Transmission plug stripped at just over 15 ft lbs
Discussion in '2nd Gen Tundras (2007-2013)' started by bradleydavidgood, Aug 17, 2025.
  1. Aug 22, 2025 at 6:02 PM
    bradleydavidgood
    bradleydavidgood [OP] New Member
    2013 Tundra 4.6L Double Cab
  2. Aug 22, 2025 at 6:15 PM
    JRS
    JRS New Member
    2012 DCLB
    Pretty sure it was supposed to be 30 in-lb. I did the same thing and was using ft-lb. Have yet to install the new cover.
  3. Aug 22, 2025 at 6:23 PM
    bradleydavidgood
    I think it is 15 ft-lbs. But I will never use a torque wrench again on this bolt/pan on the Tundra. The threads on the pan are very short. I will just feel the washer crush and snug it down tight after that but not force it further. Forget the spec.
  4. Aug 22, 2025 at 9:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Finger tight on a nut driver probably enough
  5. Aug 23, 2025 at 5:40 AM
    JRS
    JRS New Member
    2012 DCLB
    Yeah, you're right. Dunno why I had that in my head. It is 15 ft-lb. Either way, I did it too. Ha
  6. Aug 23, 2025 at 5:59 AM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    Goes against instinct for some, but I never use a torque wrench on small or low torque bolts like this. Just use a 3/8 socket wrench and choke up on it and go by feel. A torque wrench is one "click" away from a breaker bar. At their lowest settings the click can be easily missed. My .02
    I think there's a thread "stripped drain bolt club" you can join now. You're not alone!
    Orions Dad, KNABORES and JRS like this.
  7. Aug 23, 2025 at 7:09 AM
    bradleydavidgood
    Thanks for posting that diagram with the torque specs.
    Always good to hear someone else did the same thing, makes me feel human.
  8. Aug 23, 2025 at 7:10 AM
    bradleydavidgood
    I think the key is to crush the washer fully and then snug it up a little. Not sure finger tight would do that.
    Hbjeff[QUOTED] likes this.
  9. Aug 29, 2025 at 6:14 PM
    bradleydavidgood
