of the nut. The other diagram the plunger is depressed in the position that allows inserting the pin to hold the thermostat open.
    To locate the thermostat, crawl under the truck on the passenger side behind the right front wheel. Once under the truck, look forward on the right side of the tranny and you will see the large round part on the side of the tranny, see picture. That round thing is the heat exchanger for warming the tranny fluid with engine coolant.
    Right above the heat exchanger is the tail end of the thermostat. It can be recognized by the hex nut with small holed in each flat of the nut, like lockwire holes. In the center of the nut is the tail of the plunger of the thermostat, that is what you depress with a screwdriver or punch. The plunger depresses very easily and the travel is only 3/8 to 1/2 of an inch. I used a wire that measured with my calipers at 1.35mm. That was a good thickness to hold the plunger in the open position without having to force the wire in. I then bent the upper end of the wire at a 90* angle and the lower side just enough to prevent the wire from slipping out.
    I haven't towed with the truck since the mod, that will happen next week. But I did go over a local pass in the truck a few days ago and the temps were down at a safe level. Prior to the mod, at 80* outside temp the tranny temp over the 7% grade at 70mph would get up to 216*. With the mod, at 82* and 70mph, the temps never exceeded 186*. And if I shifted into S4 the temps dropped lower, down to the area of 172-175* (S6 is an overdrive, as is S5 and doesn't lock up so there is always some slippage, so I have been told, I haven't confirmed this myself, but clearly S4 runs cooler under load) Driving on the level at 70mph, the tranny temps stay at about 165*, and they were 197-200* prior to the mod.
    I will post my data when I tow next week.
  24. May 16, 2017 at 12:01 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I have to move my family for a new job so I'm getting ready to pull a 10k pound enclosed car hauler (expected total weight) from Seattle to Boston with my 08 Crewmax this summer. After all of the necessary upgrades I'll put about $1200 into the truck to get ready for the drive.(Lights, air bags, sway bar, WD hitch and brake controller, but unfortunately the supercharger didn't make it on the "must have" list.) I'll save about $5k on moving after selling the trailer.
    I wanted to make sure I don't roast my transmission crossing the Casades and the Rockies so I dusted off my old heat transfer and thermodynamics textbooks from my engineering classes.
    I found something I thought all of you would be interested to know. Liquid-to-air heat exchangers (radiators, transmission coolers, etc.) only need air moving at 2 meters per second (~7mph) to reach their maximum cooling potential. If your transmission cooler is mounted behind your grill and in front of the radiator there is almost no realistic driving scenario where an electric fan would increase your cooling capacity. The only time a fan helps is if you mount the cooler where the wind from driving can't reach it or if you're driving less than 7 mph.
    I'm just going to add a B&M Supercooler in series with the factory cooler for some cheap insurance on the transmission and pull over for a break if traffic is ever moving less than 7mph. I've also got the Torque-Pro app reading transmission pan and torque converter temps through a Bluetooth dongle on the OBDII port so I can keep an eye on actual transmission oil and engine coolant temperatures. I'll log the drive data and tell you what I see when I finish the trip at the end of June.
    So far, with the truck unloaded it looks like the transmission cooling valve opens when the oil leaving the torque converter is between 200°F and 210°F depending on the engine load and driving conditions. It's obvious when the valve opens because the converter temp drops down to about 180°F in less than a minute.
    I'll be able to tell you more about how the valve functions after I finish the 3,000 mile trip fully loaded.
    Krohsis and ToyotaDreaming like this.
  25. May 16, 2017 at 5:06 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    @n2deep
    So the tranny temps are there somewhere. How can we get it to work on our readers?
  26. May 16, 2017 at 7:16 AM
    n2deep
    n2deep Pavement Princess
    Carey - what are you using to pull the trans temp? Running Torque Pro with Bluetooth dongle but when we pull the coolant temp and tranny temp they are the same. Is that correct and they should be about the same?
  27. May 16, 2017 at 7:34 AM
    careyrob
    Carey
    Massachusetts
    What reader are you using?
    I'm using the Torque Pro app and this one:
    ScanTool 426101 OBDLink MX Bluetooth: Professional OBD-II Scan Tool for Android & Windows
    https://www.amazon.com/dp/B006NZTZLQ
    Here's the pids I'm using:
    PID: 21D9
    Long Name: Transmission Pan Temp
    Short name: Trans Pan
    Min: -40
    Max: 325
    Scale factor: 1
    Unit type: °F
    Equation: ((((E*256)+F) * (7/100) – 400)/10)
    OBD Header to use: (leave blank)
    PID: 21D9
    Long Name:Transmission Converter Temp
    Short name: Torque Converter Temp
    Min: -40
    Max: 325
    Scale factor: 1
    Unit type: °F
    Equation: ((((G*256)+H) * (7/100) – 400)/10)
    deadrx7conv likes this.
  28. May 16, 2017 at 7:56 AM
    n2deep
    Let me try those PID's and compare to what I am using. Using a similar OBD2 but not sure the brand nor do I know what @osidepunker is using.
    Will report back later
  29. May 16, 2017 at 8:18 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I'm using the torque Pro app for Android and the BAFX Products 34t5 Bluetooth OBDII Scan Tool
    How do I program custom PIDs? Well, I only need to know if they work lol
  30. May 16, 2017 at 8:27 AM
    n2deep
    I gave you directions awhile back on programming custom PID's Do some research :p Asscracker
