Transmission Drain and fill on 2016 Tundra with 125k miles?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mandrews, May 6, 2025.
  1. Jun 6, 2025 at 3:12 PM
    Bham TRD
    Bham TRD New Member
    2017 Tundra Platinum 4WD CrewMax
    I want to do a drain and fill on mine. I did one on my old GX.
    I just measured what came out, and measured how much I put in, and added just a small smidge to account for fluid left in hose, etc.
    My question is more about this particular year. The GX I did only had two bolts, drain and fill. These have three.
    So my question is, is the third bolt basically like the fill hole on the differential? Meaning if during the fill I also removed that bolt and filled it until fluid dropped out of the third bolt, would that not mark the right amount of fluid?
  2. Jun 6, 2025 at 3:28 PM
    blenton
    blenton New Member
    Kind of, but not really. The second plug on the bottom of the pan is the level check plug. There is a procedure to follow, but basically after draining and refilling, you get the transmission up to ~110F, open up the level check plug with the vehicle running, and observe the fluid that comes out for a trickle - not a drip, not a stream or a deluge, a trickle.. Make sure the truck is level. The drain plus is 14mm IRRC, the check plug is 5mm hex key.
    TheBeast likes this.
  3. Jun 6, 2025 at 8:20 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    https://youtu.be/NUAuGmDGntY
  4. Jun 6, 2025 at 8:55 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    Drain plug is 14mm
  5. Jun 6, 2025 at 9:32 PM
    blenton
    blenton New Member
    Ummm... that's what I said... :anonymous:
  6. Jun 7, 2025 at 6:54 AM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    :thumbsup:
