Transfer Case Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by vanthesupreme, Oct 13, 2020.
  1. Aug 26, 2021 at 10:45 AM
    #61
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My tundra has 226k running 75w Ravenol in the transfer case, and I use 4wd quite a lot, it shifts quickly and effortlessly. And I live in the south where it's hot, like really hot.... hotter than this argument. I guarantee it'll go well past 500k on this brand and weight of oil, probably even last the life of the truck
    So if we're talking long term, I believe I have alot of people here beat on 3rd gen mileage.
    Ravenol is cheap, it works, and it has the coolest spout of any bottle I've ever used.
    DZ_, COTundra23, 15whtrd and 4 others like this.
  2. Aug 26, 2021 at 11:01 AM
    #62
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    +1 on the bottle spout, super cool and really effective !
    Sumo91[QUOTED] likes this.
  3. Aug 26, 2021 at 3:07 PM
    #63
    737fixer
    737fixer New Member
    Use either the Toyota 75w or the Ravenol 75w at your choice. The manual states you can use equivalents for certain fluids listed. For the transmission and transfer case they don't. Not sure where people start talking about completely different weights being OK. Mindboggling. I use the Ravenol cause the spout is amazing for our transfer cases. BUT, and this is a huge BUT. The MOST important maintenance item with our transfer cases is to use them. Every month at least find a nice straight piece of road and switch 4WD on/off a few times. The biggest failure point we have is the actuator. If it gets used on a regular basis it no longer becomes a failure point. If you have not done this in a year you will immediately notice it having trouble going both in and especially out of 4WD. After you use it a few times it will get better. Just be aware that you don't want to be turning the wheel in 4WD on pavement. Again, slight adjustments are perfectly fine even though some will say cause they once heard that a friends sisters cousin babydaddy had his truck explode doing this. Not true. Completely can't happen. The best part about these forums is the never ending list of crap people say cause they once heard it from someone. I jumped off a cliff and didn't die therefore.......
  4. Nov 26, 2021 at 1:23 PM
    #64
    sgtfluffy16
    sgtfluffy16 New Member
    Corey
    2019 Super White Tunda TRDPro
    Stock
    was actually wondering the same question. Why can't i put the same fluid in the rear/front diff as the transfer case. I plan to run this in my 2019. is your fluid in your 2020 transfer case a friction modifier added as well?
    https://www.redlineoil.com/75w85-gl-5-gear-oil
    or ill run this because i have both of these already at home. https://www.redlineoil.com/75w90-ns-gl-5-gear-oil
  5. Dec 3, 2021 at 11:45 AM
    #65
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Sorry for the late reply. I don't believe the Amsoil 75W9 Severe Gear has a friction modifier added. Someone might know for certain, but I'll have to check and get back to you.
  6. Dec 5, 2021 at 11:43 PM
    #66
    engineer
    engineer Drive it 4ever
    Seattle, WA
    '21 Limited Double Cab
    My (2021) owner's manual says equivalent gear oil is acceptable for the transfer case. And Ravenol says it's applicable, so that's good enough for me. I'm ordering from the Blauparts site, because it's cheaper than Amazon... See the pictures.
    Thanks for the discussion. I received my cat plates from Valhalla's today, and decided I better change all the fluids first. FWIW I ordered the Red Line 50104 75W85 GL-5 Gear Oil for the differentials.
    shamrock246, WILLINH and Ely010606 like this.
  7. Dec 6, 2021 at 9:41 PM
    #67
    engineer
    Seattle, WA
    Wallygator and WILLINH like this.
  8. Dec 15, 2021 at 5:42 AM
    #68
    737fixer
    737fixer New Member
    Sorry about that. Your absolutely correct. Kinda wondering where I got the info or just misread it. Thanks for correcting me.
  9. Dec 25, 2021 at 10:03 PM
    #69
    badmotofing3r
    badmotofing3r To be so civilized, one must tell civil lies
    Zach
    Wyoming
    Hot Tamale
    Toytec lift and the works
    Been using the Ravenol for over 4 years now in my '14. No issues so far.
    shamrock246 likes this.
  10. Dec 25, 2021 at 10:28 PM
    #70
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I would think that any fluid with the viscosity rating of 75W would be the same “thickness” since that rating of 75-weight is a resistance to flow measurement. I am not an engineer or chemist but I was taught in high school shop class many years ago that these ratings are measurements of ‘resistance to flow’ but most people refer to as thickness. So what I am confused about is how 75w is 4x thinner than 75w-90.
  11. Jan 24, 2022 at 9:48 AM
    #71
    TSS_Tundra
    TSS_Tundra New Member
    200k Tundra
    I purchased a 2014 with 203k miles and do not know the history therefor I did all fluids so I have a history starting from my purchase.
    I decided to spend a few extra bucks and purchased the Revenol since I will not have to change it again anytime soon.
    Glad I did! I found the drain and filler on the transfer case finger tight as well as the skid plate!
