Transmission Service at 104K Turns Ugly
Discussion in '2nd Gen Tundras (2007-2013)' started by stangrev, Nov 2, 2020.
  1. Nov 2, 2020 at 6:32 PM
    stangrev
    stangrev [OP] New Member
    Dennis
    07 Tundra SR5 Double Cab 4X4 Long Bed.
    I'm Dennis, new member here! I live in East TN, retired in 2010 and figured this to be my last and best truck ever! 104K. Easy solid/shift pattern before fluid exchange.
    I had my 07 Tundra Sr5 Double Cab/LB, 4X4, 6AT, 5.7 5, transmission fluid
    changed and within 2 week started seeing shift pattern change...hanging in
    gear. Fluid level recheck OK.
    Took pan off today and garage says "quite a bit of clutch material...feel like we disturbed some debris...that is friction material." I asked about putting pan back on, filling with "heavier" fluid until replacement arrives..."if we do install the pan back we will have to extract 5 rusted bolts that broke off when removing."
    My questions: Transmission failure this early? (I've ALWAYS used Tow/Haul)
    Rusted bolts suggest chronic moisture?
    Toyota CSP been helpful to anyone on big issues like this?
    Reman vs salvage vs Toyota replacement?
    YardBird likes this.
  2. Nov 2, 2020 at 6:35 PM
    FYI...If it isn't broke don't try to fix it. Did you have a total flush? It's best to have a 1 gallon drain...check fluid...if still good......top off.
  3. Nov 2, 2020 at 7:00 PM
    Maxi13
    Maxi13 GuttenTight
    Montucky
    2020 Cement Sr5 TRD OR
    Nudding yet
    Following. Hope you can get resolved. My 2013 is running great but bought used and working through fluid changes. Are you suggesting not to do a full flush for the tranny but just top off?
  4. Nov 2, 2020 at 7:05 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Drain and fill is all I have done on tranny's. Only failure i have ever had was a PoS GM with chronic problems.
    snivilous likes this.
  5. Nov 2, 2020 at 7:14 PM
    Welcome to the site Dennis.
    Was this the first service and was it at a transmission shop or dealership? Flush or drain and fill? Doing a helicoil on the aluminum transmission is a piece of cake. They just want you to do the work right there without leaving and possibly going elsewhere.
    Personally, I would do a used transmission and be done with it. Service the transmission every 30-60K max and be happy.
    https://www.ebay.com/itm/2007-2010-...fits=Model:Tundra|Make:Toyota&epid=5030897819
    https://www.ebay.com/itm/2011-2014-...Warranty-OE-2013/203145871730?epid=1637470682
    https://www.ebay.com/itm/TOYOTA-TUNDRA-4X4-5-7L-2019-Transmission-851302-ID-350100C280/363096323992
  6. Nov 2, 2020 at 7:15 PM
    Get a new mechanic. My 07 was 12 years old when I traded it in. Tranny was flawless. I did have to replace a $18 power steering pressure sensor at 12 years old. Just my opinion.
    BlackSheep and TheBeast like this.
  7. Nov 2, 2020 at 7:40 PM
    TheBeast The Beach
    million mile Tundra is a 2007....:notsure:
    Black Wolf, BlackSheep and BTBAKER like this.
  8. Nov 2, 2020 at 7:40 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  9. Nov 2, 2020 at 7:49 PM
    Two of them now...both 4.7L motors. Not sure if that matters much with the transmission due to being 100 hp less?
  10. Nov 2, 2020 at 7:58 PM
    Azblue
    The Dirty T ( ^_^)_且
  11. Nov 2, 2020 at 8:02 PM
  12. Nov 2, 2020 at 8:03 PM
    Azblue
    It has died off, used to be great.
  13. Nov 2, 2020 at 9:14 PM
    Yep. I was a very active member. I seen a few things in the back pages of that site that changed my complete opinion of TT. Deleted 4500 posts, deleted account.
    Black Wolf and Wallygator like this.
  14. Nov 2, 2020 at 9:16 PM
    fbingha
    fbingha New Member
    Bakersfield, CA
    If there were a lot of transmissions problems with 07 then this is the forum where you would hear about it.
  15. Nov 3, 2020 at 1:50 AM
    B33
    B33 New Member
    The 4.7 and 5.7 have different trans 4.7 is a 5 speed the 5.7 is a 6 speed
    AZBoatHauler and CMB like this.
  16. Nov 3, 2020 at 1:54 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    This is ridiculous
  17. Nov 3, 2020 at 3:15 AM
    1rooster
    1rooster New Member
    Tony
    2007 crewmax
  18. Nov 3, 2020 at 3:46 AM
    timsp8
    NY
    Like others said, it sounds like you got a flush and not just a drain and fill. But the bolts breaking seems to be very common and easily fixable if they know what they are doing.
  19. Nov 3, 2020 at 5:25 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    I'm guessing you don't know if they did a flush or drain & fill, or what kind of fluid they used. Having your transmission flushed by careless, irresponsible mechanics in bad shops is a really bad idea. Dirty flush machine? Wrong type fluid? Flush machine contaminated with another fluid type, or dirty fluid from previous work?
    If I were in your position, I would tell this "mechanic" to bolt the pan back on the transmission using the remaining screws, finger tight, and to push the truck outside. I would then do the following myself. If you don't have the skills or the time, then you'll have to find another reputable shop, and have them go get your truck.
    (1) Replace/repair the broken-off screws, clean up the pan, replace the strainer, and reinstall the pan.
    (2) Drain/flush ALL remaining fluid possible, and refill the transmission with Valvoline MaxLife. Many Toyota owners have found this synthetic fluid equivalent to Toyota ATF WS. For the full transmission volume, it will be much cheaper for the experiment.
