Disable TPMS
Discussion in 'Wheels & Tires' started by 650h1, Dec 9, 2014.
  1. Jan 21, 2019 at 7:25 PM
    #61
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Last week was the first time I’ve had a TPMS warning for a legit low tire pressure. In about 9 years of having TPMS on my vehicle. Checked pressures, sure enough, left rear was down to 24 psi. Topped it up with my favourite nitrogen blend, and three days later the light came on again. Topped it up again, now to find time to visit the tire shop...
    I gotta say, it’s not all bad. I will say though, I do check pressures with a gauge less frequently than I used to. :oops:
  2. Jan 21, 2019 at 7:29 PM
    #62
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Thank god! I hate these. Have never paid for a set of sensors and never will. Thanks for the post!
    Joe Dirt likes this.
  3. Jan 23, 2019 at 2:42 PM
    #63
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Confirmed. 10 minutes, a razor blade, and 3" of electrical tape, my pesky light is cured using this method.
    Schmidt_l, SpottedDog, WVI and 7 others like this.
  4. Mar 1, 2019 at 7:30 PM
    #64
    Coffee
    Coffee New Member
    Wayne
    05 Tundra SR5 Double Cab
    None
    i know this is an old post but I am having the same issue in that I would like to disable TPMS on my 05 Tundra. I have read all the threads and know radio shack is out of business now. I think I have located the TPMS unit in the upper right side of glove box location. Mine is blue box not grey. I have not pulled the TPMS unit out to look at it but after the blown fuse issue wanting to ask if there were any more clarifications I should be aware of before attempting this?
    On another issue last weekend I pulled the instrument cluster out to fix a squeak in the dash and when I put it back in everything works now except no odometer reading, just underlines where numbers should be on the odometer and the same for the two trip meters. Any ideas on how to pull the odometer reading back in. I’m thinking the mileage reading isstore in the vehicles computer. Is there a procedure to pull it back in? I drove it town afterwards about 20 miles each way thinking that might do it but still no odometer reading.
  5. Mar 3, 2019 at 5:11 AM
    #65
    Rybman1
    Rybman1 New Member
    Ken
    2014 Toyota Tundra
    Took me 15 minutes on my 2014, I'm a little slow! Installed an aftermarket stereo with the ability to show engine functions. It would only show the tpms screen as there was an error code due to no sensors.Next time I need tires I will revert back and add the sensors to my fuel's for piece of mind.
  6. Mar 21, 2019 at 10:42 AM
    #66
    XNeewbie
    XNeewbie Eat-Sleep-Yota
    Charlie
    SC
    2017 Gray Tundra CM SR5 TRD 4x4
    20% Tints - Bull Rings - Rubber Mats - Toyota Center Console Cover - Clazzio Seat Covers - Pop & Lock - Bed LEDs w/ Timer - EvoOne Remote Start - FRAC Harness w/ Front Camera - Handle Bar - TRD Shift Knob - TRD Sway Bar - AJT Fob Cases & Battery Tie Down - Breather Mod w/ Filter - SDHQ Speed Sensor Covers - BORA 1-1/2" Spacers - TRD License Plate Frame - LEDs all Around - Door Sills - Front Seat Bracket Bolt Covers
    Did this to my wife’s 08’ Tundra. Had some code about the TPMS computer not being able to communicate. Months of research and swapping out the TPMS computer, receiver, and sensors but still no avail. Over $1,000 later and Toyota charging me $200 to tell me they couldn’t find the issue, I decided to do this. It worked like a charm! Stupid blinking light is finally off. Thank you guys for this posts.
    Schmidt_l, SpottedDog, WVI and 6 others like this.
  7. Mar 27, 2019 at 1:11 PM
    #67
    TheBeast
    TheBeast The Beach
  8. Jun 6, 2019 at 10:52 PM
    #68
    TheFreshMouse
    TheFreshMouse learning as i go...
    Mouse
    18 CM MGM
    Pinstripes
  9. Jun 22, 2019 at 4:03 PM
    #69
    melcoeb
    melcoeb New Member
    I just did this, thanks, OP and other contributors, this was a simple mod to do. I have a 2010 Limited, I did not have to take off the glove box. All I needed to take off is the lower valance in the picture. Once this was off, it was on the right side, it's a gray box that says "computer tire pressure monitor" (or close to that) . Unplugged the harness, cut and scotchlocked the appropriate wires , and done.
    Schmidt_l likes this.
  10. Jun 26, 2019 at 12:29 PM
    #70
    scottcleaver
    scottcleaver New Member
    Scott
    2009 Tundra
    After all this time I finally had enough of the light and exhausted every possible (in my mind) fix. I decided to cut the light green and attach to the primary yellow wire. The aggravating as shit light is gone and for good I would think. Thanks for the help.
  11. Jul 17, 2019 at 11:22 PM
    #71
    duncanrc
    duncanrc New Member
    Duncan
    2014 SR5 Double Cab 2WD 4.6L
    My truck didn't come with sensors but did come with the dash warning light.
    Toyota dealership sold me 4 OEM's for $200 and I had them installed at a local tire shop while I replaced rubber.
    I asked the OKTire tech and was told no special scanner is needed and continued to install and program them for free since I was changing rubber from winter to summer @$108
  12. Jul 20, 2019 at 12:08 PM
    #72
    KevinK
    Back in Arizona. Again.
