TPMS steel to Alloy
Discussion in 'Wheels & Tires' started by sresweber, Jun 7, 2021.
  1. Jun 7, 2021 at 5:23 PM
    sresweber
    sresweber [OP] New Member
    Steven
    2021 Tundra CrewMax
    I have a 2021 Toyota Tundra CrewMax switched my original steel wheels to alloy and the TPMS sensors did not fit. The Tire Shop (not Toyota) tried after market sensor and could not get to program. After much research and consulting the Toyota dealership, they were told that my ECU is running on a different hertz than the TPMS and they can't get ones that will fit in the alloy and be the right hertz.
    Is this all crap, or is there a solution that will not have me changing my ECU or having to go back to steeel?
  2. Jun 7, 2021 at 5:33 PM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Doesn't make sense...They sell 2021s with Alloys, don't they????
  3. Jun 7, 2021 at 5:37 PM
    sresweber
    Steven
    2021 Tundra CrewMax
    Doesn't make sense to me either, but they said the ECUs are different on the ones with alloy and that my ECU didn't have a second TPMS channel
  4. Jun 7, 2021 at 5:45 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
  5. Jun 8, 2021 at 4:41 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    Want to sell the TPMS out of the steelies?
  6. Jun 8, 2021 at 5:07 AM
    sresweber
    Steven
    2021 Tundra CrewMax
    Not until I can get something working on the alloy ones!
  7. Jun 8, 2021 at 5:16 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    so, yes....steel wheels have different style sensors that don't transfer over to alloy wheels. the sensors are kind of finicky (<----is that a word?). they run a different frequency that most and when i got my new wheels with sensors changed, the tire shop (discount tire in TX) said that they do run off a different frequency and are usually more difficult to buy for and program. both my 2011 tundra and 2017 tundra did fine reprogramming the new TPMS to the truck, but it was stated that they were different and more of an issue than most vehicles out there. but, it is possible to get them for your truck and for them to program, you just have to purchase the correct ones.
    i actually think i saw someone selling their TPMS off their truck, but don't remember where.
  8. Jun 8, 2021 at 5:19 AM
    Welcome from NY.
    The steel ones just don't fit properly because the rim is different.
  9. Jun 8, 2021 at 5:27 AM
    eagleguy
    eagleguy New Member
    Had the same issues with the same wheel swap on my 2021 Crewmax. 3 out of 4 sensors from the steel ones worked. The third blew out and Toyota charged me $300 for the fix which the tire shop ate.
  10. Jun 9, 2021 at 10:42 PM
    paulbk
    paulbk New Member
    I was in your exact situation a few months ago. The oem steel tpms and oem alloy tpms are at different angles once mounted in the wheels (20° and 40° iirc). There are some possible solutions to have your steel tpms work on alloy rims (mounting them upside down) but nothing worthwhile IMO.
    I even tried having the tire shop install their own a/m tpms onto my scs sr8 wheels and this also did not work.
    As soon as i installed the correct oem tpms (oem part #426070C091) the dealership was able to program the sensors immediately and I have been tire light free since.
    To save you headache, I’d recommend just going oem if u can. I learned the hard way - luckily i was refunded the cost of the a/m tpms and found oem tpms on sale for the same price!
    here is a link to my thread when I was looking for input: https://www.tundras.com/threads/tpms-not-working-on-scs-wheels.85934/
    i hope this helps. Good luck!
    AverageJoe likes this.
  11. Jun 10, 2021 at 6:48 PM
    Noeyes
    Noeyes New Member
    Shawn
    2021 tundra sr5
    I'm going through the same thing and just posted a new thread on this. I found some that are pre programmed and am wondering if anyone has had any luck using them.
