Trailer Wiring
Discussion in 'Towing & Hauling' started by parker44, Aug 25, 2019.
  1. Aug 25, 2019 at 5:05 AM
    parker44
    parker44 [OP] New Member
    2008 Tundra - Desert Sand Mica
    Im currently in the process of fixing up an old utility trailer. I put new tires on it and it’s in good shape. With it being so old, it has been wired to the old 6 pole round and was only used with an old Chevy. I bought the adapter to hook from the trailer to the 7 blade on our trucks.
    I’m not very experienced with this and hope it’s something easy, but my lights are jacked up. My brake lights work, and 4 way flashers work. When i turn either signal on, both rear trailer lights flash, like they were the flashers. My normal running lights also don’t run on the trailer.
    The adapter i bought has the led test lights, and looks like it’s sending signal to the correct part (left turn, right turn, etc) just the trailer lights aren’t corresponding right. Could it be a loose wire in the current pole or maybe i need to get a new 6 pole and rewire it?
    jeremyd likes this.
  2. Aug 25, 2019 at 5:20 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Double check all your connections.
  3. Aug 25, 2019 at 5:23 AM
    parker44
    I’ll pull the end off of the 6 pole and look at them. The one above is what is coming out of my truck, so it should be wired that way.
  4. Aug 25, 2019 at 6:50 AM
    parker44
    So I got the old connector off and had to cut as it was rusted. I’ve only got 4 wires coming out of the trailer to the plug. They are old so I can’t tell the colors really as the sheaths were falling apart. I’ll crawl under it later to see the colors, but Here is a picture of it wired. It’s looking at it with the top up.
    I’m wondering if I might be better off just buying the 4 flat connector and using it instead.
  5. Aug 25, 2019 at 6:56 AM
    Nm6300'asl
    2022 DC SR5 4x4
    If all you are running is lights, flat 4 is all thats needed.
    You folks have some red dirt out there!
    parker44[OP] likes this.
  6. Aug 25, 2019 at 7:20 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Flat 4 is easy.
    Your problem is most likely a ground and if the wiring is that crusty you're probably better off buying a whole new light set than chasing problems.
  7. Aug 25, 2019 at 7:39 AM
    parker44
    I think I’ll pick up the flat 4. It was originally wired for my dads 1980 Chevy, when that was his only truck. That one is currently not running and even if it was, very unlikely we would pull anything with it.
  8. Aug 31, 2019 at 10:16 AM
    parker44
    Bought a flat 4 and got it wired up!
    Nm6300'asl and Kerch71 like this.
