TPMS headache
Discussion in 'Wheels & Tires' started by scottcleaver, Mar 27, 2019.
  1. Mar 27, 2019 at 11:07 AM
    scottcleaver
    scottcleaver [OP] New Member
    Scott
    2009 Tundra
    I have a 2009 Tundra. Had it for 5 years. TPMS light has been on the whole time. Finally decided it was time to fix the problem. I put new sensors in it and the light is still on. I worked at Toyota and Lexus dealerships for years and would prefer not to go in for such a small issue. The guy that installed all 4 did get them to register with truck but the light still remains. We have tried the initialization process twice and both times it seems like it was fine and after a short drive its supposed to clear the light. It wont. Can I do something myself to diagnose?
    Thanks
    Scott
  2. Mar 27, 2019 at 11:58 AM
    Joe Dirt
    Joe Dirt New Member
    Don
    Sunriver, Oregun
    Silver 2018 SR5 4X4 DC
    99% of all tire shops will fix this easily.
    Mnorris1206 likes this.
  3. Mar 27, 2019 at 12:01 PM
    Does your spare have one? The light was on in the wifes 4Runner when it got cold and we found that the pressure was low in the spare. Some spares have them, some do not.
  4. Mar 27, 2019 at 12:04 PM
    Mnorris1206
    08 tundra
    The tpms sensors need programmed to the truck. Did you have a shop install them ?
  5. Mar 27, 2019 at 12:07 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    What's your tire pressure? I was told too much pressure can cause the light to come on too.
    joonbug likes this.
  6. Mar 27, 2019 at 12:24 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Discount tire programmed all 4 of mine. They also used a tpms reset tool. The reset tool was different from his programming scanner. I learned something new that day..
  7. Mar 27, 2019 at 12:33 PM
    TheBeast The Beach
    any way to disable TPMS ?
    831Tun likes this.
  8. Mar 27, 2019 at 12:50 PM
    scottcleaver
    Scott
    2009 Tundra
    Joe,
    A tire store did it for me twice. I watched both times and it all went well, except for the damn light>
  9. Mar 27, 2019 at 12:51 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Yes, you need to cut and jump one wire from the TPMS harness. I did this and no more TPMS light. Its no help for pre-2018 anyways, it doesnt tell you which tire is deflated.
    TheBeast[QUOTED] likes this.
  10. Mar 27, 2019 at 12:51 PM
    scottcleaver
    Scott
    2009 Tundra
    Spare tire does not have a sensor.
    Joe Dirt and Watt maker like this.
  11. Mar 27, 2019 at 12:52 PM
    scottcleaver
    Scott
    2009 Tundra
    The tire pressures are dead on with the factory settings. 43 in the front and 45 in the rear, according to the tire sticker in the door jamb.
  12. Mar 27, 2019 at 12:54 PM
    Makoy339
    Super White TRD
    TRD parts
    chugs and TheBeast like this.
  13. Mar 27, 2019 at 12:55 PM
    scottcleaver
    Scott
    2009 Tundra
    After spendig the money on 4 new sensors and breaking down 4 tires and balancing again, I sure would prefer not to just trick the light to go off. That would be my last choice.
  14. Mar 27, 2019 at 12:56 PM
    scottcleaver
    Scott
    2009 Tundra
    Makoy339,
    Thanks for the link. Hope it doesnt come to that.
  15. Mar 27, 2019 at 1:16 PM
    TheBeast The Beach
    what tires are you running at 45 psi ? seems on the high side.
  16. Mar 27, 2019 at 1:22 PM
    scottcleaver
    Scott
    2009 Tundra
    I try to use the factory settings that are found in the drivers door jamb. Stickers says 43 front 45 rear. I have different tire now than when I got the truck 5 years ago. Running Goodyear wranglers at the moment.
  17. Mar 27, 2019 at 1:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Put 'em in a PVC tube that you can pressurize and throw it behind the seat. I'm seriously bummed I didn't have mine removed when the new tires went on the other day.
  18. Mar 27, 2019 at 1:23 PM
    scottcleaver
    Scott
    2009 Tundra
    I will try to reset it again after I drop them down to 28-30, see if that helps. Thanks
    Watt maker likes this.
  19. Mar 27, 2019 at 2:00 PM
    TheBeast The Beach
    yeah between deflating tires before going off road and different sets of wheels. TPMS is too much of a hassle. If you take care of your car, no need for TPMS
    Watt maker and 831Tun[QUOTED] like this.
  20. Apr 1, 2019 at 1:30 PM
    schaderaide
    schaderaide New Member
    Ryan
    Orange County, CA
    TPMS sensor has been giving me fits ever since I did my lift and tire replacement. My issue has more to do with it being a 2018 and the shops being too cheap to update their software to properly reset the sensors. 2 shops both told me to go into the dealership. Not worth my time to go out of the way for TPMS. Im just going to wait until my next maintenance visit.
    A tip one of the shops gave me was to take your OEM wheels/tires (if you still have them and if they still have the sensors) and lean them up against your wheels. If TPMS recognizes them, its possible the senors that are int he new setup arent compatible
