Transfer case
Discussion in '2.5 Gen Tundras (2014-2021)' started by Animal0622, Nov 20, 2020.
  1. Nov 20, 2020 at 6:43 AM
    Animal0622
    Animal0622 [OP] New Member
    2018 Tundra Offroad 4x4
    3" level kit Bilstein shocks ARB front bumper 33x12.50 Toyo AT2 tires
    What type of oil is best for my transfer case and is it the same oil for front and rear differential?
  2. Nov 20, 2020 at 7:24 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It will be listed in your owners manual. Generally for 3rd gen- 75W or 75-90. Check your owners manual to confirm.
  3. Nov 20, 2020 at 5:11 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Use 75w-90 for the front and rear differential and 75w for the transfer case.
    Did a lot of research and used Ravenol for the transfer case. Awesome product!
    https://smile.amazon.com/dp/B00QPCL7ZE/ref=cm_sw_r_cp_apa_fabt1_-HgUFbRATTMFH?_encoding=UTF8&psc=1
    Used Redline for the front and rear differentials. (Couldn't get Ravenol in this weight at the time, but you could use it instead of Redline.)
    https://smile.amazon.com/dp/B000CPCBF0/ref=cm_sw_r_cp_apa_fabt1_eLgUFbEMRPQ3B
  4. Nov 20, 2020 at 5:56 PM
    Animal0622
    I appreciate it. I just picked up a DV8 3 piece offroad bumper but there are no assembly instructions in box with it anyone have any advice?
