Trans flush - Too late?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WalnutWest, May 4, 2023.
  1. May 11, 2023 at 3:50 AM
    #61
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    I do all my own work, but this trans fluid swap with jumping pins, getting fluid to right temp, etc seems a bit wonky, and I am considering having the dealer do a full fluid swap without a cleaner and flush. If I can't find one to do that, I'll do a drain and fill every 20-30K. I think I may want to swap out the pan bolts for SS for a future filter change.
  2. May 11, 2023 at 4:31 AM
    #62
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Drain, measure, fill in the same quantity. I was experimenting with fluid levels on a twice smaller Aisin transmission, it started to see first signs of problems 1/2 quart underfilled or 1 full quart overfilled. On Tundra I did two d&f, never checked the temperature.
    Bulldog9[QUOTED] likes this.
  3. May 11, 2023 at 7:10 AM
    #63
    CTundraForMe
    CTundraForMe New Member
    This as well. It seems like quite the ordeal, unless you have your own shop.
  4. May 11, 2023 at 8:27 AM
    #64
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    If you get an OBD tool like the OBDLink MX+ you can see the transmission pan temp and not have to do the jumping pins/shift method and makes the process much easier. It sounds complicated but its really not. Drain the pan, pump in 4 quarts, start the truck, watch the transmission pan temp while laying under the truck on your phone, when it gets to 99°-111°F, open the check bolt, let it slow to a trickle. Put check bolt in, now your done, if nothing came out the check bolt, pump some more in and do the procedure again. Once you do it a couple times its not hard at all.
    yakeng and Jaypown like this.
  5. May 11, 2023 at 9:34 AM
    #65
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I disconnected the return line and drained 3 qts at a time.
  6. May 15, 2023 at 8:53 AM
    #66
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Agreed. This is a pretty easy procedure, anyone who can change their oil can do this. Cycle through the gears to get it to warm up. I break loose the fill and check plug before draining/starting and have my tools laid out ahead of time, as it does heat up rather quickly. I used the OBDFusion app for the temperature check. I used a paint measuring cup from ACE to see how much I drained to better know how much to add back, but that isn't necessary.
    Also, the style of pump that attaches straight to the ATF bottles is kind of a pain to use and you'll get a bit fatigued using it after a couple of quarts. I recommend one of those fluid transfer style pumps or an ATF specific pump if you don't mind paying the extra cost.
    Joe333x[QUOTED] likes this.