    Tundras to Sedona
    He didn’t need a scanner because he had direct access to the sensors and could read the serial numbers by sight. If you can’t read the sensors (you bought used wheels and tires with tpms in them and aren’t cracking the set open for new tires) then you need a scanner to get the serial numbers.
  13. Sep 18, 2019 at 5:30 PM
    #73
    hunterpedrick6
    hunterpedrick6 Hunter Pedrick from Quitman ga
    Hunter
    Quitman,ga
    2019 Toyota Tundra trd off-road sport white
    I want to know how to do this on my 2019 Toyota Tundra step by step someone please inbox me.
    Fishin likes this.
  14. Oct 11, 2019 at 9:18 AM
    #74
    longcat
    longcat New Member
    Jon
    DFW / Texas
    2024 Tundra 4x4 Hybrid CrewMax (Silver)
    I just checked my 2019 and the module isn't in the same location, or if it is it looks completely different than anything in this thread. I'm guessing they moved it or redesigned it at some point.
  15. Oct 21, 2019 at 10:13 AM
    #75
    TJ07Tundra
    TJ07Tundra New Member
    2007 Tundra
    I just did this and it looks to have worked perfectly so far. Bye bye low pressure light.
    I cut the light green wire at the connector and used a quick connector to tap into the yellow low voltage line. Best of luck to anyone else that tries this.
    2007 Tundra Double Cab
    Cruiserpilot and Biggyj1967 like this.
  16. Oct 21, 2019 at 1:54 PM
    #76
    AYANG
    AYANG New Member
    Ontario, CA
    2016 Black Tundra Crewmax
    Good to know
  17. Oct 24, 2019 at 9:40 AM
    #77
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    Did you switch out your air
    Dont leave summer air in your tires
    You must replace it with winter air
  18. Oct 24, 2019 at 9:42 AM
    #78
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    So you connected it straight to the yellow wire without a resistor
    In OP. He shows a picture with 2 resistors in line
    Or that for something else ???
  19. Nov 8, 2019 at 8:45 AM
    #79
    102dalz
    102dalz New Member
    Andy
    2017 Tundra CrewMax White
    None
    For what years & models does this work? All cabs: Regular, Double, CrewMax?
    Thanks...before I start looking for cabling & cutting stuff, I'd like to make sure this will work.
  20. Nov 8, 2019 at 8:53 AM
    #80
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've done this to my RC, but I would imagine that most who have done it own DCs/CMs.
  21. Nov 19, 2019 at 4:53 AM
    #81
    Lifeislarge
    Lifeislarge New Member
    2007 Tundra 4X4 TRD 5.7L
    I just did this to my 07 DC and want to personally thank whoever the genius was who came up with this hack. TPMS has been nothing but a cash grab for Toyota and having driven for 30+ years without it I'm well accustomed to a tire gauge and compressor to keep my damn tires inflated to the right pressure. I had a piece of electrical tape over the light on my 06 and this is a much better solution.
  22. Dec 12, 2019 at 8:26 PM
    #82
    beretdra
    beretdra New Member
    I just came to see this thread and got an 06 Tundra and the Tire Pressure Monitoring System light suddenly blink. I add pressure to the tire the night before and this morning while driving it suddenly turns on and blinking. Does the TPMS got reactivated too and blinks if the the tire pressure is a about 2 PSI higher in the front. I normally run 30 in the front and 32 in the rear. Yesterday I inflate the front up to 32 . Will that trigger the sensor? please advice.
  23. Dec 13, 2019 at 4:13 AM
    #83
    Lifeislarge
    Check your spare tire. If that has similar pressure then you probably have a bad sensor in which case you have two options, take it to a tire store or the dealer and have it replaced or disable the TPMS as discussed above.
    beretdra[QUOTED] likes this.
  24. Dec 13, 2019 at 11:07 AM
    #84
    beretdra
    beretdra New Member
    Thank you for your reply. I will lessen the air pressure on front tire and see what happens. Happy holidays.
  25. Dec 13, 2019 at 7:49 PM
    #85
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
  26. Dec 14, 2019 at 12:15 AM
    #86
    beretdra
    beretdra New Member
    I put the tire pressure back into the manufacturer's recommended pressure which is 29 front and 32 rear and the blinking TPMS light disappeared.
  27. Dec 14, 2019 at 12:16 AM
    #87
    beretdra
    beretdra New Member
    Lesson learned follow the manufacturer's recommended tire pressure always!
  28. Feb 16, 2020 at 7:22 AM
    #88
    Obtunded
    Obtunded New Member
    San Antonio
    2016 Tundra CrewMax XPS-X 4x4
    Carbon fiber dash, leather seats
    I just recently spent hours trying to fix why all my lights were on. My vsc,slip light engine light and tps were on. Flashing and driving me crazy. I put all my tires to factory recommended psi. I finally out of frustration bypassed the tps sensor ,and guess what. Al my lights went off and stayed off. I was so close to trading my tundra for a gmc or Ford. But now I'm happy to stay a tundra man.
  29. Feb 16, 2020 at 7:47 AM
    #89
    Big J
    Big J New Member
    2020 4x4 crewmax
  30. Feb 16, 2020 at 7:57 AM
    #90
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    I agree it's a stupid system in how it is set up. Meaning it's good for those that could use it, but you should be able to flip a switch and shut it off if you dont want it. You can shut off the passenger side air bags, why not this. I can't believe Toyota didn't see this coming. It's a vehicle alot of people are going to be changing rims on. Compared to say a Prius.
