Transferflow - Larger fuel tank
Discussion in 'General Tundra Discussion' started by mquimby, Feb 15, 2017.
  1. Mar 16, 2018 at 5:57 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Coachbuilder shims. I think each piece adds 1/2" of height.
    The problem, as I understand, is with all the pieces that goes with the tank. Apparently, they cost a bundle together.
    jp_over[QUOTED] likes this.
  2. Mar 18, 2018 at 6:28 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    I wonder if there was a way you could make this work, if you had a small tank, it would get you to 43 gallons.
    I guess you would have to drill a hole in the bed, to tie into the line, and then fill your truck up from this tank not the other.
    It would cost less and not hang below the frame. has my wheels spinning.
    called the titan sidekick:
    http://titanfueltanks.com/titan-sidekick-15-gal-portable-liquid-tank-5040015
  3. Mar 18, 2018 at 8:30 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
  4. Jun 22, 2018 at 9:41 AM
    DKofTampa
    DKofTampa New Member
    2014 Tundra Limited/XP
    NSV bulge light 46 Gallon Transferflow Carven exhaust Rhino 2.0 sport bar
    After reading up on everything I could, I emailed transferflow and asked them for the installation manual. Had it in a couple hours. (Along with $100 bucks off)Tank will arrive in the next couple weeks. Believe I am about done with mods (did the NSV bulge light a few weeks ago) with the exception of a suspension kit. Haven’t a clue on that..this forum has been a great source of information, will probably start here. Thanks to everybody for the quality posts.
    aperezsh and 1UPPER like this.
  5. Jun 25, 2018 at 6:21 AM
    daxinarian
    daxinarian New Member
    Neither one of those can legally be setup to transfer gasoline automatically, you would have to pull over to the side of the road, get out the siphon pump and fill up manually, at that point you might as well just stop at a gas station.
    Diesel tanks are different, since you can practically put out fires with diesel there isn't as much of a concern if during an accident an auxiliary diesel tank dumps its contents all over the place due to it's gravity feed system, gasoline is a bit more concerning. Gasoline tanks have additional requirements, including the requirement for a pump, that way if an accident occurs the tank will not drain if the pump does not have power.
  6. Aug 23, 2018 at 6:18 AM
    krice118
    krice118 New Member
  7. Sep 9, 2018 at 12:43 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Sorry, to pop this back up, but the truck I bought has the Transfer Flow on it. I didn't fill it up all the way the first time, but i put about 26 gallons in it with 1/4 tank left on the gauge. While driving, I noticed that the computer always said the same miles remaining for like 3-5 miles and would drop 1 remaining per 3-5 miles. Also, the fuel needle read full and didn't move for a VERY long time. Is there a way to calibrate the computer and gauge for the extra capacity or is it something that I will need to get used to? As it sits right now, the trip computer is useless for range calculation.
    Jrharvey02 and gosolo like this.
  8. Sep 9, 2018 at 1:49 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I suggest that you do several completely full to nearly empty cycles and then calculate mileage by hand. Once you know how many miles per gallon you actually get, you can see, and remember, what your gauge reads at the different levels. For example let’s suppose you are getting 15 mpg. Let’s leave 8 gallons in the tank for “reserve”. For every 150 miles you know you have used 10 gallons and 1/4 tank.
    300miles = 20gal = 1/2 tank.
    450miles = 30gal = 3/4 tank.
  9. Sep 9, 2018 at 2:09 PM
    GravityGear
    Aurora, CO
    Thank you sir. So it sounds like I need to just get used to it. I'll do some hand calculations then.
  10. Oct 6, 2018 at 7:06 PM
    TeknikalJo
    TeknikalJo New Member
    2014 Tundra Platinum Crewmax
    LRA 46, KN air filter
    I am very interested in a larger gas tank for my 2014 Tundra Platinum. I have read posts here in which several 2014-2017 Tundra Crewmax owners seem to have installed, or had installed the Transferflow 46 gal tank. Yet, when I go to Transferflow.com and enter "2014 Tundra Crewmax 5.5 bed" as my truck, they only show in-bed tanks available for my Tundra. I am going to call them soon (when theyand see what they can tell me, but what's up with that???
    Coolhardy likes this.