    When I removed the filler I stuck my finger in and could not touch any oil! I then stuck a fluid extractor in there and could barely get anything!
    I think it "may" have been half full?
    I did not measure what came out of it because it would piss me off!
    You guys talk about how fast your trucks go into 4x4 with different oils, I can safely say mine goes in to 4x4 much faster "WITH OIL IN IT"!
    Fortunately the fluids were fine in everything else.
    Just another good reason to do maintenance like this YOURSELF!
    coldcanuk and Wallygator like this.
  12. Jan 24, 2022 at 1:42 PM
    #72
    Wallygator
    So true! Eventually I will have to hobble into the dealership waiting room, grab some "free" coffee, and read sales brochures until my vehicle is done...but that hopefully won't be happening anytime soon!
    Plus I find it fun to do it all myself and then I know it's done right. Also you may discover other issues that needs addressed.
    TSS_Tundra[QUOTED] likes this.
  13. Apr 20, 2023 at 11:25 AM
    #73
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Not to grave dig an old thread but my buddy who is a Toyota Tech said they are not even using Toyota Fluids to do the Transfer Case and diffs. Said they are using Valvoline or Penzoil, which ever the dealer can get for less. 75w85 in all three!
  14. Apr 20, 2023 at 11:27 AM
    #74
    AZBoatHauler
    AZBoatHauler SSEM#140/ASCM#3/2ndGenNaysayer/BAF140
    So.Arizona
    Exactly the reason I do my own service. I’m sure they’re still charging Toyota oil prices.
    :spending:
  15. Apr 20, 2023 at 11:35 AM
    #75
    sgtfluffy16
    Corey
    Stock
    If you want a real good laugh I can give you one. Because the rear end is a auto locking and not an actual limited slip diff and does not need the friction modifier. I actually use the same Red Line fluid 75w90 NS that I put in my Porsche is the same that I put in the tundra, in the front diff, rear diff, and transfer case
    reywcms and bmw345 like this.
  16. Apr 20, 2023 at 11:58 AM
    #76
    bmw345
    bmw345 New Member
    CT
    I ordered 75w90 Amsoil for the diffs, gonna snag some regular valvoline synthetic 75w85 for the T-case.
  17. Apr 20, 2023 at 2:00 PM
    #77
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    Agree 100%. Don’t trust anyone except yourself
    Rob's Inferno and WILLINH like this.
  18. Apr 20, 2023 at 4:45 PM
    #78
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Call 3 different Toyota service or parts departments. They'll all give you a different answer for what to put in the diffs and transfer case. Call the people that made the diffs and transfer case anf theyll tell you something else.
    I don't think it makes much difference other than mpgs.
  19. Apr 20, 2023 at 6:03 PM
    #79
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Recently changed both diffs with Amsoil severe gear and did the TCase with Ravenol. Coolest thing to me was how easy the product packaging made squirting the oil into each fill port.
    Wallygator, sgtfluffy16 and coldcanuk like this.
  20. Apr 20, 2023 at 6:27 PM
    #80
    FO LO
    FO LO New Member
    With or without LS additive??
  21. Apr 20, 2023 at 7:24 PM
    #81
    sgtfluffy16
    Corey
    Stock
    Since his signature says he owns a 21 Tundra I would hope without limited slip additive.
  22. Apr 21, 2023 at 9:44 AM
    #82
    kevine0001
    kevine0001 New Member
    Kevin
    Just sent a screen shot of this to my cousin who worked as a Toyota dealer tech for decades. He said same thing: "unless customer requests expensive stuff, you don't get it. you'll pay extra for service to use it. we always just use whatever synthetic 75/85 is cheapest/available, same with bulk oil"
    So if you want the Toyota 75W, either do it yourself or specifically request it. And if you can't see them do the oil change, ask for the empty containers. I put the Ravenol 75W in mine. About 1/4 the price of toyota's and haven't had any issues in a couple years/15k miles
  23. Apr 21, 2023 at 10:54 AM
    #83
    FO LO
    FO LO New Member
    Yeah, I'm surprised how many folks overlook that
  24. Apr 21, 2023 at 7:03 PM
    #84
    DFW
    2021 Limited 4x4
    The other guy who said something about getting Amsoil for the diffs has an 18, I also mentioned getting Amsoil and have the 21. I did not get the oil with the LS additive although I seem to remember reading somewhere that it wouldn't hurt anything but would be a waste. Anyhow, I just used the regular Amsoil Severe Gear.
  25. Apr 21, 2023 at 8:05 PM
    #85
    sgtfluffy16
    Corey
    Stock
    I believe in the 2017 they started putting the auto limited slip diff in which is an open carrier but they use the ABS to attempt to make it a limited slip diff.
  26. Apr 22, 2023 at 1:12 AM
    #86
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    It was before that my 2014 has the craptastic electronic auto limited slip
  27. Apr 22, 2023 at 9:44 AM
    #87
    FO LO
    FO LO New Member
    Nothing like the feeling of computerized traction shuddering up a slick boat ramp. Chev wins
