Trail Edition Hangout/Confirmed Fit Tonneau Covers
Discussion in 'Tonneau Covers, Caps and Shells' started by LarryDangerfield, Feb 11, 2021.
  1. Mar 29, 2021 at 4:36 PM
    #181
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    I do not have remote start. Not sure if that is part of convenience package or not.
  2. Apr 1, 2021 at 5:24 PM
    #182
    AtomicToyo
    AtomicToyo New Member
    Ontario, Canada
    Do you even really want the OEM remote start? It shuts off the truck when you open the door :frusty:
    LarryDangerfield[OP] likes this.
  3. Apr 5, 2021 at 1:11 PM
    #183
    indydieselnut
    indydieselnut New Member
    2021 CM 4x4 Trail Edition in super white
    Just things to protect it...
    Nice warm day and I was finally able to wash, clay, and then use the Griot's 3 in 1 ceramic. I stood back after all that work to survey the beautiful result...then remembered my truck is white and it looks exactly like it did before I started!
    We'll get rain later this week and I'll be able to see if it beads up any better. I've had decent success with that stuff on other vehicles. Next week I'll put in a X2Power 27F AGM (rebranded Northstar) so I don't have to worry about the stock battery.
    Truck is driving great and is so comfortable...very happy with this purchase!
  4. Apr 5, 2021 at 3:07 PM
    #184
    LarryDangerfield
    LarryDangerfield [OP] Yo! Lemme get a honk off of that bobo Staff Member
    Tyler
    Northern Wisconsin
    You just wait
    Went out and got mine dirty. Ditch lights are great on on gravel roads at night.
  5. Apr 8, 2021 at 10:23 AM
    #185
    indydieselnut
  6. Apr 9, 2021 at 8:42 AM
    #186
    2mchfun
    Well I bit the bullet, ordered a ranch hand summit bullnose bumper, rancho 2.25 lift coilovers, and lasfit switchable led fog lamp bulbs that can toggle from clear to amber with factory switch. All will be going on soon. The bumper might get modified first, going to see if I can weld in a front receiver tube, maybe two, in order to get a diy stable ride cargo rack hitched up when I need to add more cargo capacity or a bike rack. Also added a mirror mount uniden r3 radar detector powered from rearview mirror harness/plug and my cobra 29 cb got mounted under the drivers seat. Just had to do a quick turnaround down to Gulf Shores, AL and the Uniden r3 is a great tool for getting the Tundra down the road at a really quick clip. Only downside is the limiter shuts down at 109 MPH. Factory tires are pretty close at that number too, so it works. I will say this, she can guzzle fuel and get down the road nice and smoothly with great confidence in handling and braking. Some vehicles lose confidence at high speed, not the case with this beast. Anyway, all in all, I can say I just about lived in the drivers seat for over 12 hours per day for nearly a week while in Alabama and to and from, about 3200 miles all combined, no way do I suggest anyone try it, the seat just isn't made for it, your tail will get angry! Been home a few days now, but still tender! Not sure if I told you all yet, but I did install my tranny cooler b4 I left too, she now hangs around 180-190 degrees on the highway at a good clip. For anyone looking to run wires from inside to outside, grommet in floor behind front passenger seat just inside frame rail is easy to access, pull up door sill and carpet clip nearest hole and you can reach under the carpet easily. Happy Truckin' folks!
  7. Apr 10, 2021 at 4:53 PM
    #187
    2mchfun
    Update: I found a front receiver from drawtite that will bolt up using tow hook mounts, and I think it will fit under the ranch hand bumper, so it is on the way. It will also act as a shield to catch whatever roadkill is thrown downstairs by the ranch hand bumper. Also got some coachbuilder coilover shims to give an extra 1/2" of lift due to the research that dictates the rancho coilovers will be limited with crew max overall weight. Research says no way will I get 2 plus inches. No worries, a little shim and all is well. Then I also decided to order some +2 coachbuilder shackles to lift the rear 1.5. Will also drop the driveshaft carrier bearing 3/4". Will drop the front diff 1" also. Hoping to end up with the rear about 3/4" or 1" higher than the front when all the dust settles. Should be pretty close considering constant weight in my storage boxes, with recovery, tools, straps, etc. If all else fails, easy to add a bit more if necessary to get the height balanced. Oh yeah, front bump stop extensions, got those too. Don't ever mod a front suspension without taking into account your bump stops or you will be tearing up your shocks when they bottom out and take a blow that they are not at all designed for. Not sure about rubber yet, if all looks and works well, the stock michelins will remain. Like to keep tires on the smaller side to keep the tranny happy towing heavy loads. However, two sets is somewhat an option. Not the best option, but time will tell. Damn truck is getting into my wallet at this point! Going to be sweet to get all this done before the summer heat arrives! Maybe post up some photos in a few weeks if everything arrives in a timely manner. You all be safe and keep your families safe!
  8. Apr 12, 2021 at 7:30 AM
    #188
    triggerman08
    triggerman08 New Member
    Tony
    Yeah so i can use the app which i really like my wife has it on her 2020 Hyrbid Rav 4 and the fact that the car shuts off after i open the door is not the end of the world to me.