  11. Oct 6, 2018 at 7:31 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    I m interested in one too but I read somewhere on this forums that tranferflow stopped making 46 gallon tanks for Tundra.
    Guess, we need to try to do a group buy with LRA tanks.
  12. Oct 7, 2018 at 7:01 AM
    GravityGear
    Aurora, CO
    The Transfer Flow has been discontinued. LRA or OEM 38 gallon are your new options. the LRA is also 46 gallons, and some see it as superior to the Transfer Flow due to the corner not protruding below the frame rails. You can get LRA tanks from Cruiser Brothers in the USofA.
    aperezsh and TeknikalJo like this.
  13. Oct 11, 2018 at 3:45 AM
    krice118
    krice118 New Member
    contact Ward at cruiserbrothers 800-224-7801 - they are a huge Land cruiser vendor and are bringing in Longe Rante Automotive tanks
    TeknikalJo likes this.
  14. Oct 11, 2018 at 4:31 AM
    timsp8
    NY
    Had a transfer flow on my 2010. I guess the oem 38 gallon made it unprofitable for them. Really liked the 46 gallons.
    Always thought it was weird they are based in Chico, CA, but most of their products cannot be legally sold in CA.
  15. Oct 11, 2018 at 5:00 AM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
  16. Oct 11, 2018 at 6:22 AM
    GunzFC702
    GunzFC702 New Member
    Utah
    2015 Tundra TRD CrewMax
    I have a 2015 CM SR5 and this was the first mod I made. I drive across country a lot and I hate stopping every couple of hours for gas. The tank is very straight forward. I bought mine at the Toyota dealership and had them install. Took about 3 hours. It comes with everything. It is a simple plug and play. The only thing that will change is since the new tank uses the stock float your distance to empty is incorrect. You have to watch your fuel gauge. My first road trip I stopped for gas under a quarter of a tank but before the gas light came on and realized I was 720 miles in. Even towing a 26ft travel trailer I still go 325-350. Totally worth it. Have not noticed any performance issues due to the larger tank.
    I looked at the 38 gal tank upgrade that comes on the new tundras and its a big pain in the ass. Lots more parts to buy and much more expensive. You will love the tank from Transfer Flow!
    Lake.Life24 likes this.
  17. Oct 11, 2018 at 7:00 AM
    Crunch527
    Iowa
    TRD Supercharger/BAM
    You bought a Transfer Flow Tank from your Toyota dealership and they installed it? Good deal.
  18. Oct 11, 2018 at 7:20 AM
    GunzFC702
    Utah
    Yes sir. Stephen Wade Toyota in St. George Utah. I came in asking about the 38 gal upgrade and they had the 46 gal Transfer flow sitting in the service department. Talked to them about it and came in the next day and got it installed. Cost about $1400 or so.
    TheBeast and aperezsh like this.
  19. Oct 11, 2018 at 7:39 AM
    #49
    Crunch527
    Iowa
  20. Oct 23, 2018 at 6:41 PM
    #50
    TeknikalJo
    Yes, the fact is that the Transferflow 46 is no longer available. I ordered the LRA 46 from Cruiser Brothers and got a $200 Octoberfest discount! I should have it later this week or next. Can't wait!
    aperezsh, Coolhardy and gosolo like this.
  21. Oct 23, 2018 at 6:50 PM
    #51
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    If u dont mind, how much did u pay including shipping?
  22. Oct 23, 2018 at 7:12 PM
    #52
    TeknikalJo
    $1650 with shipping to Texas. But hey, it's cheaper than a new truck, and mine only has 31k miles.
