Trailer Locks
Discussion in 'Towing & Hauling' started by parker44, Mar 13, 2020.
  1. Mar 13, 2020 at 5:32 AM
    parker44
    parker44 [OP] New Member
    2008 Tundra - Desert Sand Mica
    I've got an older utility trailer I was able to fix up just with some new tires, and built some sides to it. I don't have a lot of money in it, but I'm looking to see if there are any good trailer locks for it while towing? This trailer was homemade back in the 80's, and the coupler that was used and welded on doesn't have a way I can lock it with a normal lock.
    Most of what I will be using it for will be hauling to the dump and other properties, but if I have to go pick something up from the store, I'd like to have peace of mind while I'm inside that someone can't just unlatch it and take off.
  2. Mar 13, 2020 at 5:52 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I use an aircraft cable with loops on both ends and big padlocks and lock it from the truck frame to the trailer frame and dare anyone to try to part the two!
  3. Mar 13, 2020 at 5:53 AM
    thrustmaster
    thrustmaster New Member
    Joel
    dallas
    2016 Tundra Crewmax MGM 2WD
    I have a harbor freight one that has been going strong for 10 years now.
  4. Mar 13, 2020 at 6:05 AM
    Post pictures of coupler please.
  5. Mar 13, 2020 at 6:17 AM
    parker44
    I’ll post one when I get home this afternoon.
  6. Mar 13, 2020 at 6:17 AM
    parker44
    Do you have a picture of the one you use?
  7. Mar 13, 2020 at 6:24 AM
    thrustmaster
    Joel
    dallas
    not at the moment, but ill get one this weekend
  8. Mar 13, 2020 at 6:27 AM
    timsp8
    NY
    If it’s not a normal coupler that can take a coupler pin lock, what about a ball lock?
  9. Mar 13, 2020 at 7:17 AM
    parker44
    I was looking for something similar to this, but something that I can use while pulling it.
  10. Mar 13, 2020 at 7:28 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I'd put a padlock on the safety chain. It's not perfect, but it will at least require that the crook has tools.
  11. Mar 13, 2020 at 7:33 AM
    timsp8
    NY
    Will something like this not fit?
    if not then padlock with a good lock to the chains like tvpierce said.
  12. Mar 13, 2020 at 11:12 AM
    parker44
    Here is my coupler. I guess i could drill down right behind the little clip that keeps it locked and put some type of big lock through it or a locking hitch pen.
  13. Mar 13, 2020 at 12:15 PM
    parker44[OP] likes this.
  14. Mar 13, 2020 at 12:42 PM
    tvpierce
    Maine
    Or just cut/grind that coupler off, drill a couple of holes, and for $15 put one of these on there.
  15. Mar 13, 2020 at 1:00 PM
    Even better!!!! For some reason I thought he had an A frame coupler.
    I would do this @parker44
  16. Mar 13, 2020 at 1:12 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
