Transmission Screen ,, Lifetime???
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, Jan 26, 2023.
  1. Jan 27, 2023 at 8:03 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Do you have any flow diagrams? The inside of my trans filter had clutch material on the inside of the filter sock, as if trans fluid was being pulled through the bottom of the filter. There was nothing on the outside of the sock that would suggest the fluid flows the way oure describing, at least in my particular case, im curious to learn more though. You can check link in the post above to see the debris inside my filter.
  2. Jan 27, 2023 at 8:03 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Dying on what mountain? It’s the Internet, lol. Some people take this shit too serious. I gave my opinion that what is $43 for a filter and everyone now is an engineer saying what the filter can and can’t do. Change it, don’t change it, I could care less. Just like some people go 10-15-20k between oil change. Their choice.
  3. Jan 27, 2023 at 8:05 AM
    AZBoatHauler
    So.Arizona
    One slight difference being Toyota tells you to change the oil.
    TRDFerguson and Sumo91 like this.
  4. Jan 27, 2023 at 8:07 AM
    Sumo91
    TN
    Wait till you find out about the fuel filter and how much debris it has in it :eek:
  5. Jan 27, 2023 at 8:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Because the owner should have a chance to correct a transmission problem he just observed. It still makes sense to catch that large chunk of metal that would otherwise seize the oil pump.
    I'm saying that changing the filter regularly, like every other oil change, makes no sense. To me it also makes no sense changing ATF every 100k. My truck is at 38k miles now, I did 3 drain&fills already. Toyota ATF is cheap, not like brand ATF for European luxury cars.
  6. Jan 27, 2023 at 8:14 AM
    pursuit2550
    Toyota also tells you to only use 0w-20, At least the US models.
    vtl likes this.
  7. Jan 27, 2023 at 8:14 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Unlike gas tank, which you are sort of forced to open very often, transmission is a sealed unit. Nothing gets in, nothing gets out.
    AZBoatHauler likes this.
  8. Jan 27, 2023 at 8:15 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I fully believe this and am curious how I can change mine.
  9. Jan 27, 2023 at 8:16 AM
    AZBoatHauler
    So.Arizona
    In what country do they tell to you to change the screen?
  10. Jan 27, 2023 at 8:17 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    So they last only 1 million miles. While if Toyota was recommending 10w40 every 3k the engine could easily do 2 or even 3 million miles ;)
  11. Jan 27, 2023 at 8:17 AM
    pursuit2550
    But if it’s an item that doesn’t require maintenance then the owner wouldn’t know anything till it craps out.
    I also have done 1 drain and fill and you’re right, oil is cheap, so why not change the cheap filter at, say 60k or 80k. Cheap insurance I say.
  12. Jan 27, 2023 at 8:18 AM
    pursuit2550
    What screen?
  13. Jan 27, 2023 at 8:18 AM
    pursuit2550
    Could be. I say it’s an EPA/Cafe crap.
  14. Jan 27, 2023 at 8:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Previous experience. Plus in rust belt it is all rusted already in 3 years. I don't want to go through the drilling nightmare just to find out that I was right and there's nothing inside the filter.
    If you want to and can change the filter regularly - fine, it does not hurt. I'm doing that with my tires, like new tires every couple of years ;)
  15. Jan 27, 2023 at 8:22 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Nah, not for AB60. I have a nice one for AW55/REF23 though.
    Sumo91[QUOTED] likes this.
  16. Jan 27, 2023 at 8:22 AM
    AZBoatHauler
    So.Arizona
    It says it’s an elementary word but I bet everyone can follow along.
  17. Jan 27, 2023 at 8:46 AM
    pursuit2550
    Ah, go back to post 39. I talked about oil and you quote with the screen crap. I think they teach reading in elementary also. Maybe don’t quote an oil post when asking about a trans filter.
    It’s also a filter/strainer not screen, per Toyotas description.
  18. Jan 27, 2023 at 8:53 AM
    pursuit2550
    Lucky you. I have to deal with S.Florida heat and no salt on the roads. It’s like 80 today.
    vtl[QUOTED] likes this.
  19. Jan 27, 2023 at 11:34 AM
    #49
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The issue with referring to it as a screen is #1 its not a screen, a screen is a metal mesh. #2 when people hear screen they think of it as a non serviceable item since there are transmission that only have a metal screen and not a filter. I'm not even advocating for people to replace it, i have but doesn't matter to me if anyone else does. Just trying inform people that it does have a replaceable filter and not a metal screen.
  20. Jan 27, 2023 at 12:24 PM
    #50
    AZBoatHauler
    So.Arizona
    Just making stuff up at this point.
    Jaypown likes this.
  21. Jan 27, 2023 at 12:45 PM
    #51
    Joe333x
    Joe333x Member
    Boston
    What am I making up? I have literally taken the filter out and cracked the plastic open to show what it is. Its a fiberious filter, not a metal screen.
  22. Jan 27, 2023 at 12:53 PM
    #52
    AZBoatHauler
    So.Arizona
    Who said it was metal?
    screen: a perforated plate or cylinder or a meshed wire or cloth fabric usually mounted and used to separate coarser from finer parts.
    I know, Merriam-Webster is wrong too.
    Jaypown likes this.
  23. Jan 27, 2023 at 12:58 PM
    #53
    2mchfun
    :fingerscrossed: Let's here it....come on with it @Tileguy, please share your transmission service history and odometer reading with us. Also while on the subject gents, seems like I read somewhere that the computer makes pressure adjustments for fluid age and there is a way to change it in techstream. Yes, no, or no idea? I'm skeptical, but I suppose it's possible and sort of makes sense.:notsure:
  24. Jan 27, 2023 at 12:59 PM
    #54
    Joe333x
    Joe333x Member
    Boston
    Okay, point is, its not a screen, screens separate larger material. The filter in the transmission blocks small particles as well. You wouldnt call whats in your engine an air screener, or oil screener. The reason I even replied to this is the dealer told the OP that is was a lifetime screen that you dont replace which is incorrect. Not sure the point of arguing semantics, its a filter that can be replaced, not a lifetime screen thats not replaceable.
  25. Jan 27, 2023 at 12:59 PM
    #55
    pursuit2550
    Oh good. Now we can debate screens, filters and strainer. I thought this thread was done with.
  26. Jan 27, 2023 at 1:00 PM
    #56
    brandostundra
    brandostundra [OP] New Member
    joe333, im curious what is year and model of your truck ?
  27. Jan 27, 2023 at 1:02 PM
    #57
    pursuit2550
    It right on his thing there. 2019 CM
  28. Jan 27, 2023 at 1:03 PM
    #58
    Joe333x
    Joe333x Member
    Boston
    2019 Platinum, FYI most people put there year and model in there profile and it shows next to your avatar.
  29. Jan 27, 2023 at 1:03 PM
    #59
    2mchfun
    Fwiw, I have seen plenty of screens with micron ratings!!
  30. Jan 27, 2023 at 1:05 PM
    #60
    brandostundra
    ok thanks.
    are we certain that the tundra had the same transmission through out the years?
    does the transmission on a 2016 use the same filter/screen/strainer as the 2019?
