Tranny oil
Discussion in '2nd Gen Tundras (2007-2013)' started by Jorg4709, May 13, 2022.
  1. May 13, 2022 at 9:01 AM
    Jorg4709
    Jorg4709 [OP] New Member
    Jorge
    Toyota Túndra 2008
    How easy is change the filter and tranny oil on a 5.7? Any recommendations?
  2. May 14, 2022 at 6:26 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    No need to change the filter. It's good for the life of the vehicle. As far as fluid, most people do a drain and fill of the pan, about 4 qts. I drain and fill the pan, then pump out 2qts at a time from the cooler return line until it comes out looking new. Anywhere from 12-16qts total.
  3. May 26, 2022 at 10:55 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Don't pull the trans pan if the truck has spent years on salty roads or if the bolts look corroded. You'll be in for a bad day if you start snapping bolt heads off.
    Check this video out
    baraynavab likes this.
  4. May 27, 2022 at 6:59 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    I agree with @Tbrandt if your truck is nothern truck don't even think about dropping the pan. Just a drain and fill. Also make sure you use the Toyota oem transmission fluid. And follow the exact procedure to drain the transmission oil.
  5. May 28, 2022 at 12:40 PM
    Dr_Al
    Dr_Al New Member
    Al
    Some of the bolts are blind and will come out without much fuss even in the rusty states. The ones that you can see the ends of are the problem ones. With a little work they can be coaxed out. But you'll want to remove the rust on the threads and soak them a couple of times over the week before you try to remove them. I've replaced mine with stainless bolts so if they ever need to come out again it'll be easy.
    WVI likes this.
