Tractors...
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Sep 27, 2017.
  1. May 19, 2025 at 11:44 AM
    #481
    woods
    woods New Member
    2021 SR5 TRD Sport
    Took delivery of a big tent today, barely able to do it. Vertical box was a real pain and the bottom was broken so it wasn't stable, did not enjoy moving that one down the highway from my business to these containers. had to have help crossing the road as I couldn't see a thing as I was driving.
    If you don't have forks on your tractor, what are you even doing! These things have saved my butt moving big logs and let me handle commercial deliveries, saving more than they cost, without question. They are close to my favorite attachment I own!
  2. May 21, 2025 at 11:39 AM
    #482
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Going to be in the market for a tractor shortly. Long story short, we live off-grid on 21 acres. We have a farm with lots of animals. I need something that will do a variety of tasks. Front bucket, forks for unloading hay bales (1500-1700lbs on average), Backhoe, auger (fence work), plow (snow removal), box blade (road maintenance), tiller (crop planting), etc. Pretty much every attachment will see use in what we do. We are looking at preparing 1-2 acres for growing our own alfalfa and grains for feed for the animals. Lots of digging and moving dirt as well (we are on about a 2% grade property wide with some areas seeing 4% or higher with dips, etc. I rent a mini-ex on occasion because that is the max the Tundra will tow. I have operated large machinery (backhoe, Trackhoe, bulldozers, etc) so i'm no stranger to operation and upkeep. My concern is how "Big" of a unit do I need to realistically not ride the ragged edge on capacities with the hay bales being the most use for the tractor followed closely by dirt work.
    BR73, woods and ColoradoTJ[OP] like this.
  3. May 22, 2025 at 2:58 AM
    #483
    woods
    woods New Member
    2021 SR5 TRD Sport
    I think you are at least around 40hp, and to make your work easier I think 50-60 should do everything you want, and do it strongly. Make sure to pay attention to total tractor weight, the more the better! I have a 40hp with 30ish at the pto. I do most of what you do besides growing grass, but my fields do that and I mow them down with the brushhog. If you had a 50-60hp that could lift 2k or more, I think you'd be able to cruise through most chores. I love tractorbynet.com for my tractor forum.
    My tractor could come close to doing everything you want at 38hp and about 4k lbs with weighted tires, but I could do it happily stepping up to a more ag tractor than hobby tractor I have.
  4. May 22, 2025 at 5:43 AM
    #484
    birdman076
    Chuck
    Montana
    I appreciate the input and the link to the tractor forum. I am looking at something like a Kubota L6060 or a John Deer 5060E which come in around 60hp / 50ish at the PTO. I prefer a little buffer so I'm not riding the ragged edge all the time.
    woods[QUOTED] likes this.
  5. May 22, 2025 at 6:15 AM
    #485
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Those Kubota's are excellent machines. I'm a huge fan of them. I agree that you should go bigger than you need if you can swing it.
    birdman076[QUOTED] likes this.
  6. Jun 3, 2025 at 3:18 PM
    #486
    250000yota
    250000yota New Member
    Russ
    Berthoud, CO
    White 2015 SR5 Crewmax
    S&B intake, Dirty Deeds 8", Airlift airbags with Daystar contact cups, LED's everywhere including Diode Dynamics stealth front LED bar, Baja Design Squadron II's on CBI ditch light brackets, completed Diode Dynamics interior LED's. Full RCI skids with cat guards and sliders, Transfer flow 46 gallon tank. Radflo 2.5 IFP coilovers, Coachbuilder shackles, TRD rear sway bar. 295/70R18 Nitto RG's. Dobinson snorkel, softopper.
    Just finished a little side job that I picked up through my normal side job. I haul scrap to make extra money, and I picked up a load from a couple that were trying to clean up the woman's parent's house and property. After picking up the metal they asked me if I knew anyone who did field mowing. Through a little negotiating I worked a deal to borrow my dad's Ford 3000 and brush hog and take care of the field. I'm going to call it a learning experience. On the plus side, I'll never turn down seat time on a tractor and the pay was alright. The learning side though is that you always need to establish the property borders BEFORE you work if they're not clearly marked, and that weeds can push hair pins out allowing things to fall off.
    To the first learned lesson, I ended up cutting close to 10 acres over two Saturdays. Before I began cutting, I was told that a white capped T-post marked the northern edge of the property. What I didn't hear was that it also marked the east edge. So, I went along my merry way running the mower, and cut both parcels, even though I was only paid to cut one. :confused:
    The second lesson was much more of a pucker moment. To haul the tractor (see the first picture with my daughter posing on grandpa's tractor on the trailer) my dad uses a hitch receiver mounted in the front, with a chain and binder. It works well, holds the tractor steady during transport and is fast. What I didn't realize is the tall weeds (Between 3-5' tall) had enough strength and mass to push the hair pin out of the hitch pin. On one of my U-turns, the receiver fell out. On a subsequent U-turn, I found said receiver with the brush hog in a very loud and terrifying fashion. Surprisingly to me, the mower ended up winning the battle. I cut for another 3-4 hours after hitting it.
    The weather was rather uncooperative, hence taking two Saturdays to cut. We've gotten a lot of rain in the last two weeks here in Colorado, and scheduling around thunderstorms has been a challenge, as has the soft ground in the fields.
    Time will tell if I do this again but it sure was fun turning diesel into smoke and noise and cutting some weeds down. Ford and Ellouise on the trailer.jpg
  7. Jun 3, 2025 at 6:37 PM
    #487
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    2020 SR5 Barcelona Red CREWMAX 4x4
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    I will be using my L2502 this weekend spreading lime if we don't get rained out IMG_20240224_110951_01.jpg
  8. Jun 3, 2025 at 6:39 PM
    #488
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    4wd 57 HP Kabota for the win
  9. Jun 3, 2025 at 6:52 PM
    #489
    Florida AF
    Logan
    North Florida
    Back in business.... ran the brush hog for a bit and then went and got the box blade... going to work on leveling the dirt in the barn a bit more so I can order the first round of flooring...
  10. Jun 30, 2025 at 12:51 PM
    #490
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Tractor put in proper work today fellas. I’m impressed it pulled the engine and trans together!
    250000yota, woods, BR73 and 1 other person like this.
  11. Jun 30, 2025 at 3:40 PM
    #491
    woods
    woods New Member
    2021 SR5 TRD Sport
    A little counter weight goes a long way! The little tractors are always impressive in their capabilities imo.
    Mountun Goat[QUOTED] likes this.
  12. Jun 30, 2025 at 9:07 PM
    #492
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Yessir. Hydraulics are amazing
  13. Jul 2, 2025 at 6:04 PM
    #493
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Dammit!!!
    Just stumbled across this thread again!!
    Dammit now I want another tractor and I'm living in the Burbs!!
    Someday soon...someday...
    Mountun Goat, 250000yota and woods like this.
  14. Jul 2, 2025 at 6:15 PM
    #494
    Made myself a driveway drag the last few evenings. Damn UPS/ FedEx/Amazon think my driveway is a race track it's a 800 feet long and chatter the hell out of it. The box blade works but you have to really pay attention when doing it. Tried it out last night before I painted it today and it works awesome. IMG_20240519_103620~3.jpg PXL_20250703_010750481.MP.jpg PXL_20250703_010739255.MP.jpg
    Mountun Goat, woods, Outbound and 4 others like this.
  15. Jul 2, 2025 at 8:45 PM
    #495
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Nice work Bryan!
  16. Jul 3, 2025 at 5:11 AM
    #496
    250000yota
    Russ
    Berthoud, CO
    Never stopped my dad...:rofl:
