Tranny issues
Discussion in '1st Gen Tundras (2000-2006)' started by kodyquist21, Jun 15, 2020.
  1. Jun 15, 2020 at 6:34 PM
    kodyquist21
    kodyquist21 [OP] stay low, stay frosty
    Kody
    Buckeye, AZ
    2006 Toyota Tundra DC SR5
    Hey everyone. I was driving down the road today and I heard a weird metal grinding sound and it stopped really quick. I stop at a red light and then I hear it again. It sounds like a brake pad but then as the light turns green I hit the acceleration and it revs up super high but took forever to actually move. I pull off into a parking lot and try switching gears. It wouldn’t move in reverse nor drive. I turned it off and check my tranny fluid which was full. I turn it back on and put it into low gear and it moved and then I put it back into drive and it moved just fine. I got all the way home with no issues. However I parked it and tried putting it in reverse but it wouldn’t budge. It’s clearly the transmission but has anyone witnessed this before and fixed it ?
  2. Jun 15, 2020 at 7:39 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
  3. Jun 15, 2020 at 7:41 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    That’s kinda what happened on a Camry my sister had, haha out in the woods of corse. But towed it to a trannys shop and said the tranny was bad bla bla. Dolly towed it home, dropped the pan, replaced the filter screen and pan gasket, filled it, it ran great but my dad sold it immediately
  4. Jun 15, 2020 at 7:42 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
  5. Jun 16, 2020 at 4:27 AM
    Professional Hand Model
    Hand Protectors
    Doesn’t sound good based on hearing this same story from others. Could be catastrophic failure inside. Suggest taking it to a Transmission Specialist. They can rebuild it BETTER than new for $3-4k or you can take a chance and buy a used junkyard one and drop it in for $1-1.5k. Rolling dice.
    kodyquist21[OP] likes this.
  6. Jun 16, 2020 at 4:35 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I have a 95 4Runner, when I bought it I changed all the fluids. I took it somewhere and did the transmission flush thing where they hook it to a machine and swap all the fluid while it’s running. Had same issues as you w transmission after that. I dropped the pan and changed the filter, filled it back up s Walmart brand fluid. Haven’t had any issues w it since. Before you dump a bunch of money into it, try dropping the pan and replacing the filter. It’ll be a little messy but only cost you a gasket/filter kit and a few quarts of fluid.
  7. Jun 16, 2020 at 4:49 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Fresh fluid and cross your fingers.
    bmf4069 likes this.
  8. Jun 16, 2020 at 5:13 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, that sucks. Mine did the exact same thing, but it was low on tranny juice. Put more in and it was fine. I'd do what others have said and drop the pan and poke around. Maybe your filter is clogged.
