Trans Cooler added but took no Fluid
Discussion in '2.5 Gen Tundras (2014-2021)' started by nasher75, Jul 16, 2025.
  1. Jul 20, 2025 at 3:29 AM
    SoTexTundra
    SoTexTundra New Member
    19 DC TRD OFF-ROAD
    I as well noticed some strange behavior in my shifting after I did my dnf and wonder if I need to add a bit more fluid to mine like maybe a 1/4 to 1/2 quart more.
  2. Jul 20, 2025 at 8:18 PM
    2020_Tundra
    2020_Tundra New Member
    2020 MGM Platinum Tundra
    MHX cooler documentation states the inlet is on the bottom with horizontal plumbing. With Hayden the inlet can be at the top or bottom, however, prone to having air trapped in the cooler if the inlet is at the top or if the inlet and outlet are both at the bottom.
    Also, the thermostat needs to be pinned when you do the level check to ensure transmission fluid is actively flowing through and filling the cooler.
    joseph_womack likes this.
  3. Jul 21, 2025 at 6:24 AM
    Chip_Tundra
    Chip_Tundra New Member
    I have this cooler and ran the inlet on top with no issues. I recently switched to the suggested method and saw no real difference in performance. Either way, this cooler performs as it should
  4. Jul 21, 2025 at 6:44 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    TC convertor spikes are normal. It’s converting energy which intern creates heat. Pan and tc temps will fluctuate from each other but when tc is locked that temp will decrease as normal.
