Trailer brake controller error HELP
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Feb 20, 2019.
  1. Apr 19, 2021 at 12:44 AM
    Viliamu808
    Viliamu808 New Member
    Dealer blamed it on the p.c. ..unplugged it and possibly reset the computer or something and been fine now for a few weeks..
  2. Apr 19, 2021 at 6:33 AM
    TFONG95
    TFONG95 New Member
    Sacramento
    2019 SR5 Off Road
    No, my truck is pretty much all stock with no modifications other than deleting the chrome off the truck.
  3. Apr 19, 2021 at 5:07 PM
    Viliamu808
    Well that's not good..im sure they would have to reset something...maybe clean the sensors?
  4. Apr 20, 2021 at 6:37 AM
    TFONG95
    TFONG95 New Member
    Sacramento
    2019 SR5 Off Road
    Found out the issue for my Truck. According to the dealership, the dealership that did the recall for the fuel pump. They did not do the install correctly and something popped out. My truck wasn't getting enough fuel. Which didn't explain the PCS error or the Brake controller error to me. I asked about that and they said its normal, my truck was crying out for help and it set off the error codes. Which I guess makes sense???? So my only issue is, they said Toyota wont cover the repair. It wasn't a part issue, it was a installation issue. So the dealership has to notate all the problems and contact the dealership that did do the install and they have to pay them to correct the issue. Since the recall part wasn't the problem. It was just a bad install. So Toyota wont pay for any of the repair since they paid for it once for the recall and this isn't covered under warranty for install error.
    They said it shouldn't be a issue, but they have had other dealership say they refuse to cover the expense because it wasn't their fault. They said if that happens, I would need to pay for the repair and I would have to go after the dealership to refund me back the money. Which I hope doesn't happen. But I learn more today.
    I asked how often does this happen. They said its actually happen more often than you think. They just did one last week for another Tundra that came from the Bay Area and got stuck out in Reno too. Bad install on the fuel pump also.
  5. Jan 19, 2022 at 4:26 AM
    jleonk
    jleonk New Member
    I have had this "trailer brake controller error" issue for a couple years, BUT it's only when the truck is very cold, like 27 degrees or below. When the issue arises for me, I can't shift the truck out of park, and the HVAC display stays dark. Eventually, if I leave the truck running for 5-10 min to warm up, the warning message will go away, the HVAC display comes on and the truck will shift normally. A couple times, when it's been REALLY cold, the truck engine start but then will sputter out before it gets sufficiently warm, and the battery will be dead. I've taken it to the dealer -- they blamed an aftermarket remote starter. I had that starter taken out, and the problem persists.
    I have generally managed the issue by keeping the truck garaged (and therefore above the very low temps), but it's really aggravating. I just decided to do some internet searching and found this thread, which I guess I missed last time I looked into this.
    Any thoughts on what might be causing this specific temperature-driven issue? Thanks.
    (2017 Tundra Platinum CrewMax)
  6. Jan 19, 2022 at 6:19 AM
    This is such a frustrating issue to have. What worries me when owners get this message while towing. Most half tons don’t have a secondary braking system so that could get dangerous very quickly.
    To be blunt, I would have a separate aftermarket brake controller that doesn’t fault out due to a wheel speed sensor or bad fuel pump TSB download. Towing is my main concern, so this would be a priority for me. For others, this is no more than an annoyance.
    One of my worst trips out to Moab, UT for a off-roading event I lost my trailer brakes due to a brake magnet grounding out. I was in my 2004.5 Dodge 2500. This was long before factory exhaust brakes and grade braking transmissions (well, except for the Allison). As my normal ass kicking luck is, I was heading west on I-70 going up Vail Pass. To put icing on the cake, of course it was snowing and around 9 PM. I was screwed since I couldn’t go back or forward. Right after the Eisenhower Tunnel I pulled off and had to solve the problem. With some troubleshooting, I bypassed the bad brake magnet and ran with 3 brakes instead of 4. Not my finest hour, but it got me to Moab and could make repairs in a warmer/dryer climate.
    The point of this is having a back up plan and Toyota doesn’t deliver in this department. I used to think how nice it would be to have an integrated brake controller on my 2012 Tundra. Little did I know how fortunate I was to have a really good aftermarket brake controller that never let me down (in several trucks).
    NewImprovedRon likes this.
  7. Mar 18, 2022 at 2:23 PM
    fortiz619
    fortiz619 Mall crawler
    SoCal (SD)
    2017 crewCab 4x4
    3 inch lift
    Just went through this and turns out my battery was on its way out , got a new battery problem went away
  8. May 28, 2023 at 8:47 PM
    Fsuriptide
    Fsuriptide New Member
    My 2016 is doing this at 44k. No trailer attached and it’s only “brake controller error.” I disconnected the negative terminal for 2 min and after reconnecting I no longer have the error message but I also no longer have a trailer page
  9. Jun 7, 2023 at 3:52 PM
    Otis9347
    Otis9347 New Member
    2015 tundra crew cab
    Stock
    Exact thing happend to me as above. Brake controller error, so I disconnected the battery, but also lost trailer brake control screen. Too much at a dealership to reprogram. I will be installing the tekonasha p3. 2015 tundra 80k miles.
  10. Jun 7, 2023 at 7:12 PM
    Fsuriptide
    Think I’m gonna do the same…
  11. Jun 13, 2023 at 9:56 AM
    Otis9347
    Otis9347 New Member
    Stock
    Update: my oem brake controller was the problem. I replaced it with a tekonasha p3 for $150 vs oem$$$. Trailer brakes work great now!
    thearborbarber and Fsuriptide like this.
  12. Jun 13, 2023 at 10:47 AM
    Fsuriptide
    Thanks for the follow up, will likely be doing the same!
  13. Sep 14, 2023 at 6:41 AM
    MrBreeze
    MrBreeze New Member
    2016 Tundra CM
    Hello all, just joined the Forum but on my 3rd Tundra since 2003, now the 2016 - was continually upgrading for size/power due to growing family, growing trailer size...
    I was having multiple problems with the OEM controller - started with having to turn it up to 8-9.0 to get braking action on the trailer, read abt the software update and got that a couple years ago (charged me $50 since out of warranty) but that didn't seem to help at all. Most recent was the "brake controller error see dealership" message that was present when towing or not towing - so went online to search right away and from reading comments and info here, I had a local trailer-shop install a Tekonsha Primus controller (as well as repack my bearings) and trailer brakes work great now - setting is 3.7 with a boost. I also disconnected the negative battery terminal for abt 2 minutes, then reconnected and lost trailer screen - but now that is unneeded with readout on the Primus controller and the annoying message is gone.
    Thanks all for info!