  23. Nov 17, 2018 at 6:54 PM
    #53
    TeknikalJo
    OK! All done. I received the LRA 46 gallon tank a few weeks ago and completed the install today. Now, having said that, there are things you must be aware of before you decide to install this tank yourself. It was not a four hour or even a one day project for me. I grew up working in my parents auto repair shop, but at 65 I'm much more of a computer nerd than mechanic. But I do have a fair selection of tools and a good well-lit barn with a concrete floor. I did this with my Tundra on four jack stands. The wheels were barely off the ground in front and about an inch off the ground in the rear. This is just enough clearance to get the old tank out and slide the new one under the step bar. I used a couple of floor jacks to lower the old tank and raise the new one into place. My old tank had an anti-siphon device in the neck and therefore I had to drop it "wet". It still had about 4 gallons in it. The extra care this demanded took more thought and time. I followed the directions as closely as possible all the way but I found them not to be 100% accurate for every case. For instance, LRA insists that the front mount on the tank goes "on top" of the new bracket you install. This was not the case for me. With both new straps in place and tight, my front front mount is below the bracket. Woopti-doo. And the little hose that goes to the filler neck was about four inches too short. Also, the large hose that attaches the FLVV to the carbon canister MUST be routed straight back over the rear crossmember. The FLVV is very close to the crossmember so if it goes anywhere but straight back it will be kinked. This is the vent for the tank and if it is plugged or blocked you will not be able to put fuel in the tank!!! (Don't ask)
    All in all, I really have to thank Cruiser Brothers and LRA for a great product! This is a good thing, especially for older Tundras like mine, before the 38 gallon tank.
    Coolhardy and aperezsh like this.
  24. Nov 17, 2018 at 8:17 PM
    #54
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Now if u can update us if the fuel guauge is reading it right and miles u are getting on a fill up, 500+??
  25. Nov 18, 2018 at 5:22 AM
    #55
    TeknikalJo
    I'll be driving it plenty next weekend!
  26. Nov 19, 2018 at 12:36 PM
    #56
    uprvrndn
    uprvrndn New Member
    Edward
    2015 CrewMax SR5 4x4
    None
    Does it matter that I have a 15 CM Flex Fuel with the LRA Tank?
  27. Nov 19, 2018 at 5:38 PM
    #57
    TeknikalJo
    I wouldn't think so, the LRA is made from aluminized steel, it doesn't care what fuel you put in it, if that's what you're asking. Mine is a CM also.
  28. Nov 24, 2018 at 12:06 PM
    #58
    TeknikalJo
    Ok, first trip with the LRA 46 gas tank: Yes, I drove 100 miles before the gage ever came off the Full peg! All other readings are when the needle was directly over the given mark.
    Distance to come off the Full peg: 100 miles
    Distance to the Full mark: 140 miles
    Distance to the 3/4 mark: 225 miles
    Distance to the 1/2 mark: 350 miles
    Distance to the 1/4 mark: 575 miles!
    I filled up after 611 miles, it held only 36.151 gallons, so I had a LOT of gas/range left, but I found some really cheap 87 octane gas and couldn't resist. Oh, do the math, that's 16.9 mpg. This trip was 95% highway driving at 75-80 mph. And I drove another 160+ miles home after the second fill up and the results were the same so far. I've added a picture below to show the gage at just below the 1/4 mark and milage at 611 just prior to the 2nd fill up. From a user perspective, nothing is different except more fuel capacity and range. The automatic fill shutoff has worked perfectly so far. Hope this clears up some mystery and answers some questions. If you have the old 26 gallon tank, I highly recommend this upgrade whether you do it yourself or have it done by a good mechanic.
    Joe Dirt and Coolhardy like this.
  29. Mar 27, 2019 at 8:55 PM
    #59
    ginocara74
    ginocara74 New Member
    North Carolina
    2017 SR5 5.7 V8 FFE 4WD magnetic gray with front bench seat and off road package
    TRD dual exaust, TRD drop in air filter, Weather Tech rain GUARD, tri-fold bed cover
    I was just curious and wanted to ask you if you:
    1) were you able to use same fuel pump and fuel gauge sensor you had on the 26 gallon tank?
    2) any upgrade needed to fuel lines or the evaporator canister?
    3) over time did the miles to empty reading relearned and gave a more accurate reading different from the 26 gallon tank?
    I've a 17 FFV that I was told has already a bigger fuel pump then a non FFV.
    Some dealerships also mention computer reprogrammimg needed. Can you clarify some of my concerns?
    Thanks.
  30. Mar 28, 2019 at 5:59 AM
    #60
    GravityGear
    Aurora, CO
    Can't speak for the LRA, but I do have the Transferflow.
    Same pump and sensor.
    No upgrades.
    DTE does NOT relearn. On a fresh fill up, my DTE is still 300ish miles. In actuality, I have 500+.
