Transfer, front and rear diff oil
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by YotaBro, Sep 13, 2020.
  1. Sep 13, 2020 at 5:01 PM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    What oils do y'all use for the transfer case? As well as the front and rear diff?
  2. Sep 13, 2020 at 5:11 PM
    blanchard7684
    blanchard7684 New Member
    Front and rear Mobil one 75 90
    transfer case took the plunge and got Toyota 75w.
    if you look on bitog some folks did voa on it and it has a distinct additive package.
  3. Sep 13, 2020 at 5:17 PM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
  4. Sep 19, 2020 at 8:04 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Schaeffers for front and rear diff, ravenol for the transfer case.
    Bravohook likes this.
  5. Sep 19, 2020 at 8:07 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    RedLine 75w85 for the front and rear differentials and Toyota 75w for the transfer case.
    skylinekin and Ely010606 like this.
  6. Sep 19, 2020 at 10:13 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    X2, used the same thing for mine
  7. Nov 27, 2020 at 7:01 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    My 2019 4x4 Sport has 16,2xx miles and I’m the only owner. The last 3K-4K miles when I would get to highway speeds and let off the throttle and then get back on the throttle there has been a slight hesitation and a light jolt and clunk sound. I figured it was my rear differential. Tonight I drained the rear differential and the gear oil was a very dark chocolate colored brown. I am working with lights because the sun has went down. Nonetheless, I was shocked to see the poor shape of the factory fill. The magnetic drain plug of course was maxed out and could not hold any additional metal particles and there was a lot of metal sparkle in the oil drain pan after dumping it at AutoZone. I refilled with nearly 4 quarts of Mobil 1 75W-90 Synthetic. Put 100 miles on the fresh oil and it drives like it should and the jolt and clunk are now gone. For what it is worth, I haven’t towed anything, nor I have I pushed the payload.
    Here is my learning, CHANGE the rear differential oil every 15,000 miles. I wish I would’ve done this at 10,000 miles.
    -George
  8. Nov 27, 2020 at 9:28 PM
    skylinekin
    skylinekin New Member
    Michigan
    2021 Tundra DC TRD PRO (Current), 2014 Tundra SR5 DC TRD OR (Sold)
    Also, if your doing a lot of DIY drivetrain fluid changes it’s worth investing in the motive powerfill pump. As others mentioned can’t go wrong with OEM 75w transfer case fluid and redline 75w85 Diff fluid.
