Trailer brake controller
Discussion in 'Towing & Hauling' started by UNTMatt, Sep 9, 2020.
  1. Sep 9, 2020 at 6:33 AM
    UNTMatt
    UNTMatt [OP] New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    I know the Tekonsha P3 is a popular brake controller but I'm also looking at the Redarc Ultra brake controller. Right now we will be renting some TT's in the 20~28 ft range with looking at purchasing in the late spring once we have a feel for what we want.
    Any thoughts or preferences from the experienced towers on which brake controller or should I look at another one? I'd prefer one that will connect to the factory wiring and have a clean install.
  2. Sep 9, 2020 at 6:56 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    P3 hands down. Great unit and works well every time!
    UNTMatt[OP] and SprinterAE86 like this.
  3. Sep 9, 2020 at 7:35 AM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I recently installed a RedArc. Easy install and the controller works great. I put in the Tow Pro Elite.
  4. Sep 9, 2020 at 7:43 AM
    sbxx312
    sbxx312 New Member
    2018 Tundra TRD Sport
    I have the P3 in my Tacoma and the integrated brake controller in my 2018 Tundra. The IBC update seems to have fixed most of the towing issues for everyone, but I was pretty nervous owning a truck to tow my trailer that had a shitty malfunctioning brake controller.
    The P3 is rock solid and will always work. The IBC works great on the Tundra, but I'd still get the P3 if you have the option. Most people will say it's the best aftermarket option. If Toyota hadn't issued the update, I was going to hard wire the P3 and stop worrying about it.
    SprinterAE86 likes this.
  5. Sep 9, 2020 at 7:45 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I just installed Redarc this morning. It's not calibrated yet. But I chose it due to the remote controls. Everything out there is bulky you have to place it in an odd place.
    Teconsha does have a bezel mount for third generation that i would do if i have 14-15. But they don't have any bezel for 2nd gens.
    UNTMatt[OP] likes this.
  6. Sep 9, 2020 at 7:46 AM
    alwzdfiant
    alwzdfiant New Member
    2013 Tundra Crew Max
    How was the install?
  7. Sep 9, 2020 at 7:49 AM
    SprinterAE86
    Ian
    Very easy. You do need to get a patch harness still.
  8. Sep 9, 2020 at 7:49 AM
    alwzdfiant
    Thanks!
  9. Sep 9, 2020 at 7:51 AM
    SprinterAE86
    Ian
    I also got this just in case I messed up with drilling the blanks.
  10. Sep 9, 2020 at 7:57 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    299.9k Supercharged 2008
    On my 3rd vehicle with the P3 and no complaints. Can't go wrong for $120 or whatever.
  11. Sep 9, 2020 at 8:37 AM
    UNTMatt
    Thanks for the replies. I was going to get the P3 but then found the Redarc. I really like the cleaner install and the panel adapter is far less expensive than the panel adapter for the P3. Now I'm strongly leaning to the Redarc but just haven't read much on it and since I'm new to towing, want to be sure.
  12. Sep 9, 2020 at 8:49 AM
    SprinterAE86
    Ian
    Etrailer.com have a YouTube video about it.
    UNTMatt[QUOTED][OP] likes this.
  13. Sep 9, 2020 at 9:13 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    They all work the same. Doesn't matter what brand or what it looks like. With the exception of it being "timed" or "proportional". The proportional is definitely smoother. I have used both..
  14. Sep 9, 2020 at 9:16 AM
    SprinterAE86
    Ian
    Yes, I'll be setting mine up as proportional. I'm only going to pull a 3600lbs camper.
    jeremyd[QUOTED] likes this.
  15. Sep 9, 2020 at 9:20 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Just go old school, 40 bucks ! Lol
  16. Sep 9, 2020 at 5:53 PM
    JLS in WA
    It really all depends on what kind of mount you want. For me, it was worth not having the damned controller underneath the steering wheel. Beauty is in the eye of the beholder. Buy what you like. The RedArc install is as clean as they come.
  17. Sep 10, 2020 at 11:10 AM
    UNTMatt
    I have the Redarc on order, more for the clean install than anything else. The only piece I can't find is the wiring harness. Amazon has the Tekonsha wiring harness, will that work? I want this to be plug and play into the trucks wiring harness. No splicing.
  18. Sep 10, 2020 at 2:08 PM
    JLS in WA
    I ordered the harness through Amazon. Splice to the controller and plug it in.
  19. Sep 10, 2020 at 2:15 PM
    SprinterAE86
    Ian
    Yup, that's what I have.
  20. Sep 10, 2020 at 2:21 PM
    UNTMatt
    Thanks! Went ahead and took the chance. Should be here on Tuesday so I'll try to get it installed then. I also have a set of black Sumo Springs I need to install.
    --Matt
    SprinterAE86[QUOTED] likes this.
  21. Sep 10, 2020 at 2:38 PM
    JLS in WA
    FWIW, I’d spend the 12 bucks for the mounting plate for the control knob. I found the plastic knock out inserts difficult to work with. Wasn’t very clean or flush. Maybe I had too much beer.
  22. Sep 10, 2020 at 2:44 PM
    UNTMatt
    That part is supposed to arrive on Saturday. I thought about going the cheap route and drilling the knock out insert but, well, I'm not going the cheap route with the brake controller so I might as well spend a couple of extra bucks on the pre-drilled blank. LOL
  23. Sep 10, 2020 at 3:54 PM
    SprinterAE86
    Ian
    I got lucky with my first attempt. I still have the blank coming in tomorrow. I'll use it when I relocate the knob next to the tow haul button where it belong. I'll do that when I get my stereo upgrade.
