Trailer Axle Maintenance
Discussion in 'Towing & Hauling' started by ColoradoTJ, May 9, 2018.
  1. May 9, 2018 at 10:24 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    LML 3500HD
    @landphil, he is a professional in this particular area, feel free to add your comments.
    I really hate being on the side of the road due to stupidity on my part, so when things just are not normal, time to inspect your equipment.
    I rarely use my service brakes do to the truck used to pull, but that won't help me in an emergency stopping condition. Over the past couple of years I have had to crank up my brake controller a little more than I would like. Two things, either my brakes are out of adjustment/shot or I have a seal puking grease inside my brake assembly. Since my brake shoes were in great shape last year, I kinda knew what might be happening.
    Tools needed for axle bearing & brake maintenance:
    -Dead blow hammer
    -seal install, removal tool kit
    -Screwdriver, needle nose pliers, Adjustable wrench
    -Drum brake spring tools and adjuster.
    -wire brush
    -Grease gun/bearing grease.
    Parts:
    Bearing kit, seal, emory cloth, cotter keys six one packs of beer.
    -Remove bearing hub dust cap (use hammer and screwdriver)
    -Remove cotter key and dispose of it. Use a new one.
    -Remove spindle castle nut and washer. Easiest way to do this is start pulling on the brake drum a bit and then push the assembly back in. The bearing and washer should be easy to grab now.
    -Remove the brake drum. You may need to loosen up on the brakes a bit. This is what the brake adjustment tool is for. Remove the dust cap from the rear of the dust plate, use the adjusting tool to release the brakes.
    Bad inner seal.
    -This is what a typical trailer brake assembly looks like, but as you can see, I have grease inside my brake assembly, so the rear seal is out on this one. No wonder the brakes were not grabbing since they were covered in grease.
    -Clean up the spindle and check for any rough spots or gouges. This one actually has a little spot that needs to be touched up with some emory cloth. This can cause the seal to be torn, bearing not to seat all the way...etc etc etc.
    -Use the bearing seal install kit to remove inner bearing/seal. Inspect inner bearing, race and repack bearing. Remember to install the bearing before the seal. Install seal.
    6F82EB25-806A-418B-A261-36480C357D2C.jpg A0BB220B-22FB-4966-BB58-DF7FEC38EE3A.jpg E150428A-0959-4E6F-8AC9-1B96DD026403.jpg F0326541-65E4-4921-9DC2-907AB8497115.jpg
    -Clean up braking surface and where the electric magnet runs on inside the drum.
    -Lube up the spindle shaft. You always want to lube your shaft.
    -Reinstall brake drum, carefully sliding it on the lubed shaft to protect the seal. Reinstall outer bearing after inspection, repacking, etc. Install the washer first, then the castle nut. Tighten down the nut pretty good, then back off 1/4 turn. There are torque specs for seating bearing sets, but I have been doing this for a bit and would like to think I know a little bit. Install cotter key and bend the tabs opposite of each other.
    -Install dust cap with your dead blow or rubber mallet. Careful not to dent or damage that cover.
    -Install wheel and tire and tighten lug nuts as best you can with the wheel remaining off the ground. Climb under the trailer and adjust the brakes. I like to tighten them down to where you can't move the tire, and then back off.
    Other items to remember:
    -If there's grease all over the shoes, they need to be replaced. Trailer brakes come in assemblies (usually) and you just disconnect the electrical wires, remove the 4 bolts on the backing plate and install the new assembly. Its very easy and the way to go. This way you get all new hardware. For a 10" brake, this is about 38.00. A new drum is around 40+. Trailer.com has complete assemblies for 70-80.00, which is a great deal.
    -Check the drum for excessive wear. On the drum, it will say what the maximum allowable diameter for the service life.
    landphil, RangerBP, gosolo and 9 others like this.
  2. May 10, 2018 at 6:03 PM
    pamtnman
    pamtnman New Member
    God's Country
    '17 Tundra TRD CrewMax
    Working through the list
    Thanks for posting. I admire your ability to do this work; it is beyond my capability. I'll take mine to one of the trailer guys around, but it is useful to see what goes on with this work
    757TUNDRA and ColoradoTJ[OP] like this.
  3. May 10, 2018 at 6:08 PM
    LML 3500HD
    You have to be comfortable doing the work. No harm, no foul.
    pamtnman[QUOTED] likes this.
  4. May 10, 2018 at 6:13 PM
    pamtnman
    pamtnman New Member
    God's Country
    Yeah brother
  5. May 10, 2018 at 6:20 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Great write up. Thanks.
    ColoradoTJ[OP] likes this.
  6. May 10, 2018 at 6:49 PM
    ertlonggun
    ertlonggun New Member
    2013 Dbl cab grey TRD
    TRD air filter TRD air flow accelerator Dirty Deeds budget SS Exhaust Worx wheels Roadmaster active suspension (rear) P-3 brake controller 3” Toyotec lift w/ shackles 35” Nitto Ridge Grapplers
    I just repacked the bearings, replaced the seals, and adjusted the brakes on my travel trailer today. Getting ready for the camping season.
    pamtnman and ColoradoTJ[OP] like this.
  7. May 10, 2018 at 7:18 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Great post and perfect timing as many get ready to hit the road for camping this summer. I just did mine in April on my pop up camper, good peace of mind.
  8. May 10, 2018 at 7:23 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Good post. I just replaced my Tie Down Engineering junk torsion axle on my boat trailer with a UFP torsion axle and Vault maintenance free hubs as well as new rotors, calipers, and pads plus an actuator in the tongue (surge system).
  9. May 12, 2018 at 7:36 PM
    gosolo
    Ray
    NW Oregon
    Nice post my friend. Hopefully this gives confidence and understanding to folks that need and want to do stuff themselves!
  10. May 12, 2018 at 11:20 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Those two, and trusting someone when they tell you they recently serviced the bearings. All three are killer.
    Great thread Chris,
    The only things I can think of to add:
    - check the lever the brake magnet attaches to for free movement on the pivot.
    - check your brake magnets before reinstalling the drum (manual application with brake controller, and make sure it grabs hold of a wrench or anthing iron.) It sure pisses a guy off when the brake doesn’t work because of a faulty magnet after it’s all together.
    - for anyone in areas where salt is used, remove the star wheel adjuster from the brake shoes, disassemble it, wire brush the threads if needed, and apply a light coat of anti-sieze to the threads and moving points.
    ColoradoTJ[OP] and Watt maker like this.
  11. May 15, 2018 at 9:09 PM
    LML 3500HD
    Excellent choice. It really sucks doing this maintenance on the side of the road, from what I’ve heard.
    pamtnman likes this.
