Transmission Drain and Fill Capacity
Discussion in '2nd Gen Tundras (2007-2013)' started by Retroboy1989, Jun 3, 2022.
  1. Jun 12, 2024 at 12:51 PM
    bikedennis
    bikedennis New Member
    Dennis
    2007 Tundra 5.7L 4WD
    You can use an infrared thermometer pointed at the bottom of the trans. pan. They will read about 5 degrees degrees low. Cost around $20-$30 on Amazon or Harbor Freight.
    Sand-man likes this.
  2. Jun 12, 2024 at 5:13 PM
    Retroboy1989
    Retroboy1989 [OP] 'Course it's 4x4!
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    I'd like to do this, if only to validate what OBD Fusion says.
    COTundie[QUOTED] likes this.
  3. Jun 12, 2024 at 8:21 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Yep. I love to see it too.
    Seems to limit all the funny variables as much as possible, going with what the truck itself is telling you.
    Dont need to know the proper temp for your tranny, don't need to worry about accuracy of your laser thermo, etc.
  4. Jan 21, 2025 at 10:56 AM
    AlexOd
    AlexOd New Member
    Idk why, but on my 18' TRD OR came out about 3.5 qt , I refill it with 4 qt, AND STILL WASNT ENOUGH.
    Changed transmission oil yesterday.
    I added about 0.6 qt more ..and after opened the overflow plug came some amount of fluid before it starts trickle.
    Aproxm I fill it with 4.2 qt.
    Does any body know, is it Factory fault that possible wasn't fill correctly ? Why i have to fill a lot more then came out.
    Truck has 59K miles. Bought truck at 19k miles.
    Btw truck shifting a lot smoother, just wow.
