Transmission over heat temp warning display...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tchase, Aug 17, 2020.
  1. Aug 28, 2020 at 3:38 PM
    #151
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    While so many choose to debate and argue back and forth about a trans cooler... some of us are enjoying our trucks after adding the auxiliary cooler... and running MUCH safer/cooler ATF temps.
  2. Aug 28, 2020 at 3:47 PM
    #152
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    Cpl_Punishment and 19crewmaxTRD like this.
  3. Aug 28, 2020 at 4:00 PM
    #153
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    God I love this forum
  4. Jan 29, 2021 at 8:58 PM
    #154
    Scott04Tundra
    Scott04Tundra New Member
    Scott
    2004 SR5 Tundra Stepside
    Stock
    Ok I've looked through all the comments and I'm still clueless on what's the fix for my Tundra.
    I have a 2010 crewmax 4x4 with 5.7. I just bought this truck with 265k for my shop truck and have only put six miles on it.
    I've had the 4 LO flashing light come on when just Ideling in the garage in park.
    Also had the at temp light come on after short yard drive and the engine just stalled.
    I drained 4-1/2 quarts from the trans and it wasn't too bad and smelt ok.
    So what's the problem and how do I fix it?
    Thanks
  5. Jan 29, 2021 at 9:01 PM
    #155
    Scott04Tundra
    Scott
    Stock
    Thanks
  6. Jan 30, 2021 at 3:17 PM
    #156
    Blue Thunder
    Washington
    Step 1: It's a little known fact that double-posting doesn't do anything...
    Step 2: I suggest posting this either as a new thread in the correct sub-forum, or at minimum in a thread that's even remotely related to your issues. Your issues are not related to the 2014+ generation truck, nor transmission temps.
    Cpl_Punishment likes this.
  7. Jan 30, 2021 at 4:12 PM
    #157
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Ouch. The 2019+ owners are under a little stress because of this whole auxiliary cooler thing. :D
    If you've done the "Search", arrived at this thread, and read all six pages of this, you certainly deserve the best answer we can conjure. Be important in your own right! Start your own thread in the Gen2 forum (2007-2013) asking your question, and someone will help you out. That's just what Tundra guys do. :thumbsup:
    Welcome @Scott04Tundra from the Texas Hill Country.
    Scott04Tundra[QUOTED] likes this.
  8. Jan 30, 2021 at 5:12 PM
    #158
    timsp8
    NY
    Double post was probably an accident. He did mention AT temp and draining some fluid out of the trans. While not specifically related to this thread, Im not sure how that’s not related to transmission temps. And the 2010 is pretty much the same as the 2014-2018.
    Scott04Tundra likes this.
  9. Jan 30, 2021 at 6:26 PM
    #159
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Semi frames are heat treated alloy steel. This is why they have the sticker “do not weld “.
