Trailer lights
Discussion in 'General Tundra Discussion' started by Dcuff, Aug 18, 2017.
  1. Aug 18, 2017 at 6:18 PM
    Dcuff
    Dcuff [OP] New Member
    Dave
    Outside of Philadelphia
    Silver. Tun 4x4 doublecab SR5
    Bull bar, spot light and fog lights. Master lock tool lock system. Rear brake lights underneath the Tellgate with turn signal's, just added new step bars, vent visors, HID head lights and fog lights. Just ordered a lift kit.
    Does anyone know why my factory trailer lights all flash when my hazard lights are on? I'm talking about my running lights cause yes I know my hazards are supposed to flash. I have a 2012 sec edition sr5
    4x4_Angel likes this.
  2. Aug 19, 2017 at 7:12 AM
    cfdfireman90
    cfdfireman90 New Member
    Cory
    Southern NH
    2015 Tundra Limited/TRD Double cab
    Bad ground somewhere on the trailer.
    Dcuff[OP] likes this.
  3. Aug 19, 2017 at 10:08 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Did you just get the trailer or did it just start happening?
  4. Aug 19, 2017 at 1:29 PM
    Dcuff
    Dave
    It just started happening I was testing out the lights and I noticed it.
  5. Aug 19, 2017 at 1:33 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Weird, they flash in sync with the blinkers, like same function? Or are they just flickering with no rhyme/reason?
    If no rhyme/reason has to be a bad connection somewhere.
  6. Aug 19, 2017 at 2:11 PM
    Dcuff
    Dave
    I checked it again. I used a four way tester on my truck and it's actually coming from my truck! Yeah doesn't sound good huh? Yes it's pulsates with the rhythm of the hazard. Do you think it's a relay going bad or a bad connection?
  7. Aug 19, 2017 at 2:48 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Shot in the dark here. Do any of the marker/parking lights flash when the left turn signal is on? I'm assuming you have the combination 7 round/4 flat plug on the truck. If so, the tail light spade is next to the left turn spade and if there's corrosion it's possible for current to jump across the spades. You can unplug the wiring from the back of the plug and look for any corrosion inside the plug, it'll be crusty and bluish green. If it's there, a small pick or flat screwdriver, some WD40 and some compressed air will clean it out.
  8. Aug 19, 2017 at 3:22 PM
    Dcuff
    Dave
    Thanks I'll have to check that out. Yes I have the four plug with the seven round plug next to it. I'll let you guys know thanks for the help
  9. Aug 19, 2017 at 4:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I guess it's not the trailer then! Hopefully just corrosion.
  10. Aug 27, 2017 at 9:04 PM
    Dcuff
    Dave
    Thanks for all the help guys. I got a wire brush & WD40 and went to town. It seems to stop after I found a little bit of corrosion. It's not doing what it was. So that's a plus for me. Sorry it took sometime to get back to ya'll
  11. Aug 27, 2017 at 9:51 PM
    duece292
    Greg
    Green Bay, WI
    That's good to hear! Glad she's back up and running :thumbsup:
  12. Aug 28, 2017 at 4:27 AM
    MotoTundra
    MotoTundra The Ocho
    Don
