Transfer Case Oil Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by vanthesupreme, Oct 13, 2020.
  1. Oct 13, 2020 at 8:45 AM
    vanthesupreme
    vanthesupreme [OP] I'm Batman
    OKlahoma
    2014 Tundra
    I have looked at other threads on changing the diff fluid along with the transfer case. I have also watched a few YouTube videos on the process, but I an needing to know if the transfer case can use 75w-90 gear oil just like the rest of the diff fluids or if I need to use just 75w? The one youtube video I watched the guy used 75w-90 in the transfer. All input will be greatly appreciated and thanks in advance
  2. Oct 13, 2020 at 9:10 AM
    duerrs
    duerrs Semper Fi!
    2008 Tundra TRD Off Road & 2020 Tundra TRD Pro
    Wondering the same thing. On my 2008, I put Royal Purple 75W90 in all three. On my 2020, I've put Amsoil 75W90 in front and rear but not the transfer yet. I'm told they made a change to the transfer case in 2014 or some MY after that. Amsoil has no recommended oil for this yet.
    vanthesupreme[OP] likes this.
  3. Oct 13, 2020 at 9:14 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have all my stuff being delivered today (supposedly) to change out my front/rear diff and my transfer case. I'm using Mobil 1 Sythetic 75w-90. A few places I've found have all said that using that is completely fine. Now, per manual, specs, etc...they all say straight 75. I mentioned it to my dad yesterday actually that has owned a shop for 35+ years and said it is fine to do that. This is no means professional advice, but if it makes you feel better, I did my job. :cheers:
    vanthesupreme[OP] and 406Michael like this.
  4. Oct 13, 2020 at 9:18 AM
    AZBoatHauler
    So.Arizona
  5. Oct 13, 2020 at 10:44 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    yes. I put Lucas synthetic in all three.
    75w90
  6. Oct 13, 2020 at 12:11 PM
    vanthesupreme
    OKlahoma
    2014 Tundra
    Thank you all for your input greatly appreciated!!
  7. Oct 13, 2020 at 12:55 PM
    OTX
    OTX 2018 Tundra SR5 Off-road Crewmax 4x4
    Eddy
    North Chicago, Illinois
    I have been going back and forth about what oil to use on my 2018 Tundra transfer case. From my research, 75w90 is not really suitable as it’s much thicker than the 75w oil Toyota uses. Then you have Ravenol which is a 75w oil but from what I have researched is also quite different from the Toyota fluid when an oil analysis was done.
    I decided to get the original Toyota 75w oil and not chance it. It hurt paying $125 for 2 quarts of this stuff but when it only has to be changed every 60,000 miles, it’s worth it. A transfer case cost about $2800!!!. For the front and rear, I went ahead and put in 75w90 Mobil oil. My advice is go for the real deal as there is no real substitute for it!.
  8. Oct 17, 2020 at 7:47 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I bought and used Toyota 75w .truck is still under warranty so.And when i change the t case at 35000miles ,fluid looked as clean as the brand new fluid
  9. Oct 17, 2020 at 9:30 AM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    $125 for 2 quarts is asinine. Next time get
    https://www.blauparts.com/ravenol-manual-transmission-fluid-mtf-3-75w-1l.html
  10. Oct 17, 2020 at 9:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I changed Tacoma at 50k and same thing. Unless you do a lot of driving in 4wd it is not going to look dirty. I am not changing it in my Tundra.
  11. Oct 17, 2020 at 10:24 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Use the Toyota 75 weight oil. It has additives that prevent solenoid stick. Many people have changed it with a different oil and have had problems with shifting between two and 4 wheel drive. And then it not wanting to disengage.
  12. Oct 17, 2020 at 10:35 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
  13. Oct 17, 2020 at 1:55 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’ve been using redline mt-Lv for about 10k miles, it has worked flawlessly, shifts the same as stock, and its synthetic.
    coldcanuk and vanthesupreme[OP] like this.
  14. Oct 17, 2020 at 5:08 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Ravenol 75w works great in mine, I'm in 4wd a few times a month at least and I drive the piss outta my truck
  15. Oct 17, 2020 at 7:33 PM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    I knocked mine out this weekend with a lil helo from my dad since he was helping me do brakes. Not difficult, but I forgot how much gear oil stinks. When I did the transfer case, it had more velocity than expected and got it on my clothes. They were trash clothes anyway, but it had the gear oil stank on it ha. All 3 were easy to do tho. We'll see how the transfer case does with mobil 1 75-90
  16. Oct 17, 2020 at 8:37 PM
    OTX
    Eddy
    I ended up changing the transfer case fluid today in less than 20 minutes(mostly just waiting for it to drain). I am not a car guy whatsoever and I couldn’t believe how easy it was to do even without the truck being jacked up. Just take off the fill plug first and then do the same with the drain and let it drain for 10 minutes or so and then I put the Toyota 75w fluid in using a transfer fluid pump. Super easy.
