Transmission serviceable??
Discussion in '2nd Gen Tundras (2007-2013)' started by Ronmat4X2, May 12, 2018.
  1. May 12, 2018 at 7:49 AM
    Ronmat4X2
    Ronmat4X2 [OP] New Member
    2007 4X2 TRD
    Are our 6 speed auto trans. Serviceable by us owners?
    Thanks
    Ronmat
  2. May 12, 2018 at 11:49 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    Yes, they are.
    Greg
  3. May 12, 2018 at 11:56 AM
    Ronmat4X2
    2007 4X2 TRD
    No owners manual came with my Tundra I'm in the process of getting some manuals for this puppy. I assume it has a filter also?
  4. May 12, 2018 at 12:07 PM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    It’s a pain in the ass, IMO. One of those things I go to the dealer for.
    Black Wolf likes this.
  5. May 13, 2018 at 4:49 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Don't trust a chiltons manual. Lot's of important steps missing.
    There are two filter's available. You may need to drop the pan to see which one you have.
    The pan gasket is reusable but Fel pro sells a new gasket for $20, toyota wants $49
  6. May 13, 2018 at 5:30 AM
    Ronmat4X2
    2007 4X2 TRD
    This might be a little more than what I want to do due to not having a shop work in.
    Does anyone know how much Toyota
    charges for this?
  7. May 13, 2018 at 6:17 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Full flush can be pricey at the dealer, like in the $4-500 range.
  8. May 13, 2018 at 6:25 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    The standard Toyota service is a drain and fill of the pan at 60k miles intervals; usually 4-5 quarts. This can be a DIY. Many discourage the flush, possible disturbing sediment better left alone. From this forum, "You flush a toilet, not your Transmission". lol
    Hoff likes this.
  9. May 13, 2018 at 6:31 AM
    teedubbya
    Austin TX
    Call around your local Toyota shops and ask them what the process is. A common backdoor they take is draining only 3-4 quarts of the 12 quarts. I had dealerships quoting me the same as a flush for that.
    Also keep in mind some may not recommend a flush over 160k miles.
    I had mine flushed, 12 quarts synthetic for $260. The fluid alone would have cost me that.
    The old mindset of not flushing your transmission fluid is silly and misinformation. Toyota uses a machine that doesn’t flush anything, just replaces old fluid. You change every other fluid in your truck, why wouldn’t you change your transmission fluid?
  10. May 13, 2018 at 6:33 AM
    Ronmat4X2
    2007 4X2 TRD
    Well since i have an 07 with 176,000 miles and car fax says nothing about trans service, i will be a
    non flusher. I dont have trans issue so i will let that sleeping dog stay a sleep.
    Thanks Guys
  11. May 13, 2018 at 6:37 AM
    Trooper2
    JR
    I do not think there would be any issue with a drain and fill, or a pad drop /new filter and fill. I would be looking into that......
    15whtrd likes this.
  12. May 13, 2018 at 6:40 AM
    Ronmat4X2
    2007 4X2 TRD
    Yes i will definitely do the drain and fill with filter.
    Thanks
  13. Jun 10, 2018 at 4:04 AM
    leikolee
    leikolee New Member
    I have 131k on my 07 4x4. Just did a flush 3 months ago now I have a hard shift from 1st to 2nd. I tow nothing. Its my pavement princess and now I don't know what to do. Replace filter and the few quarts of fluid or save the money for Toyota to diagnose it. Any ideas guys? sorry to take over the thread.
  14. Jun 10, 2018 at 5:12 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    You could start by checking the fluid level. Mine was somehow low after I changed the fluid for the first time, followed the factory service manual step by step and still ended up adding another quart.
    leikolee[QUOTED] likes this.
  15. Jun 10, 2018 at 10:18 AM
    Ronmat4X2
    2007 4X2 TRD
    Agree with fixnfly make sure level is right before you get too worried. I have a 07 with
    176,000 and will do drain and filter one day.
    I wonder what the dealer will charge for a drain and filter change?
  16. Oct 9, 2018 at 3:57 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I posted this to another thread in here. I’ll update it with what I find out today, but I’m increasingly worried I’ve fixed what wasn’t broke.
  17. Oct 9, 2018 at 5:16 AM
    trdprobped17
    trdprobped17 New Member
    Take it to the dealership! It can be problematic at times. It doesn’t have a replacement filter of the sorts because it is a reusable meshed type thing. But, the seal and drain plug tends to have issues sometimes.
  18. Oct 9, 2018 at 4:08 PM
    BlackSheep
    Scott
    Kansas City, MO
    Got my truck back this afternoon, and so far it’s a world of difference from two days ago. The mechanic said he put an aftermarket filter on the transmission to begin with, and the new one is from Toyota. He said the difference in driving to him was night and day as well. He said he learned something today, and so did I!
  19. Aug 28, 2020 at 9:02 AM
    Finch
    Finch New Member
    Donnie
    '16 Inferno CM 5.7L TRD Off-Road
    Resurrection time! Any update to know which filter one might have before they drop the pan? I have a 2016 5.7L 4x4 and I'm wanting to replace the filter. Noticed two options that "fit" my Tundra.
  20. Aug 28, 2020 at 9:30 AM
    SouthWestGA
    SouthWestGA New Member
  21. Aug 28, 2020 at 9:57 AM
    Mark18TRD
    Mark18TRD New Member
    Mark
    Cypress TX
    2018 White Tundra TRD
    6" RC lift, 20" Fuels, RC rear bumper w/ lights, RC front bumper light bar, (NSV light bar ordered and on the way)
    i looked everywhere in the owners manual for info on trans service, and was not successful. i called toyota and they told me my trans was non serviceable (2018 Tundra)
  22. Aug 28, 2020 at 10:42 AM
    timsp8
    NY
    Look up the trans threads. One has pictures where a guy took his filter out over 100k and it was clean. It’s more of a screen and doesn’t need to be replaced. You could cause more issues trying to replace it like breaking the bolts on the pan, which is common.
  23. Aug 28, 2020 at 10:55 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Shoot me a VIN and I'll look it up for you.
  24. Aug 28, 2020 at 11:27 AM
    Finch
    Finch New Member
    Donnie
    Pm sent
    Roman[QUOTED] likes this.
