Toytec spacer question
Discussion in 'Suspension' started by DPOWELL391, Mar 8, 2020.
  1. Mar 8, 2020 at 4:06 PM
    DPOWELL391
    DPOWELL391 [OP] New Member
    DREW
    SOUTH CAROLINA
    2019 CREWMAX SR5 4X4 TRD Sport
    I just bought 2.5” front spacers for my Tundra. Just trying to make sure I received the right product before installing. I would think measuring from top to bottom would be 2.5” but it actually is only 2”. The pic is both spacers still wrapped up. Anyone with experience please help. Thanks!
  2. Mar 8, 2020 at 4:14 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  3. Mar 8, 2020 at 4:19 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Your pic angle and how you're holding the tape measure are a little weird, but it looks like each spacer (assuming there are two in that package?) looks to measure at 1.25". The way that the front suspension geometry works, that will bring you out to 2.5" on each side. There are quite a few threads on this, e.g. .25" spacers net .5" of lift, .5" spacers net 1", etc.
    Taco-Blender likes this.
  4. Mar 8, 2020 at 10:50 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    Front lifting any truck the spacer is normally about half the size of actual lift. For instance on coil overs if you adjust 1” worth you get actual 2” worth adjusting in front. Now the rear is equal 1:1 ratio. But front is 1/2:1 ratio