  9. Apr 12, 2021 at 9:24 AM
    #189
    heyacker
    heyacker New Member
    I want the boxes but had to take out my rail system for the leitner forged rack.
  10. Apr 12, 2021 at 11:57 AM
    #190
    PVTUNDRA2021
    PVTUNDRA2021 New Member
    2021 Tundra Crewmax Trail Edition
    Installed all Black Clazzios 2 weeks after I got my 2021 TE. Turned out great.
  11. Apr 12, 2021 at 1:25 PM
    #191
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Just a little bit which was exactly what I wanted. I can take more pictures if you would like. IMG_20210328_155946.jpg
  12. Apr 12, 2021 at 3:28 PM
    #192
    AlohaTundra22
    AlohaTundra22 New Member
    How do you guys let your Trail? I came close to purchasing one. Love the Army Green. The trail by me sold and I ended up getting a Sport instead.
  13. Apr 12, 2021 at 3:34 PM
    #193
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I like it a whole bunch. It is my attainable dream vehicle. ( Obviously if I won the lottery all bets are off ) truth be told the bed boxes are only okay, but I like how it's just a good looking SR5 with the upgrade package. Mine came with all kinds of little cosmetic things that all work well with each other. ( All badges are black, black inserts in the tailgate, black chrome exhaust tip, dark wheels, etc)
    2mchfun likes this.
  14. Apr 14, 2021 at 6:31 AM
    #194
    indydieselnut
    Mine didn’t come with the black chrome exhaust tip, but I picked one up at the dealer and it was the easiest install after the TRD shift knob. I like the way it looks and it is a beautifully made piece.
    Does anyone know definitively if the TRD skid plate has the red logo on it? It does in stock photos but the recent YouTube install videos show it being “blank”. I really like the blank look and would order one for the first oil change if I could guarantee it being blank.
  15. Apr 14, 2021 at 6:35 AM
    #195
    jonclark96
    Jon
    Maryland
    2021 Army Green SR5
    I believe that older versions of the TRD plate did not come with the red logo. I am pretty sure that the newer ones include the logo.
    indydieselnut[QUOTED] likes this.
  16. Apr 14, 2021 at 7:20 AM
    #196
    indydieselnut
    I'll probably go RCI powder-coated aluminum in that case. I'd prefer it all black anyway; I was just trying to stick with Toyota parts. Thanks!
    2mchfun likes this.
  17. Apr 14, 2021 at 12:46 PM
    #197
    2mchfun
    Update: The ranch hand bumper has arrived, it's a beast! There is no way the Rancho quick lift coilovers will work, not only because crewmax weight, but also the ranch hand and the front receiver. All together over 200 lbs at the very front. So, the Rancho coilovers are going back and fat bobs garage vated 3" coilovers with 700# springs which are bilstein 5100s with adjustment collars similar to toytec boss are inbound via ups air. Going to buy once, cry once! Might throw in a 1/4" coachbuilder shim and back down the adjustment just a little. Trying to find out what is going on with coachbuilder, can't get status on my shackle order yet. Trying to get this truck done ASAP. Fwiw, there is no substitute for this ranch hand bumper, photos do absolutely no justice. It almost needs it's own idependant chassis! If only now I could find some decent rear traction bars to keep the axle more stable. Don't want to keep stressing all those components for the long haul. BDS has some but damn, another grand?? I guess it is pay now or pay later! Just wanted to share my experience, pics coming soon.
  18. Apr 14, 2021 at 12:49 PM
    #198
    2mchfun
    Love the truck, hate that it needs so many expensive mods to make it a "truck" not a grocery wagon!
  19. Apr 14, 2021 at 12:54 PM
    #199
    2mchfun
    Stock coilovers, front bumper, mirrors, all for sale. Will list when time permits.
  20. Apr 14, 2021 at 1:10 PM
    #200
    zach_attack4
    zach_attack4 New Member
    Zach
    York, PA
    21 Army Green CM
    I posted in another thread about this but incase any of my fellow trail edition guys missed it, I got a bunch of stuff to fit.
    Trail Edition boxes, Leitner Rack, Rago Bed Stiffeners, and OEM Bed Rails. A little trimming, some custom holes, and a few grade 8 nuts and bolts.
    168053639_10165094342565394_875285124334_e03f06f659cfc7ed478b727bbdf30625959a1191.jpg
    167636246_10165094343070394_770380233581_2823a772a1688810bc7ca5fff6f8fb4a37750731.jpg
  21. Apr 14, 2021 at 1:29 PM
    #201
    2mchfun
    I dig the rack, might get one and add a piece of heavy expanded metal with hinges behind the rear window somehow to protect the window and hinge open to clean the glass.
