Transmission fluid @ 175k never done
Discussion in '2.5 Gen Tundras (2014-2021)' started by drpheta, Jul 17, 2023.
  1. Jul 18, 2023 at 7:34 AM
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    That's good to at least keep up on the FF. I'm sure you'll be just fine then if you keep at it then.
  2. Jul 18, 2023 at 8:44 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd wire brush the loose stuff off those bolts then soak the piss out of em in PB Blaster and let it set for 24 hours. You could also try a little heat from a butane torch on the ones that seem to be fused in.
  3. Jul 20, 2023 at 8:29 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Had a drain and fill done at the dealer but it may have been the first ever at 102k mi. Can I do another at home without bringing the pan to temp etc? That seems a bit outside of my capabilities
  4. Jul 21, 2023 at 6:55 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Assuming you put in exactly what came out there isn't alot that can go wrong. I want to believe the dealer did the proper level procedure but I would be surprised if they did.
  5. Jul 21, 2023 at 6:56 AM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    What's the risk if you're off by say 1/4 of a quart?
  6. Jul 21, 2023 at 7:09 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'm sure it will probably be fine, will probably shorten the life of the transmission. I'd rather be over by a 1/4 of a quart.
  7. Jul 21, 2023 at 7:29 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It wont shift as crisp, i added a little more, back to normal
  8. Jul 21, 2023 at 9:12 AM
    Talon2006
    Talon2006 New Member Vendor
    This, or hold a air duster can upside down and freeze the bolt.
    The nice thing is, while the outside of the bolt has been very dusty, the inside has been backed with fluid so there is a chance that the threads are not rusted together.
  9. Jul 21, 2023 at 12:06 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Low fluid will lead to soft shifts. Common dealer trick when selling used vehicles with slipping transmissions is to over fill them.
  10. Jul 21, 2023 at 12:21 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    So the consensus is that I should put the truck through a few more drain and fills, and that simply one of them isn’t quite enough to help much?
    Jaypown likes this.