    Fotnot likes this.
  17. Jul 23, 2021 at 3:07 PM
    Basso1964
    Basso1964 New Member
    Richard
    Regina, SK Canada. The Ice Planet!!
    2016 Tundra Platinum TRD Pro kit
    Trd Pro exhaust, suspension, stabilizer, rims. Rhino Bar Hella Rallye 4000 HIDs Rhino side steps Mcrtuning led tray lights Oem tri fold tonneau Dasaita 13.3 head unit
    I just rang Toyota in Regina Canada, they actually use 75-90 in the transfer case. So now I am going with Mobil 1 the whole way. Walmart has 12 bottles for 175!
    equin likes this.
  18. Jul 23, 2021 at 5:17 PM
    Unclebuck
    Unclebuck New Member
    2018 Crewmax SR5 TRD Offroad
  19. Jul 26, 2021 at 9:22 AM
    Basso1964
    Richard
    Thanks Mate!
  20. Jul 26, 2021 at 10:23 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    These are wise words. I would stop visiting any dealership using 75-90 in this transfer case.
  21. Jul 26, 2021 at 11:51 AM
    duerrs
    duerrs Semper Fi!
    I disagree. My local dealer also uses 75-90 or GL5 in all 2014's and up. I decided to use the Amsoil 75w90 Severe Gear in my 2020 transfer case just like I used in the front and rear diffs. Believe it or not, the truck engages and disengages 4WD quicker since the change! 42,000 miles and two winters with no problems. I'm not worried at all about my decision. If this was an issue, there wouldn't be as many dealers using the same gear oil in all three as we keep hearing about.
    jordoncloutier likes this.
  22. Jul 26, 2021 at 11:57 AM
    AZBoatHauler
    So.Arizona
    So you took the gear oil out of the transfer case on a brand new truck and replaced it with 75-90? Why?
    15whtrd likes this.
  23. Jul 26, 2021 at 12:03 PM
    duerrs
    duerrs Semper Fi!
    Yep...converted most of the truck over to Amsoil. Engine, transmission (partially so far - 6 quart drain/fill), diffs, transfer case and power steering fluid. Only thing I haven't changed is brake fluid and coolant. Plan on keeping this truck for a very long time and believe in the Amsoil product. To each their own as they say! ;)
  24. Jul 26, 2021 at 12:10 PM
    crewmaxlmt
    scott
    If you plan on keeping your truck for a long time, you might want to switch the transfer case back to 75W. These transfer cases do not use a gear lube. These use an advanced fully synthetic oil formulated by Toyota for transfer cases.
    I used to think that all gear lubes were the same then I started my research into swapping out both of my differentials. Oil thickness, too slippery, not slippery enough, additive, or no additive; it all matters. For instance, I could not use Amsoil with the differential that I am putting in my truck. It would not work properly since it has too much lubricity.
    15whtrd, AZBoatHauler and Ely010606 like this.
  25. Jul 26, 2021 at 12:20 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I was in the same boat also. I was going to use the 75w90 for my TCase since I’m using that for my front and rear diff. I backed out and ended up buying the 75W, it sure freakin cost more for 2 cans but I have the peace of mind.
    coldcanuk and crewmaxlmt like this.
  26. Jul 26, 2021 at 12:30 PM
    duerrs
    duerrs Semper Fi!
    Whatever lets you sleep at night. I sleep better knowing I have Amsoil in mine. Plus, as mentioned, it shifts to/from 4WD quicker than the 75W that it came with.
    I'll keep you updated as to whether or not I have problems. I plan on putting over 500,000 on this truck! :fingerscrossed:
  27. Jul 26, 2021 at 12:33 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    I've used Amsoil severe gear 75w90 in my 2019 CM transfer case without any issue , just did a fluid change last week , decided to give Royal Purple Syncromax a try. its spec'd to be a suitable replacement for toyota's 75w oil . plus its way cheaper too . So far no change in performance between the 2 fluids . lets not over think this subject .
    COTundra23, duerrs and Ely010606 like this.
  28. Jul 26, 2021 at 12:36 PM
    Unclebuck
    If there are additives -
    Its a friggin' transfer case, not a human heart requiring the proper blood type and rh factor to work. Even Toyota accepts that 75w-90 is acceptable. FFS - I never would have guessed that TC oil would become the "whats the best oil" argument. It is gears and chains, not a internal combustion engine.
    duerrs and jordoncloutier like this.
  29. Jul 26, 2021 at 12:52 PM
    crewmaxlmt
    scott
    Not just gears and chains on this one. FWIW, my last three 4x4's dating back to the 90's used ATF not gear oil. I believe the lighter ATF is used for better heat dissipation.
  30. Jul 26, 2021 at 1:31 PM
    Unclebuck
    So these TCs need ATF and not gear oil. Good to know
