Trailer Hitch
Discussion in '3rd Gen Tundras (2022+)' started by AustinTexas, Nov 28, 2022.
  1. Nov 28, 2022 at 6:44 AM
    AustinTexas
    AustinTexas [OP] New Member
  2. Nov 28, 2022 at 6:59 AM
    You can have the employees at U-haul level the exact trailer you will be renting, measure for the ground to the top of the coupler. Then measure from the ground up on the back of your truck to see what kind of drop you might need.
    Another way around this is just buy an adjustable hitch.
  3. Nov 28, 2022 at 7:16 AM
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Depending on the weight of the trailer you are going to rent, consider a bit of truck back end squat when measuring your truck's ball height. But not very much likely, just an inch maybe.
  4. Nov 28, 2022 at 7:27 AM
    AustinTexas
    Are most of you going with a 4" drop for general all around use?
  5. Nov 28, 2022 at 7:42 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
  6. Nov 28, 2022 at 7:45 AM
    aj350925
    aj350925 New Member
    Yea, about that.
    I have the drop maxed out to 4" on the two hitches I have used. I do have the rear air suspension adjusters set to maximum height on the truck though.
  7. Nov 28, 2022 at 7:47 AM
    AustinTexas
    That one is very nice. Just more expense that I would like . I do not tow often.
    This is really just a one and done tow for moving my daughter to college .
    Towing the smallest 4'x8' cargo trailer from U-Haul.
    slowpokepete[QUOTED] likes this.
  8. Nov 28, 2022 at 7:53 AM
    aj350925
    aj350925 New Member
  9. Nov 28, 2022 at 8:01 AM
    Paul Moll
    Paul
    Idaho
    How far are you towing AutinTexas? If it's only like 100 miles or less, I'd suggest getting the ball height from Uhaul, measure your truck, then find something on Amazon or your local farm supply store and call it done. If the trailer leans a bit I've found that's fine for shorter trips. ps: if you're not a frequent tow-er, then driving a bit slower than normal is a good idea too, which lessens the impact of a somewhat tilting trailer. Safety first :)
  10. Nov 29, 2022 at 5:29 AM
    AustinTexas
    Do these measurement look correct?
    Should I get a 4" or 2" drop
    I measured my receiver tube on my 2022 Tundra at 20"
    U-Haul is listing a trailer coupler height of 18"
    So it looks like I will need to get a 2" drop for the trailer hitch
    ( or should it be a 4" drop so the center of the ball is at a 2" drop)
    Or I guess I can stop being a cheap ass and just buy the adjustable.
  11. Nov 29, 2022 at 5:33 AM
    AustinTexas
  12. Nov 29, 2022 at 7:47 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    You're not going to have much difference on a 2" vs 4" drop. Biggest thing you need to pay attention to with that U-Haul trailer is how you distribute the weight inside the trailer.
    https://www.youtube.com/watch?v=w9Dgxe584Ss
  13. Nov 29, 2022 at 8:04 AM
    Paul Moll
    Paul
    Idaho
    @AustinTexas: would you be ok with telling us what Tundra you have? TRD etc... thanks :) ..I'd like to compare to the height of mine, when I get it next week.
  14. Nov 29, 2022 at 8:36 AM
    AustinTexas
    I have the 2022 Tundra Limited 4x4.
  15. Nov 29, 2022 at 8:39 AM
    Paul Moll
    Paul
    Idaho
    Nice, thanks :)
  16. Nov 29, 2022 at 2:30 PM
    wing-2
    wing-2 New Member
    I bought this. I have a 2023 SR5 TRD Off Road Double Cab with 6.5' bed. It tows my Proline 14' double axel snowmobile trailer level, with two sleds in it. It came with a dog bone lock. Bought it at Tractor Supply. IMG_20221129_172020995.jpg IMG_20221129_172032701_HDR.jpg
  17. Nov 29, 2022 at 4:06 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have 2 Weigh-safe hitches. They both have a 6" shank that can be flipped so you get a huge range of heights. One is a WDH and the other is standard hitch. My truck picture has the Airstream attached and WDH is active. It sits very level. If I put bigger tires on or a lift, I can just slide the hitch up or down on the shank to suit the trailer.
