Trailer Harness Relocated
Discussion in '2nd Gen Tundras (2007-2013)' started by Jrharvey02, Apr 18, 2019.
  1. Apr 18, 2019 at 5:56 PM
    Jrharvey02
    Jrharvey02 [OP] New Member
    2010 Tundra CM 5.7 Platinum Dark Black
  2. Apr 18, 2019 at 8:18 PM
    ND_Porkchop
    ND_Porkchop New Member
    2008 Tundra 5.7 CM DSM
    It's steel behind the plastic right? What did you cut through with? I'm considering doing that, then putting a flush mount LED cube(reverse light) on the other side.
  3. Apr 18, 2019 at 9:04 PM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    I have been looking at doing the same thing. Do you have any pictures of the process?
  4. Apr 18, 2019 at 11:29 PM
    Jrharvey02
    Yes, chrome metal is behind and that’s what you need to mount the bracket to for this to work and not be flimsy. You just pop off the plastic, breaking some of the tabs. You can see the bracket in the pic of harness above. I got 3 of the 4 mounting screws into metal, so it’s suuuper sturdy, it rocks the truck if I grab and rock it, way stronger than factory. I used a dremmel w/ reinforced wheel to cut the round part out, then grinded smooth, no problem, just be patient and it only takes 1 disc. I didn’t take pics, kinda self explanatory what’s necessary. Went to Ace hardware and got longer nuts/bolts. Kit comes with 1” and you need 1 1/2”, I went with black and upped em a size for strength.
    sf319 likes this.
  5. Apr 25, 2019 at 4:17 PM
    EBenke
    EBenke I’m Ready To Go!
    Everett
    2007 Toyota Tundra DC, 5.7, 4x4
    3/2 lift, Icons, 35's, 3" CB's shackles
    Very Nice, I need to do something like this as well.
    Jrharvey02[OP] likes this.