  22. Apr 15, 2021 at 11:45 AM
    #202
    2mchfun
    The truck is still attacking my bankroll, ordered a set of bds recoil traction bars, a set of hella auxillary driving lights for the front bumper, and a westin hdx headache rack that I intend to slightly modify with a few braces and a winch mount for an atv winch to mount up under the rear window. The ranch hand sport rear bumper is in my sights now too, just waiting on a damn promo code to seal the deal. Finally, getting somewhere with transforming this toy into a "truck"! Glad I bought it when the price was right, never guessed I would be adding 5 grand in the first year though. Thank you to my fellow American taxpayers! Please send more stimulus, and I will be happy to stimulate the economy even more!
    CorsoTundra likes this.
  23. Apr 16, 2021 at 6:09 PM
    #203
    2mchfun
    Update: Fat Bob's adjustable +3" coilovers have arrived, and they are of great quality! I will release them about two full turns prior to installation. As for bump stops, I will be using factory with extension in the front location and wheeler's superbumps with extension in the rear front to give it a progressive bottom out point, trying to minimize any hard impacts. Looks like coach builder shackles are a few days out so I will be doing the front this weekend and rear next weekend. The front bumper will be this weekend too. Next week the headache rack arrives too. A few weeks on the front receiver and rear traction bars. Shipping is slow now unfortunately. Trying to decide on tires either Toyo AT3/ Bf KO2/ Nitto RG. Still need a coupon code for the rear bumper discount, maybe next week. Take care!
  24. Apr 18, 2021 at 10:41 AM
    #204
    2mchfun
    Ranch hand and 3" lift up front, next weekend do the rear shackles.Screenshot_2021-04-18-12-35-22.jpg
  25. Apr 19, 2021 at 7:29 PM
    #205
    cc4337
    cc4337 New Member
    Clark
    2021 Cement Tundra Trail Edition
    Was hoping you could tell me from the pictures I posted of my exhaust pipe if the black chrome tip would fit my truck. I was wondering if your exhaust pipe had a "flare" at the end of it like mine?
  26. Apr 20, 2021 at 11:40 AM
    #206
    cc4337
    cc4337 New Member
    Clark
  27. Apr 21, 2021 at 6:43 AM
    #207
    indydieselnut
    Just got the current Toyota TRD skid plate and it DOES have the red TRD logo on it. However, it's pretty slick how they did the letters and I think it should look good for a long time. I'm planning to paint my front tow hooks the same red (saw several other people doing this) and I think it should be a good look.
    jonclark96[QUOTED] likes this.
  28. Apr 21, 2021 at 6:44 AM
    #208
    indydieselnut
    Sorry for the delay! Yes, the Toyota TRD tip will fit. There are two "c" pieces that sit behind the flare that it clamps on to. Great fit and finish, easy install.
  29. Apr 21, 2021 at 6:45 AM
    #209
    2mchfun
    Update on the truck: Bilstein has shipped the rear shocks, the rear Ranch Hand sport series rear bumper has also shipped. If all goes well the rear lift will happen this weekend, depends on if the shackles arrive. The Hella driving lights for the front bumper will go on also this weekend. Got a lot going on with the headache rack plans too, waiting on the rack to ship though. Already got super bright work/off road lights that are slim and will mount back to back for two way lighting leaving space on the rack for lumber, ladders, kayak, etc. Also got two faced marker/turn lights that will mount on the outside at the top of the rack. The rack is going to be fastened to custom fabricated HD bed rails mounted in stake pockets. The rails will tie the rack together with angled square tube stock to transform the headache rack into roll over protection also, it will be substantially stout when all is completed, much more than just glass protection and ladder support. There will also be a removable rear rail directly across the top of the tailgate to carry heavy loads. Got a prebuilt 6 gang switch panel/box from Amazon for $30 for all my exterior auxillary lights, its small, good quality, and will mount easily with mounting tape probably right beside drivers knee without any problem and within easy reach while at the helm. As for tires, I park this truck on my driveway and the stock size isn't terrible, especially for towing. So, to help prevent tire/wheel theft it might be wise to keep them as is. Yes, got wheel locks, also planted two semi tires halfway into the lawn right at the edge of the driveway that line up perfectly with my truck to barricade access to two rims. These also serve as places to sit and watch the kids play. Chose tires because I didn't want my children falling into bricks or rocks 18" off the ground while playing outside. Took some work, but turned out nice and keeps the rims on the truck while I sleep. All in all, it's coming together, and we should be doing some traveling in a comfortable and safe truck this Summer. Limited only by the pandemic of course!
  30. Apr 21, 2021 at 10:00 AM
    #210
    2mchfun
    The verdict is in: The Ranch Hand rear bumper arrived today (not exactly sure how, miraculously fast!), anyway it is every bit as solid as the front. If you want aftermarket, these are going to give your truck and it's occupants serious protection folks. I have looked at many options and I assure you all the photos don't show you what is under the skin. The Ranch Hand is all beef and no Chinese stamped crap. Wish I would have been able to score their headache rack too, tried but not available. No offense to those other manufacturers, I get it, the market is full of options for everyone and their needs, but if you want to have a "truck" bumper or two, I suggest these be considered. Yes, they do lead to suspension mods due to the weight and design, but I look at that as an added bonus! To each his own! Pics coming soon!