    Mattedfred likes this.
  18. Feb 20, 2023 at 5:20 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I use a Curt 45142 to take boat to ramp since salt water and weigh safe don’t mix. I like that the ball is welded on since I have had a few stolen.
    CURT 45142 Trailer Hitch Mount
  19. Aug 24, 2023 at 12:38 AM
    abe86
    abe86 New Member
    Here are a few considerations for selecting a trailer hitch and ball for your 2022 Toyota Tundra to haul a small U-Haul trailer: geometry dash
    - For a light utility trailer from U-Haul, a class III hitch with a 2" receiver size should be sufficient. This provides up to 5,000 lbs towing capacity.
    - Make sure to get a complete kit with all necessary mounting hardware tailored specifically to the 2022 Tundra. Custom mounting points vary by vehicle.
    - Most small U-Haul trailers use a standard 2" ball size. Choose a ball with appropriate weight rating for the trailer. Steel or chrome balls are common options.
    - Measure from the center of your Tundra's rear bumper down to the ground. Select a drop/rise hitch that positions the ball height to match the trailer coupler height.
    - A drop of 6-8" is typical for a level towing stance, but double check with U-Haul on the exact trailer height when unloaded. Too much drop can over-tilt the trailer.
    - Adjustable ball mounts allow tweaking drop/rise height as needed. Static drop hitches are fixed.
    - Add accessories like trailer wiring harness, hitch pins, locks, stabilizers to complete setup.
    Consulting with a knowledgeable hitch installer and measuring precisely will ensure you get the right gear for a safe, level tow. Let me know if you need any other specifics on selecting the proper hitch components.
  20. Mar 27, 2025 at 1:48 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    2022 toyota tundra platinum
    K&N air filter. Front windows tint, RC front leveling kit.
  21. Mar 27, 2025 at 1:54 PM
    99ways2die
    99ways2die New Member
    NJ
    2022 Tundra Platinum
    Ipaddick likes this.
  22. Mar 27, 2025 at 2:11 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    They have different sizes and weight options. I am looking for something that can smooth the ride while towing a boat. The problem I have is that on some patches of freeway, the ride becomes a bit bumpy. I am looking for options to fix that.
  23. Mar 27, 2025 at 2:35 PM
    99ways2die
    NJ
    I'm sorry to tell you, but trying to add "suspension" to your hitch will not mitigate inadequate vehicle and (most likely) trailer suspension.
    Outta curiosity:
    -AVS/airbags on your truck?
    -size + weight of your boat+trailer?
  24. Mar 27, 2025 at 2:37 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    Yes i have AVS and boat weight about 5k it's a 24 foot surf boat.
  25. Mar 27, 2025 at 2:39 PM
    DRP
    DRP Old Member
    Dave
    Tongue weight?
  26. Mar 27, 2025 at 2:40 PM
    DimaA
    DimaA New Member
    Dmitriy
    WA
    I need to check on tongue weight.
  27. Mar 28, 2025 at 8:24 AM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    While you are correct, hitches can smooth out the side a bit. Look at Gen y, shocker, and airsafe. Again you still need a capable truck, but it can make the ride more enjoyable.
    I used a friends Gen y glyder to tow our horse, and I’ve never had any issues with a regular hitch, you did feel bumps quite a bit less. I’m towing with an hybrid with airbags and avs. The trailer was 2400lbs and the horse was under 900lbs. It was Especially noticeable on bridges, washboard and whatnot. I imagine it was probably easier on the horse as well. That being said i was under the recommended tounge weight and still noticed some difference.
    it has me considering adding their hitch to my wdh for our camper.
    DimaA likes this.
  28. Apr 12, 2025 at 7:09 PM
    Spacecowboy863
    Spacecowboy863 New Member
    i use an adjustable 6" drop on my hitch
  29. Apr 12, 2025 at 7:51 PM
    Jigenax
    Jigenax New Member
    Ken
    Idaho
    2022 Blueprint Tundra DC TRD Sport
    When I was moving from NV to ID, I towed 3 motorcycles on a trailer with the bed loaded up with heavy boxes. The weight in the bed lowered the hitch mount about 2 inches so I was lucky that my hitch had 2" drop.
