Toytec Shackles are squeaking like crazy!! - '08 CM
Discussion in 'Suspension' started by digdug, Jul 13, 2019.
  1. Jul 13, 2019 at 1:11 PM
    digdug
    digdug [OP] New Member
    Doug
    2008 Crewmax
    Toytec Ultimate kit w/ Bilstein Fabtech UCA TRD stabilizer Boss shocks - Rear Airlift wireless one 35x12.5x20 Nitto G2 Grappler
    About a month ago I had Toytec Shackles installed on the top setting. They ride great. However, after about a week they started creaking/squeaking like crazy. The sound is so awful that I can't ride with the windows down, lol. I took the truck back to the shop and they tried repacking them with grease. Again, they were quiet for a week (to the day) and then started to squeak. The truck went back a third time and they tried packing them with marine grade grease, and again, after a week (to the day) they started squeaking again. I am wondering if perhaps I need new bushings (they used the old factory bushings, or does anyone know if an alternative type of bushing is available? It is not the bed bolt as I discovered here in my search. I have already investigated that as a possibility.
    Thanks for any help in advance. I'm at my wits end with this~
    ~dig
  2. Jul 13, 2019 at 1:18 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    you Sure it’s not rubbing the bolt. Mine didNt appear so the naked eye bug was in fact rubbing.
    Black Wolf and digdug[OP] like this.
  3. Jul 13, 2019 at 1:21 PM
    digdug
    Doug
    2008 Crewmax
    Yes, I'm positive. Trust me, I wish that was the problem!! I'm also on the top setting which places is far enough away from that bolt. Thank you though
  4. Jul 13, 2019 at 1:24 PM
    Blueknights75
    Ron
    Clayton, NC
    Ask @Toytec Lifts i would assume you would just want to have some poly bushings installed....
  5. Jul 13, 2019 at 1:27 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    digdug[OP] likes this.
  6. Jul 13, 2019 at 1:32 PM
    digdug
    Doug
    2008 Crewmax
    I sent them an email and this is the response I got:
    "Hello and good morning Doug!
    I do apologize for the inconvenience of the squeaky upper frame bushing! One thing I would personally recommend doing would be to insure that they are doing their final torque while the weight of the vehicle is on the ground, not in the air on their lift. That is one very common overlooked "install error" I have seen a lot of people do... Having the vehicle in the air and torqued down tight will cause the bushing to then have a "binding" effect once the vehicle is lowered back down to resting/ final ride height and then will cause the bushings start to squeak very bad/ loud.
    The only bushing I would personally recommend replacing them with would be Toyota OEM bushing. I have yet to see a bushing stand up/ be comparable to the OE bushings."
    Rica25 and Black Wolf like this.
  7. Jul 13, 2019 at 1:33 PM
    digdug
    Doug
    2008 Crewmax
    Rica25 likes this.
  8. Jul 13, 2019 at 1:33 PM
    Danman34
    Danman34 New Member
    Danny
    Try backing the nut off. They might have tightened them too much and it’s binding on the bushing. With that being said, the toytecs don’t like the oem leaf bushing. The teeth in it dig into the shackle and can shorten its life and albeit limit the suspension. Replacing them with polys will make a world of difference.
    digdug[QUOTED][OP] likes this.
  9. Jul 13, 2019 at 1:35 PM
    Danman34
    Danman34 New Member
    Danny
    I’m assuming they mean the top bushing. They sell poly bushings with their shackles so I can’t see how they would say they are junk. Even so, they would literally take 10 mins to replace if need be.
  10. Jul 13, 2019 at 1:36 PM
    digdug
    Doug
    2008 Crewmax
    We tried that too. They put the truck down and tightened them to specs. They work well for exactly a week, and then the sounds comes back. I might have to try those poly's and see if they help. Thanks!
  11. Jul 13, 2019 at 1:37 PM
    digdug
    Doug
    2008 Crewmax
    I agree, I found the email confusing. I will try these poly bushings and see how it goes. Thanks for your help
  12. Jul 13, 2019 at 1:50 PM
    Danman34
    Danman34 New Member
    Danny
    They made a noticeable improvement in the way the rear suspension feels. Makes it feel much more compliant and transition into and out of bumps is a lot smoother.
  13. Jul 13, 2019 at 2:28 PM
    There must be a typo in that email since the OEM bushings suck and ToyTec knows that too. That's why ToyTec offers the poly bushings! Quite frankly no make of shackles will fair well with the pos OEM bushings. It's always best to upgrade to poly bushings whether you are adding aftermarket shackles or keeping the OEM shackles to help mitigate bed bounce. I ran with ToyTec shackles on my 07 for almost 4 years with zero issues using their Energy Suspension poly bushings.
    BlackSheep likes this.
  14. Jul 15, 2019 at 7:35 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    I can get you squared away on a replacement set of bushings if you want, shoot me a call at 303-255-4959 ex 103 and Ill get you squared away.
    -David
  15. Aug 1, 2019 at 6:03 PM
    digdug
    Doug
    2008 Crewmax
    Thanks David. I've actually been emailing with you as well. I will call you tomorrow.
    Thanks again.
    Toytec Lifts[QUOTED] and Rica25 like this.
  16. Aug 1, 2019 at 6:07 PM
    digdug
    Doug
    2008 Crewmax
    No typo ... straight up copy and paste. David, who replied here on this thread is the same David I've been emailing with, and who sent me that email (unless there is more then one David at Toytec). I haven't been on in a while and am thrilled he replied here. I'll call tomorrow and hopefully I can get some direction on this. I love the way they ride, just can't stand the squeak and creak, lol.
    Thanks for the input
    Rica25 and Black Wolf[QUOTED] like this.
  17. Aug 26, 2020 at 4:34 PM
    100LL
    100LL smells better than Jet-A
    NW Oregon
    2020 SR5
    Potatoes.
    Did you end up fixing the squeak? What was the ultimate solution? I just installed Toytec shackes and they are squeaking like mad too. Verified they aren't hitting that bolt up top.
  18. Aug 27, 2020 at 10:14 AM
    Toytec Lifts
    Denver, CO.
    Was there grease applied on poly bushings during installation?
  19. Aug 27, 2020 at 10:16 AM
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Yup! I used the grease that came with the bushings.
  20. Aug 27, 2020 at 10:16 AM
    Toytec Lifts
    Denver, CO.
    Was final torque done at static height or at full droop?
  21. Aug 27, 2020 at 11:26 AM
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    Static height, sitting on the ground.
  22. Aug 27, 2020 at 11:27 AM
    100LL
    NW Oregon
    2020 SR5
    Potatoes.
    I may loosen them, jump on the bumper and re-torque to see if they need to settle or something.
