Transmission Drain and Fill
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmevis, Mar 26, 2018.
  1. May 6, 2019 at 4:11 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    I don’t care what manuals say
    NOTHING is for a LIFETIME!!
  2. May 7, 2019 at 6:54 AM
    jmevis
    jmevis [OP] New Member
    Nashville TN
    2017 Tundra Trd Pro
    Agree.
  3. May 7, 2019 at 7:48 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I'm pretty sure I've done at least 3 drain and fills already at 10 years old and 86K on my 09. One at 40 or 50K, another around 60, another a few months ago. People are all over the place with this. Some do full flushes early in the truck's life. Some do drain and fills only. Some do a mix of both. Toyota recommends 60K if you tow, otherwise I think it's 'inspect' at 90 or 100K with no specific instructions to change. But don't quote me on that. The catch 22 tends to be, a lot of dealerships don't want to touch it earlier than the manual recommends because they're afraid if there's any underlying issues uncovered by removing the fluid they're on the hook for it. But if you start going around asking for a full flush at 90K they're all gonna tell you it's too late in the vehicle's life to fully flush it if you've never done it before.
    I find multiple drain and fills is a good compromise and the dealer has always been happy to oblige every time I've asked for one. The truck still shifts the same as it did when I pulled off the lot brand new a decade ago.
    The 60K or 100K transmission claim is marketed at people who hold a car the average time period of 5-6 years and 100K or less who don't want to spend any money on anything besides payments or gas before they dump it and move on. Those of us who want cars to run like new and be trouble free for 200K-plus go above and beyond that.
    Sequoia_XLR8R, Midnite72 and chugs like this.
  4. May 8, 2019 at 9:15 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Exactly. It is a sealed system.
  5. May 8, 2019 at 9:29 PM
    619Tundra
    The Dude who put One Million Miles on a Tundra had transmission failure at 792,000 Miles. That was a 4.7L V8.
    JohnLakeman likes this.
  6. May 9, 2019 at 5:36 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Since the transmission is a closed system, it is not subject to external contaminants or by-products of combustion like engine oil. But, it is vulnerable to wear materials from hard use or abuse such as towing and excessive shifting.
    I used to be a life-time AT fluid believer, but no-more based on reading Tundra forums. Fluid life depends totally on the service the transmission sees. My present belief on change interval matches the take-away from other real experience reports on this thread, and Toyota's recommendations: 60K for towing or other extreme service, 100K for normal service. As noted before, more frequent changes certainly won't hurt anything but your pocketbook, but if you're imagining that you know more than Toyota about fluid change intervals and effect on your transmission's life, it's just that...your imagination.
    Siglersj and Rider0120 like this.
  7. May 9, 2019 at 6:12 AM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Has anyone transferred to amsoil atf yet?
    jmevis[OP] likes this.
  8. May 9, 2019 at 6:16 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    I would LOVE to do this, since I use Amsoil in everything I can. However I would never want to mix transmission fluid so the process to flush completely requires shop/dealer involvement. And I have done 100% of the work to my truck myself. I don't trust a $15 an hour shop tech.
  9. May 9, 2019 at 6:20 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I believe several on here have replaced with synthetic; flush and drain/fill.
    A few have claimed smoother shifting as well.
  10. May 9, 2019 at 6:29 AM
    jmevis
    Nashville TN
    2017 Tundra Trd Pro
    If I could do this myself I totally would.
    Trooper2[QUOTED] likes this.
  11. May 9, 2019 at 12:24 PM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    The manual doesn't even say this. It requires a drain and fill every 60k miles....
    ryanwgregg likes this.
  12. Jul 2, 2019 at 4:39 PM
    Mikey02151
    Mikey02151 New Member
    2010 Tundra 5.7
    I could use some advice please. I followed some tips from the forums and drained my fluid on my 2010 5.7 Tundra. Issue is that over 6 quarts came out! I tried replacing with 6 but made a mess as it overflowed from fill hole. Thoughts?
  13. Jul 2, 2019 at 4:54 PM
    Professional Hand Model
    Hand Protectors
    Who benefits from your transmission going bad after warranty?
    Why would you not at least do a drain and fill on occasion to freshen the fluid?
    Fresh fluid never hurts. Oil fluid does.
    What does Toyota say about heavy service, such as towing and hauling? Same lifetime fluid no service as a street princess truck?
    Nothing for me to gain here, but I’d at least do some regular drain and fills. Cheap insurance, especially DIY.
  14. Jul 2, 2019 at 5:51 PM
    JohnLakeman
    At some point in it's life, your Tundra has had it's transmission fluid checked or changed by incompetent professionals or well-meaning amateurs, and it was over-filled. Nothing you can do about that now, set the fluid level at the proper temperature using Toyota's procedure, and keep on trucking.
  15. Jul 3, 2019 at 6:17 AM
    Mikey02151
    2010 Tundra 5.7
    I agree with you. My new problem is that when I removed the upper hex drain plug it drained most of the fluid.. It seems to be missing the straw that is supposed to level off the fluid and get me to correct level. Called dealer and they said there is no replacement straw part... Saw a guy on YouTube that shows a red straw being threaded out.
  16. Jul 3, 2019 at 9:04 AM
    JohnLakeman
    Assuming your 5.7L has the AB60 transmission like Gen 3, the upper hex plug in the body of the transmission (left side) is only for fill. There isn't a "straw" on the upper plug hole. Only the overflow port on the very middle bottom of the transmission pan has the overflow tube. Your dealer parts guy probably meant the overflow tube doesn't come separate, that it's sold with the oil pan.