    (3) Then see how the truck drives. If you still have rough and irregular shifting, damage has been done.
    Maybe the few hundred expenditure above will be money down a "rathole", but if the transmission is fine after a little TLC, you've saved thousands. If the transmission still has problems, then you gambled and lost.
    Your other best option is a low-mileage salvage transmission. Labor will probably equal or cost more than the transmission. And, I would definitely find another shop to do the work.
    Welcome from the Texas Hill Country.
  20. Nov 3, 2020 at 5:34 AM
    I had a friend that owned a transmission shop in TX for 37 years. He was amazed what different machines he had seen over the years for flushing. His recommendation was every 20k:
    -drain fluid.
    -change filter according to factory specifications.
    -fill.
    Now most of his customer base was HD trucks. With the Tundra, I would be good with every 60k miles unless towing pretty heavy every day.
    JohnLakeman likes this.
  21. Nov 3, 2020 at 5:43 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Not trying to argue with your buddy as I'm sure he knows a lot more than me but I wanted to talk about that 3rd bullet point. I just dropped the pan on my 18 year old Tundra and replaced the "filter". The filter is really just a mesh screen that tries to trap bigger particles. While I can't see the entire thing, I didn't see anything of concern in there. Also, there were zero metal shavings on any of the magnets. The truck has around 175K miles. I'm really not convinced there was any benefit to me replacing that filter and I would say unless you have a suspicion something is wrong, dropping the pan is a waste of time. Maybe that's different for HD trucks like you mention.
  22. Nov 3, 2020 at 5:45 AM
    Yzed608
    Yzed608 New Member
    Wisconsin
    I'm not too well versed in truck maintenance, can someone explain the difference between a flush and a drain and fill? I'm guessing the drain only gets a certain portion of the contained oil, as the rest is trapped in the assembly and cooler?
    I'm just over 50k and just trying to understand everything for future maintenance. It seems like I've read so many conflicting things on transmission stuff. Sorry, not trying to hijack op's thread, but may be good info for others still.
    ColoradoTJ likes this.
  23. Nov 3, 2020 at 5:50 AM
    Most recommend filter swaps at 120k miles. For my Allison, it’s around 90k or something. Now the external screw on filter is every 45k. I would also find out what kind of filter is used. As you stated, the mesh screen is for large particles. The filters that use media should be changed out.
    I would think keeping fresh fluid in the transmission would be more important.
    FirstGenVol[QUOTED] likes this.
  24. Nov 3, 2020 at 5:53 AM
    Drain and fill: drain plug removed, get a few quarts out of the system. Refill
    Flush: disconnect transmission lines, hook up a machine to push the old fluid out while putting new fluid in. If done backwards, this can push the old fluid through the valve body and cause numerous problems.
    Yzed608[QUOTED] likes this.
  25. Nov 3, 2020 at 6:02 AM
    Professional Hand Model
    Hand Protectors
    For a complete transmission fluid service, one can do a drain (from the pan plug) and then fill. Now, move up to the rubber transmission hose and disconnect. Turn truck on and pump out 1 quart at a time and turn off. Fill at dipstick/refill plug 1 quart. Repeat x10 (or whatever your fluid capacity). You just performed a safe flush and saved $$$.
    ElNopal likes this.
  26. Nov 3, 2020 at 6:12 AM
    JohnLakeman
    The use of a flushing machine in a commercial shop is a problem even if the guy does get it hooked up right. How many guys on tools are going to thoroughly clean the machine after a previous service of a failing transmission with metal filings and clutch debris? Clean fluid is essential to an automatic transmission; consider the tolerances necessary to prevent excessive fluid leakage past the spool valves. Probably in the very low thousands of an inch, if not ten thousandths.
  27. Nov 3, 2020 at 6:52 AM
    Totally agree.
  28. Nov 3, 2020 at 7:00 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    This happened to my 2000 Celica... My brother flushed the transmission when he worked at Jiggy Lube, and it was probably the worst thing ever.. had issues shifting and had some hang time between shifts... it still acts up today, but I'm finally getting around to ditching it at 167k...
    Apples to apples my 07 Tundra 5.7 2wd has 224k on the same transmission has been serviced twice early in life due to issues with seals, and I've sorta ignored it... I will be doing a drain and fill, but it's been good so far.
  29. Nov 3, 2020 at 7:13 AM
    Kurt7700
    Kurt7700 New Member
    Kurt
    Ocala, FL
    2009 Tundra DC V6
    Nothing is more confusing than trying to get a straight answer on transmission fluid changes on these trucks. The engines don't have a dipstick to check it and my service manual has nothing in regard to transmission fluid changes. I go back and forth between the people who swear you should never change it and those that drain and fill every 30k to 60k miles. Even the dealers don't have consistent answers. I don't get it but I have 30K miles before I have to make a decision. Lol.
  30. Nov 3, 2020 at 7:30 AM
    drowhawk
    drowhawk New Member
    '19 Tundra SR5
    5.7L Tundras have always recommended an ATF drain/fill every 30k miles for towing/hauling. If you do not tow/haul, Toyota doesn't recommend changing it.
    I have never flushed ATF on a Tundra, as it requires a special spacer plate to hook up a flush machine. But I have flushed plenty of other automatic transmissions and there seems to be a lot of misinformation about flushing.
    Flushing is a GOOD thing on healthy transmissions. It can accelerate the failure if the transmission is already starting to fail. Flushing a healthy transmission will not damage it. Period. Flushing machines do not allow used/old fluid to interact with the new fluid so there is no risk of cross-contamination among vehicles.
