Transmission overflow plug gasket?
Discussion in 'General Tundra Discussion' started by Atomic City Tundra, Sep 2, 2018.
  1. Sep 2, 2018 at 9:39 AM
    Atomic City Tundra
    Atomic City Tundra [OP] Cam Tower Leak Addict
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I just finished up changing the fluid in the transmission on my 2013. I noticed that when I left the truck sitting overnight to let it cool below the check temperature, the gasket for the overflow/check plug is leaking. Upon closer inspection, it looks like they slapped two gaskets on top of each other during assembly. Worked out so far, but now it is seeping.
    I haven't had much luck finding part numbers on the OEM online places (I guess they really don't want you servicing these things themselves. So, I did a generic search and found this link:
    https://www.amazon.com/Rexka-Transmission-Gasket-4Runner-35178-30010/dp/B07B7HKD54
    Looks like it is the right size according to my measurements, and it appears that Tundra is on the list for what it fits. Was wondering if @Roman could help out and confirm?
  2. Sep 2, 2018 at 11:51 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Just did a drain/fill on my tranny. I went to my dealer and told them what I was looking for and they got me the gaskets and o ring. Sorry I don’t have the part numbers but I bet a call/visit to your dealership parts dept would get it figured out.
  3. Sep 4, 2018 at 10:17 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    It just depends on which plug you're needing it for. Check out the parts diagram here:
  4. Sep 4, 2018 at 10:27 AM
    Atomic City Tundra
    Devin
    New Mexico
    It would be 35106B in that diagram. I just did a search on toyotapartsdeal.com for that part code, and it came up with the one I ordered this weekend. So I think that I am ok. However, there are a couple of other sites that say it won't fit. But, the dimensions listed match what I measured. So, hopefully it will work.
    Thanks!
    Roman likes this.
  5. Sep 4, 2018 at 12:28 PM
    Roman
    Roman
    Franklin, TN
    Yep, those are definitely the 35178-30010. Glad I could help you out. :)
  6. Mar 5, 2020 at 11:52 AM
    TuNdRaRiDe
    TuNdRaRiDe New Member
    Lyanna
    2013 Blk Tundra
    6 in lift/ 35's/ off roading equipped LEDs
    Omg guys thanks changed the transmission fluid to my tundra and for the life of me I couldn't find that gasket part number thanks