    If the individual filled the transmission until it ran out of the fill port, then the transmission was way over-filled.
  17. Jul 3, 2019 at 10:06 AM
    JohnLakeman
    l probably misunderstood your description of the "upper hex drain plug". The port with the overflow tube IS higher than the drain plug and is located oh the driver side of the oil pan about in the middle. Both the drain plug and the overflow port are in the oil pan. There is a third hex plug up on the transmission body that is only for fill.
    If you're missing your overflow tube, then you'll probably have to find one from a salvage yard or used parts dealer. I don't know that you can even buy automatic transmission parts from Toyota. From what I've read, dealers will change entire transmissions, but will not take one apart.
  18. Jul 3, 2019 at 11:12 AM
    Mikey02151
    2010 Tundra 5.7
    Yes I think you misunderstood. The hex plug I mentioned is the one to check the fluid level and is a couple inches higher than the drain plug. The fill plug is several inches higher and is a 24mm bolt. I'm still shocked that when I added what I took out, it overflowed from the fill port and so I'm not driving it until I sort this out.
  19. Jul 3, 2019 at 11:15 AM
    #49
    Trooper2
    JR
    I am curious as to how it got that full or what seems to be overfilled. :notsure:
  20. Jul 3, 2019 at 11:20 AM
    #50
    Mikey02151
    2010 Tundra 5.7
    Bought the truck a month ago. Looked great and runs great and has 270k miles. Was owned by a delivery comoany of some sort. So I'm doing much preventatve maintenance. Drained fluid and over 6 quarts came out. My understanding is that it should be less than a gallon when u drain. You agree?
  21. Jul 3, 2019 at 11:42 AM
    #51
    Trooper2
    JR
    Yes, always heard 2-3ish quarts drained is typical. I drained 4 1/2 quarts on my recent drain and refill. Certainly did not drain from fill plug.
    Your scenario makes me wonder if there is a check valve in the system that keeps fluid in the torque converter or en-trained elsewhere that may have failed or isn't working as it should, letting more fluid drain to the pan.
    There is a level check procedure with the truck running, transmission up to certain temp. I am not sure if you could add fluid with it running, but if not overflowing at check point then add more if needed. There are a few Youtube videos, and Tundra Talk did a really good one that I wanted to link but can't find right now.
    I am not sure you are going to get any more answers needed on here. If still an issue I would be calling Transmission shops and get some feed back. Tell them what you expected and what you experienced.
    Good Luck!
  22. Jul 3, 2019 at 12:12 PM
    #52
    Mikey02151
    2010 Tundra 5.7
    Thanks! And yes I have read all the threads on this topic and have watched all available videos. My Toyota dealership quoted me $60 to check fluid for me. Certainly worth it but I'm afraid they may be as incompetent as the person that overfilled it previously. I just don't trust other people on fluid changes. Interesting idea about the check valve allowing more fluid to the pan but haven't heard anybody else mention that.
  23. Jul 4, 2019 at 6:15 AM
    #53
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    It says change it if you tow a lot or have a lot of heavy loading. If not, it just says to check for leaking. So, if you never do any of that (which a lot of Tundra owners don't) then according to the manual it never gets changed.
  24. Jul 4, 2019 at 8:07 AM
    #54
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    That is what I did on Tacomas and plan to do on the Tundra. I shoot the outlet line at the pan with an IR thermometer. I never could get Tacos in the test mode.
  25. Jul 4, 2019 at 12:49 PM
    #55
    Mikey02151
    2010 Tundra 5.7
    Yes it was definitely overfilled by about 2 quarts or so and I finally did the proper steps to get the correct fluid level.
    Step 1.... After draining fluid and replacing drain plug, remove 5mm hex bolt...
    Step 2... Remove 24mm Fill bolt and fill until fluid comes out of that "overflow" port
    Step 3... Hand tighten that overflow port and add another quart
    Step 4.. Install paper clip on the thermostat if you have tow package
    Step 5 .. Start truck and get it to transmission temperature mode (there are links that show how)
    Step 6... When the "D" light comes on you have less than 2 minutes to get under truck and remove that hex bolt and allow excess fluid to drain until it trickles then replace bolt and you done. Truck must be running during this process.
  26. Jul 4, 2019 at 12:54 PM
    #56
    Mikey02151
    2010 Tundra 5.7
    I screwed this up a couple of times when I was not fast enough and lost too much fluid!! My helper did not tell me the "D" was blinking which means that the fluid is too hit and my window is closed.... So I drained too much fluid and I had to wait until everything cooled.... Add more fluid and do again. I feel confident this was done right and I will cancel the appointment I made with the dealer to check my transmission fluid level. Thanks all who resoonded and helped me figure this out.
  27. Jul 4, 2019 at 2:04 PM
    #57
    JohnLakeman
    So, you determined that the overflow tube was actually still there, and not removed as shown on youTube video you described? :confused:
  28. Jul 4, 2019 at 5:08 PM
    #58
    Mikey02151
    2010 Tundra 5.7
    Tundra does not have that red overflow tube. That video is a pan from a Venza. Tundra has a bump built into to the pan where that hex bolt is. I was also confused but with input from these forums and YouTube its clear now.
  29. Jul 5, 2019 at 10:03 AM
    #59
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
  30. Jun 26, 2020 at 10:46 PM
    #60
    dananderstein
    dananderstein New Member
    17tundra
    I changed my transmission fluid at 52k miles to amsoil signature series, I wish I did it earlier. The garbage Toyota was fluid was dark and I never towed anything or took my truck off road
