Transfer case fluid after 59k w/pics
Discussion in 'General Tundra Discussion' started by Sumo91, Feb 11, 2022.
  1. Feb 11, 2022 at 5:14 PM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Got around to changing my transfer case fluid today while I had time and the weather was nice. It has 59,345 miles on it. It is Ravenol 75w.
    It came out much much darker than I was expecting, especially since I just changed my rear diff at 58k miles and it looked and smelled great.
    This fluid was dark, smelled like used gear oil, and I never plan to use Ravenol again. I LOVE high quality oil. And it seemed Ravenol was a good fit for my transfer case when I researched it. But it did not meet my expectations. The Schaeffers I used in my front and rear diff still looks great after the same mileage. This is a good example of quality oil and subpar, regular oil.
    I filled the transfer case with High Performance Lubricants 75w. I know this is great oil, and I'll be doing a sample at roughly 50k miles to send to Blackstone. Anywho, here's pictures of the used oil and new oil, cause thats what yall wanna see.
    20220211_135320.jpg 20220211_135325.jpg 20220211_135335.jpg 20220211_140630.jpg
  2. Feb 11, 2022 at 5:16 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    How long ago did you put the Ravenol in it? How often do you use 4wd?
    Since it's a small amount of oil I plan to stick with the Toyota stuff for the t case.
    Mike59, Ely010606 and Sumo91[OP] like this.
  3. Feb 11, 2022 at 5:27 PM
    Sumo91
    TN
    12/2019
    I use 4wd quite a bit, and also used it under load while towing my 8k camper. This level of varnish is unacceptable in an enclosed gearbox for a "synthetic" oil. I guess Ravenol was cheap for a reason. I will say I never had and issues shifting into or out of 4x4, but I expected much cleaner oil than what came out. The front and rear diff fluid looked great, and it was all changed at the same time, but the Ravenol was the only odd ball fluid I used. I know the new 75w from HPL will perform to my expectations, so no worries from here on out.
    I just wanted to post my experience with Ravenol. I will say it did its job, and if you're running shorter intervals then by all means use it. I just want the best of the best when it comes to oil, because we all need a hobby right? :rofl:
  4. Feb 11, 2022 at 5:47 PM
    MadMaxCanon
    Did it look much worse than the Toyota stuff that was originally in it?
  5. Feb 11, 2022 at 6:01 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    I used the OEM, when i did my t-case.
    MadMaxCanon[QUOTED] likes this.
  6. Feb 11, 2022 at 6:04 PM
    MadMaxCanon
    Ya at less than 2 qts I can swing the cost.
    Ely010606[QUOTED] likes this.
  7. Feb 11, 2022 at 6:05 PM
    Damn DJ…how many miles was on that 75w?
    Sumo91[OP] likes this.
  8. Feb 11, 2022 at 6:17 PM
    Sumo91
    TN
    I think it had 75-90w from the PO when I got it, it didn't look too bad, but I think it was serviced recently before I bought it.
    59,345 miles. I changed all the fluids shortly after I bought the truck in November 2019, so the fluids were changed in December 2019.
    I just don't think the Ravenol is a quality oil just based on visual results. I'll be sending it into blackstone for analysis, because it has me really curious.
    Dirtytruck, Mike59, TTund16 and 2 others like this.
  9. Mar 20, 2022 at 3:12 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Can you tell me where you bought the HPL fluid, I can’t seem to find it. I have 57,000 on the truck and it’s time to do change it. Thank you
    Sumo91[QUOTED][OP] likes this.
  10. Mar 20, 2022 at 3:17 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Do you still have the UOS? Can you send it to Blackstone or Amsoil for a UOA, curious minds would love to know.
    *edit - nvm saw you were going to send it. By chance going to send any virgin OS's?
  11. Mar 20, 2022 at 3:53 PM
    Sumo91
    TN
    Here is the link to their products.
    https://www.advlubrication.com/collections/automotive-lubricants
    If you need 75w, shoot them an email and they can make a batch for you. But they probably have some leftover from when they made my 75w for me.
    WILLINH[QUOTED] likes this.
  12. Mar 20, 2022 at 3:55 PM
    Sumo91
    TN
    Itll be a few months before I get around to sending it. Moving right now so everything is getting packed up. I believe you can find the VOA on the Ravenol 75w on BITOG.
    14burrito[QUOTED] likes this.
  13. Mar 20, 2022 at 4:09 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
  14. Mar 20, 2022 at 4:27 PM
    Sumo91
    TN
    DeesCrewMax and badmotofing3r like this.
  15. Mar 22, 2022 at 6:01 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Should do it’s job as intended… was your first change at 59k?
    Reason I ask is because I’m about to do my tcase with ravenol 75w.
  16. Mar 22, 2022 at 6:11 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Terndrerrr likes this.
  17. Mar 22, 2022 at 6:59 PM
    Sumo91
    TN
  18. Mar 22, 2022 at 7:06 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Geezus, that second report of the OEM 75w…
  19. Mar 22, 2022 at 7:07 PM
    Wallygator
  20. Mar 22, 2022 at 7:08 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
  21. Mar 22, 2022 at 7:12 PM
    Wallygator
  22. Mar 22, 2022 at 7:16 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I like Royal Purple. Probably what I'll run when I get around to the T-case.
    Been running the syncromax in the Trans of my old 5 series for the last 60k and have been very happy. 5 ratios (+1) and synchronizers are still smooth after almost 340k miles
    Wallygator[QUOTED] likes this.
  23. Mar 22, 2022 at 7:27 PM
    Wallygator
    I ran it in my 4Runners T-case also, works well and a lot cheaper than OEM. I run Amsoil in the diffs.
  24. Mar 22, 2022 at 8:16 PM
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I wish I knew what I was looking at here. How does one read this report?
    Kgfit85 likes this.
  25. Mar 22, 2022 at 8:44 PM
    Sumo91
    TN
    eccracer104[QUOTED] likes this.
  26. Mar 23, 2022 at 9:50 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    So I talked to my friend at Toyota parts and he said they only use 75-90 GL5 in the differentials and transfer case. He said the 75w and 75-85w are not synthetic but plain old conventional fluid.
    I did check with 2 other dealers and they said the same thing. They only use 75w if it is a warranty work. I have also read by other members here that is what they use.
    Punisher1 likes this.
  27. May 8, 2022 at 2:00 PM
    Punisher1
    Punisher1 New Member
    Dale
    2020 Tundra TRD PRO
    285/75R18 Goodyear Duratracs
    I've heard this too from a Toyota Mech and was just planning to use my Amsoil 75W90 to change my TC oil but reading one of these threads caused me to pause for a little to make sure. One thread stated something about 75W90 making it hard to switch into and out of 4X4.
  28. May 8, 2022 at 5:11 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Wallygator likes this.
  29. May 8, 2022 at 6:33 PM
    Piki
    Piki New Member
    2017 Tundra crewmax 1794 TRD
    You should change your T Case oil every 30K
    Severe conditions every 15K
    07DCLimited likes this.
  30. May 8, 2022 at 7:24 PM
    Sumo91
    TN
    The manual calls for inspection of fluid at 30k or replace at 30k for severe use. Where did you see it needed to be changed at 15k for severe use?
    Wallygator, Terndrerrr and 14burrito like this.
