Transmission Filter and pan gasket ..... part number please
Discussion in '2.5 Gen Tundras (2014-2021)' started by brandostundra, May 8, 2023.
  1. May 8, 2023 at 2:29 PM
    brandostundra
    brandostundra [OP] New Member
    Hello does anyone know the correct toyota part numbers for a
    transmission filter and pan gasket?
    I have a 2016 Tundra 5.7 4x4 Limited
    thank you
  2. May 8, 2023 at 5:28 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Ely010606 likes this.
  3. May 9, 2023 at 4:43 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I may say to add on bolt p/n 9011906A02 up to a qty of 12. Most of mine were in good shape, but a couple had corrosion started on them.
    Joe333x likes this.
  4. May 9, 2023 at 1:02 PM
    brandostundra
    thank you
  5. May 11, 2023 at 4:54 PM
    737fixer
    737fixer New Member
    I've done the filter on these and the risk/reward simply doesn't payoff. This filter is not like the filter for your engine oil. Most transmission people call them catastrophic filters since they are only meant to keep out the big stuff in case of massive failure. While I do not agree with this even the one I did at 184K really wasn't what anyone would call dirty. If you simply do the drain & fills at a little ahead of schedule you will never have a transmission failure. If you're doing it just for piece of mind then by all means go for it. I am a huge believer in if it gives me some stress relief then it's a good thing.
    AZBoatHauler likes this.
