TPMS after a tire rotation
Discussion in 'Wheels & Tires' started by zeke7681, Jan 31, 2019.
  1. Jan 31, 2019 at 4:50 AM
    zeke7681
    zeke7681 [OP] New Member
    Zeke
    PA
    2018 Black TRD Sport CM
    I have a 2018 and was wonder how the Tire Pressure on my dash knows where each tire is after a tire rotation (just had a 5k checkup) . Do you have to reprogram it after a rotation or does it know somehow?
    jeremyd likes this.
  2. Jan 31, 2019 at 5:40 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Tire Pressure Monitoring Systems (TPMS) were created by The Russians. They just know after you rotate. They're smart like that. Nuttin' else for yooz to dooz. Good to go Bro.
    You can also rotate the tires and go inside and say out loud "Alexa, I rotated the tires on the 2018 Tundra." Same effect.
  3. Feb 23, 2019 at 7:27 AM
    SYRTundra315
    SYRTundra315 New Member
    Andrew
    2019 Super White Tundra CrewMax Platinum
    OEM nerf bars, BakFlip MX4, BedRug, VLED interior lights and license plate bulbs, JDM Astar turn signal and reverse bulbs.
    In all seriousness, the manual (pg 497 for my 2019) says to re initialize the TPMS system after you rotate. Since that procedure requires a 10-30min drive each time I suspect that this never happens. It would mean every 5k miles you have go through that process which is absurd.
    So, when you rotate tires yourself, does the system display the correct tire pressure at each location? Or are they wrong on the individual pressure display?
    Never had a system that shows each reading before and I am curious like the OP is.
  4. Apr 15, 2019 at 9:53 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    BUMP.... Curious about this as well. How does the system know where each tire is?
  5. Apr 19, 2019 at 5:25 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
