Transmission rear seal
Discussion in '1st Gen Tundras (2000-2006)' started by 2003stepside, Feb 21, 2020.
  1. Feb 21, 2020 at 8:12 AM
    2003stepside
    2003stepside [OP] New Member
    David
    2003 Tundra Stepside
    Hi, my 2003 Tundra with the 4.7 and auto transmission is slinging transmission fluid where driveshaft enters transmission. I think it is rear seal that is leaking. I spoke with local repair shop and was told it may be bad brass bushing in the tail piece also . He mentioned that a cross member may have to be removed to get tail piece out if bushing is bad. Does anyone know if the cross member has to be removed? Tundra only has 143k miles on it. Hoping it is just the seal but wanted to get as much input from others that may have had this repair done before I get service done. Thanks
  2. Feb 21, 2020 at 9:13 AM
    Professional Hand Model
    Hand Protectors
  3. Feb 23, 2020 at 7:39 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I know I had to remove the cross member to get the transfer case input seal out so I would assume so.
