Transmission fluid change on my Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by Jake92, Aug 3, 2019.
  1. Nov 15, 2019 at 4:58 AM
    Professional Hand Model
    Hand Protectors
    Very nice! Stoked on the quick feedback. Mine reads at the high end of the sweet spot after a hot summer run. A little lower on cooler days.
    The valve body inside the drain fluid pan works off of hydraulic pressure. The fuller level get inside all those ports/tunnels and solenoids making for better shifts pressure.
  2. Nov 15, 2019 at 9:50 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Rechecked again this morning after a good hour drive and its spot on. It's now sitting right in the middle of the sweet spot. Now that I think about it, the trans sometimes had a hard shift between 1st-2nd which seems to have gone away now. I always chalked it up as being a older truck with 175K so it wasn't going to be smooth as butter but it seems to be now.
    I hate checking transmission fluid. It's such a pain. Why can't it be like engine oil lol?
  3. Nov 15, 2019 at 11:30 AM
    Hand Protectors
    Mine was the same between 1st and 2nd especially on cold days. Now its a very smooth transition regardless. Its the simple things.
    SouthPaw[QUOTED] likes this.
  4. Nov 15, 2019 at 11:58 AM
    SouthPaw
    2000 Limited 4x4 AC
    Yup, on cold days it was worse. Maybe now it will clean it up.
  5. Nov 15, 2019 at 1:47 PM
    Hand Protectors
    Cold starts and the first one or two shifts its a bit tight which I guess is normal for most transmissions. After that good to go.
  6. Nov 16, 2019 at 6:50 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Looks like I got a ways to go after a drain and fill. Checked after trip to dump just now.
    SouthPaw likes this.
  7. Nov 16, 2019 at 9:55 AM
    Hand Protectors
    Looks about 1.5-2 quarts short.
  8. Nov 16, 2019 at 10:15 AM
    SouthPaw
    2000 Limited 4x4 AC
    If that’s how it reads hot, try one quart first. Mine was similar and I only needed one to bring it up to full.
  9. Nov 16, 2019 at 11:03 AM
    Hand Protectors
