TPMS issues
Discussion in 'Wheels & Tires' started by YoTundra, Nov 22, 2019.
  1. Nov 22, 2019 at 7:25 AM
    YoTundra
    YoTundra [OP] New Member
    2018 Tundra SR5 Quicksand
    Had aftermarket wheels put on and new sensors on the wheels. The shop cannot get them to connect to the truck. Been dealing with it for a few weeks.
    Has anyone had issues with not getting aftermarket sensors to work.
    The truck is a 2018 Tundra SR5
  2. Nov 23, 2019 at 6:28 PM
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    The same happened to me with 2019 Tundra Limited. I put some steel wheels with winter tires on it and Discount Tires installed their aftermarket sensors. I've been there 4 times and no success. TPMS light still on. It looks that IDs are correctly programmed in ECU (I can read them) and they can read them in the wheels. The sensors just do not connect.
    I plan to purchase some Autel MX sensors and Autel 501 device and try to program and register them myself.
  3. Nov 26, 2019 at 4:46 AM
    YoTundra
    Let me know what happens with this, cant believe I haven’t had more response, haven’t been able to find much information on this, tomorrow the shop is going to try different sensors.
  4. Nov 26, 2019 at 4:50 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Have them rotate the sensors 180°. It happened to me too when I installed aftermarket wheels from steel.
  5. Nov 26, 2019 at 5:30 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Find the thread on here that tells you how to permanently disconnect the TPMS.
    Rex Kramer likes this.
  6. Nov 26, 2019 at 5:46 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I removed my sensors and replaced them with standard valve stems, the yellow warning light stops flashing after about two minutes.
  7. Nov 26, 2019 at 12:12 PM
    YoTundra
    They are not OEM sensors, but the orientation really matters?
  8. Nov 26, 2019 at 1:10 PM
    SprinterAE86
    Ian
    Radio signals maybe too week I'f antennae is pointing the other way.
  9. Nov 26, 2019 at 2:46 PM
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    I don't believe that. Radio signal is strong enough even if the tires are not on the truck but stored on the other side of my garage.
  10. Nov 26, 2019 at 2:54 PM
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    I did a test today. I changed IDs back to my original tires using TS501 and put my original tires on the bed of the truck. I drove about 200 feet and the TPMS light went off and the pressure was displayed correctly. So it looks that programming using TS501 works, the problem is the new sensors.
    So I made clones of my original sensors (used Autel MX sensors and TS501 tool). I planned to test them today but no chance to find a store where they would change it. It's before Thanksgiving and a snowstorm is coming to our area. I will try it in a week or two. At least, my TPMS light is now off because TPMS can read my original tires stored in the garage and for short trips, it's enough not to trigger alarm.
  11. Nov 26, 2019 at 4:15 PM
    SprinterAE86
    Ian
    After rotating the tpms 180° in an oem worked with me. It took 7 trips to discount tire to figure it out after numerous research and resetting.
  12. Nov 26, 2019 at 4:21 PM
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    Thank you, it looks that anything is possible. Toyota TPMS is probably some kind of magic...
  13. Mar 3, 2020 at 4:48 PM
    ClaytonW
    ClaytonW New Member
    2022 Tundra 1794
    O.K., today Discount Tires replaced the sensors with Toyota OEM sensors and everything works now. I would be very careful with aftermarket sensors. I was not able to make them work.
